Speed of Sound vs Light - Possible?
  • Thread starter aman malik
In summary, the speed of sound in a medium is dependent on its density and elastic modulus. As the density of a material increases, the speed of sound also increases, but it is difficult to reach the speed of light due to the limitations of particle compression. Temperature also affects the speed of sound, as warmer temperatures result in faster sound propagation. However, the exact relationship between speed of sound and density is complex and depends on the material being examined.
aman malik
velocity of sound in dry air is 332m/s and it (linearly-i think so) increases with density.
so is it possible to formulate such a medium in which speed of sound reaches to the level of light
No its not possible
Velocity of sound in the air is related to temperature, not density.
Yea and the speed of sound in a solid is actually depenadant on the material's youngs modulus by the equation :
V = sqrt(Y/P)
Where Y and P stand for the youngs modulus and the density respectively.
The youngs modulus is the ratio between the stress and strain coefficients of the material.
It can be the case inside a black hole.
But if you take the known mass of the Universe and it's known dimensions we might well be in a black hole, and it's not true here either...
OP: The answer is No. If you messed with the air in terms of temperature and solidity to make your hypothesis possible it wouldn't be air any more. Specifically to counter the density and modulus problems you would have to freeze the air to zero Kelvin. At which point it wouldn't be air, but pretty much neutronium on it's way to becoming a black hole. Then it would work per the previous poster. Then it would blow up in your face and take a good chunk of the solar system with it per Stephen Hawking.
~sigh~ So many ideas. So few solar systems worth blowing up...
one more thing i know now is that the velocity of sound does not linearly vary with medium. can anybody tell me how does it vary?
to jeff reid's ans it varies both with temp and density.
Jeff Reid said:
Speed of sound in air, not an ideal gas:
Doesn't matter...
This calculation is usually accurate enough, but for great precision one must examine the more general relationship for sound speed in gases.
Source: http://hyperphysics.phy-astr.gsu.edu/hbase/sound/souspe.html
...In a real material, the stiffness of the springs is called the elastic modulus, and the mass corresponds to the density. All other things being equal, sound will travel more slowly in denser materials, and faster in stiffer ones. For instance, sound will travel faster in iron than uranium, and faster in hydrogen than nitrogen, due to the lower density of the first material of each set...
Source: http://en.wikipedia.org/wiki/Speed_of_sound
I do agree with you that the overall effect of the density as it relates to the speed of sound in air is negligible. However, it technically should be considered from a theoretical stand point.
in a solid medium sound is tranferred br the vibrtaion of the atoms .more denser the substance more quickly the will tranfer energy from one part to another.
all the links that you have given relate velocity of sound in air, or ideal gases .but which exactly relates with density?
Take water and air for example. The speed of sound is faster in water than in air because the particles responsible for transmitting the sound energy from point to point is closer to each other. Therefore it's partially correct to say that increasing density of a material will increase the speed of sound, but difficult to attain speed of light because you have to consider the type of particles involved. Even if you use the smallest atomic particle, it still has a certain limit to be compressed in order to conduct sound energy at speed of light. Exclusion principle from Chemistry states that no two electron occupies the same quantum state, meaning there is always a difference in position. In short, the speed of sound only tends to speed of light when density increases. Similarly, increasing temperature has the same effect as the abovementioned.
1. What is the difference between the speed of sound and the speed of light?
The speed of sound is the rate at which sound waves travel through a medium, such as air or water. It is approximately 343 meters per second in air at room temperature. The speed of light, on the other hand, is the fastest possible speed at which energy can travel, and it is approximately 299,792,458 meters per second in a vacuum.
2. Why is the speed of light faster than the speed of sound?
The speed of light is faster than the speed of sound because light is made up of electromagnetic waves, which can travel through a vacuum. Sound, on the other hand, is a mechanical wave that requires a medium to travel through. Since there are fewer obstacles in a vacuum, light can travel faster than sound.
3. Is it possible for the speed of sound to be faster than the speed of light?
No, it is not possible for the speed of sound to be faster than the speed of light. As mentioned before, the speed of light is the maximum speed at which energy can travel, and it is impossible for any object or wave to exceed this speed.
4. How do scientists measure the speed of sound and light?
The speed of sound can be measured by using an apparatus that detects the time it takes for a sound wave to travel a known distance. The speed of light is typically measured using a laser beam and precise timing equipment to measure the time it takes for the light to travel a certain distance.
5. Can the speed of sound and light change?
Yes, the speed of sound and light can change depending on the medium through which they are traveling. For example, sound travels at a slower speed in water than in air, and light travels at a slower speed in water than in a vacuum. Additionally, the speed of light may change in extreme conditions, such as near a black hole, but it will always remain the fastest possible speed in the universe.
  • Classical Physics
  • Classical Physics
  • Classical Physics
