Is multiplication associative in physics?
The discussion centers on the properties of multiplication in physics, specifically addressing whether multiplication is associative or commutative. It clarifies that while scalar multiplication is both associative and commutative, vector operations like the cross product are not commutative, and matrix multiplication can also lack commutativity. The concept of work, defined as W = Force X Distance, is highlighted to illustrate commutativity in scalar products. The conversation emphasizes that the mathematical rules applied in physics remain consistent across different contexts. Overall, the distinction between commutative and associative properties is crucial in understanding various mathematical operations used in physics.
oahz
Work = Force X Distance.
? = Distance X Force
How do you make sense of the second equation?
For a little displacement ##\vec{dl},## the work the force ##\vec{F}## does is ##\vec{F}\cdot\vec{dl},## which is identical to ##\vec{dl}\cdot\vec{F},## for the commutativity of the vector's scalar product.
But it doesn't happen everywhere in physics. For example, the non-commutativity of matrices finally implies the uncertainty principle.
Edited for getting uncleared at the same time.
1) You're asking about the commutativity property, not associativity, which is ## (a \times b)\times c=a \times (b\times c)##.
2) The multiplication defined for real numbers is commutative, doesn't matter in what field of science you're considering it. But the more general definition of work is through ## W= \vec F \cdot \vec D ##. So we should talk about the inner product defined on vectors. That is commutative too and again it doesn't matter in what field of science you're considering it.
Do you mean commutative? (Associative -> a+(b+c) = (a+b)+c, commutative a*b=b*a). https://en.wikipedia.org/wiki/Commutative_property
And physics is associative/commutative when the mathematics you are using is. The rules don't change when you're doing physics. If you multiply scalars, it is associative and commutative. If you are multiplying matrices, it is not commutative in general.
Yes, I mean commutative.
Then the answer is yes and no.
A cross product is not commutative. A dot product is.
A vector product is not commutative. A scalar product is.
And the multiplication of operators need not be commutative.
This should be in Math, not Physics.
Zz.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
