Can Water Reach 101°C @ 1 Atmosphere?
  • Thread starter Thread starter Mark617
    Atmosphere Water
Heating water to 101°C at 1 atmosphere is theoretically possible under specific conditions, such as superheating in a smooth container where no nucleation sites exist for boiling. While pure water typically boils at 100°C, impurities can alter the boiling point, creating a range rather than a fixed temperature. This phenomenon allows for the possibility of water remaining liquid above its normal boiling point, especially in controlled environments like a microwave. However, caution is advised, as superheating can lead to explosive boiling when disturbed. Ultimately, while it challenges conventional understanding, it is feasible under certain circumstances.
Mark617
To heat water to 101 degrees C at 1 atmosphere?
Is there any case when this is possible? Even off the wall lab stuff will suffice.
What if water isn't completely pure, like most tap water here in the states? My teacher says it isn't possible but any caveat to prove him wrong would be great!
Thank you
Im assuming you mean heat water to 101 degrees and it still remain a liquid?
Also the idea of boiling point, isn't strictly true. Things have a boiling range due to an energy distribution, even pure water with no contaminents doesn't instantly go form not boiling at 99 to boiling at 100degrees C. It's more correct to thing of it as a boiling range. Contaminents will also play a factor. However! These are very anal and pedantic points to make.
Now, don't go and rub it in your teachers face becuase nobody like a smart ***. But you can superheat liquid water in a microwave. If the container is smooth enough there is nothing to trigger the 'boiling'.
You guys are my heroes.
Thanks a lot.
Edit - Yes, I meant heat it to 101 degrees C at 1 atm and still have it remain a liquid :)
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
