Does Lenz's Law Apply When Inserting an Iron Rod in a Solenoid?
In summary: So in summary, when an iron rod is suddenly inserted into a long solenoid connected to a constant current source, the self inductance of the solenoid increases by a factor of 'n', causing a temporary decrease in the magnetic field due to the solenoid. However, the presence of the iron rod, with its high relative permeability, permanently increases the overall magnetic field. This is in accordance with Lenz's law, as any induced mmf/emf opposes the cause of the change.
i_island0
123
1. suppose a long solenoid is connected to a DC source and after a long time steady state has reached. And suddenly an iron rod is inserted in the solenoid along its axis. Obviously, self inductance of the solenoid will increase by some factor. [One can assume some resistance of of the solenoid if required].
MY question is:
(a) what happens to the magnetic field at the center of the solenoid.
(b) what happens to the magnetic flux through an infinitesimally small area at the center of solenoid.
My answer to them are:
1(a) magnetic field reduces - as current will reduce.
1(b) flux doesn't change. - as lenz's law says that induced emf is such that it opposes the cause. so flux shouldn't change.
2. suppose a long solenoid is connected to a constant current source and after a long time steady state has reached. And suddenly an iron rod is inserted in the solenoid along its axis. Obviously, self inductance of the solenoid will increase by some factor. [One can assume some resistance of of the solenoid if required].
MY question is:
2(a) magnetic field reduces - as current will reduce. [but how can current reduce if we are using a constant current source across an inductor (i am confused here)].
2(b) flux doesn't change. - as lenz's law says that induced emf is such that it opposes the cause. so flux shouldn't change.
Can some one comment of both the answers and correction please if i am saying something wrong.
H won't change much, but B will increase greatly. Since iron has a relative permeability much greater than air, and B = mu*H, and H is determined by the amp-turns divided by the integral magnetic path length, B will increase very much. Any e/m fields reference text will affirm this. I hope I've helped. BR.
Claude
i am little confused as I thought that if the solenoid is connected to a battery; finally when the steady state is reached, then the current through the solenoid will be i = V/R.
Now, when we insert the iron rod, flux through the solenoid will not change immediately, while the inductance will increase by some factor 'n'.
And flux = L i. L: inductance i: steady current
Thus, L i = nL*i' Therefore, i' = i/n
Thus, just after inserting the solenoid, the current reduces, and so the magnetic field due to the solenoid reduces as well.
Once again, after a long time the current through the solenoid will again become V/R.
Now, due to the current the iron rod gets magnetized permanently. And the magnetic field due to iron rod is much higher than the magnetic field due to the solenoid.
Thus, the total magnetic field increases to a high value.
My final point is:
a) magnetic field due to the current in the solenoid will reduce initially and come back to the same value finally.
b) magnetic field due to the iron rod will remain permanently, and thus the overall affect will be that the magnetic field will increase.
Am i going wrong somewhere in my concepts? Please help.
But you keep saying "magnetic field"? Are you referring to "B", the magnetic flux density, "phi" the total flux (phi = A*B)), or "H", the magnetic field intensity. The steady state current is related directly to H. The I and H before and after are equal after transients have been dissipated.
When you insert the iron rod, you are doing work, as you will feel a force. Your force integrated over the distance equals the work done. The B will increase due to the high mu of the iron rod. Thus the total energy before is B*H/2, or mu0*(H^2)/2. The total energy after is mu0*mur*(H^2)/2, where mu0 is the free space permeability and mur is the relative permeability of the iron rod.
The energy after is much greater than before due to the work done inserting the rod. Lenz' law is not violated at all. When the rod is moving through the H/B field, any induced mmf/emf is oriented oppositely. The momentary decrease in current is due to the increase in volt seconds. Since the power source was specified as a constant voltage type (battery), any increase in the inductance voltage drop results in a decrease in voltage across the winding resistance, hence a momentary decrease in current.
I believe these types of problems are solved as examples in classic physics texts such as Halliday-Resnick and other similar texts. Does this help? BR.
yes surely.. this helped me a lot. ... and yes i was actually reading halliday resnick and so i was little confused abt this point..
moreover i was not using proper notations so my question went a bit confusing...
i was looking for the net magnetic field just after inserting the iron rod.. and of course it would reduce. But with time it will rise to a very high value.
Related to Does Lenz's Law Apply When Inserting an Iron Rod in a Solenoid?
1. Does Lenz's Law apply when inserting an iron rod in a solenoid?
Yes, Lenz's Law states that when a change in magnetic flux occurs in a closed circuit, an electromotive force (EMF) is induced in the circuit that opposes the change in magnetic flux. This applies to any change in magnetic flux, including the insertion of an iron rod in a solenoid.
2. What is Lenz's Law?
Lenz's Law is a fundamental law of electromagnetism that states that when a change in magnetic flux occurs in a closed circuit, an EMF is induced in the circuit that opposes the change in magnetic flux.
3. Why does Lenz's Law apply when inserting an iron rod in a solenoid?
Lenz's Law applies when inserting an iron rod in a solenoid because the change in magnetic flux caused by the insertion of the rod creates an induced EMF that opposes the change in flux. This is due to the movement of the iron rod, which creates a changing magnetic field that induces an opposing current in the solenoid.
4. What is a solenoid?
A solenoid is a coil of wire that is used to create a magnetic field when an electric current is passed through it. They are commonly used in electromagnets, motors, and other electrical devices.
5. How does Lenz's Law affect the functioning of a solenoid?
Lenz's Law affects the functioning of a solenoid by creating an opposing EMF when there is a change in magnetic flux. This can be seen when an iron rod is inserted in the solenoid, as the induced EMF will create a current that opposes the change in magnetic flux, thereby reducing the strength of the magnetic field created by the solenoid.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
