A Is MWI Considered Local in Quantum Mechanics?
  • A
  • Thread starter Thread starter DrChinese
  • #152
Moderator's note: If there is interest in further discussion of the Branching Space-Time model, it probably needs to be treated as a separate interpretation from the MWI and be spun off into its own thread.
  • #153
PeterDonis said:
I have found a review of the "Branching Space-Times" book online here:
https://ndpr.nd.edu/reviews/branching-space-times-theory-and-applications/
From the review, it looks like a sort of mixture of consistent histories and the MWI. Unfortunately, the review does not describe any actual math in the book (although the description of some chapters suggests that there might be some).
Decoherent histories formalism is leveraged heavily by Wallace's camp. Specifically, they are interested in the development of the universal wavefunction wrt decoherence bases. (Though they still identify as Everettians as they believe all histories in a set with nonzero weights occur. DH proponents believe only one history in a set occurs). And projectors in sets of decoherent histories mark out causal structures that branching spacetime maths can be applied to.
  • #154
Hm, ok, so it is kind of a mixture. Interesting.
  • #155
DrChinese said:
1) The issue we have with this centers around the usage of the word "causal". As you use the word, there is no causal action at a distance (AAD) possible - and I agree with that usage of the word "causal". This definition is perfectly fine, and I agree that AAD that involves doing something at one spot cannot deterministically ("causally") affect something at a far away location (i.e. outside the relevant light cone).
But no one in the general physics community is saying otherwise! What is being asserted is that there is a kind of AAD - called "quantum nonlocality" or just "nonlocality" in which indeterministic (random) effects propagate superluminally. I won't quote experiments, but simply quote the 2022 Nobel committee: "...[Zeilinger's] research group has demonstrated a phenomenon called quantum teleportation, which makes it possible to move a quantum state from one particle to one at a distance [i.e. outside a light cone]."
But that's misleading. There is no action at a distance nor acausal influences in contemporary relativistic QFT by construction. The Nobel committee's formulation is of course inaccurate.
DrChinese said:
So if you define such indeterministic AAD to violate "Einsteinian causality" (as I do), fine. If you choose to say it violates something else (so you can maintain "Einsteinian causality"), that's fine - use whatever term you like for what is being violated by experimentally demonstrated indeterministic AAD.
To the contrary, I say you cannot violate Einsteinian causality with any experiment that is describable by relativistic local QFT, and Zeilinger's teleportation is perfectly in agreement with standard QED!
DrChinese said:
2) If you choose to say that entangled particles exhibit correlations stronger than local realism allows, I agree with that. ReplyIf you choose to say that such correlations can occur without long distance entanglement, I would disagree strongly.
"Long-distance entanglement" of course can occur and is observed with all these experiments we discuss here. It's, however, a correlation due to the preparation procedure and not caused by mutual local measurements on each other that violate Einstein locality.
DrChinese said:
The most common viewpoint for entanglement of 2 photons is that they DO have spatiotemporal extent. And in fact such a system is defined as one biphoton. (Which violates conventional locality by definition.)
Of course, the electromagnetic field is a field, i.e., a quantity that is defined on each point in Minkowski space. A photon has not even a position observable and thus it doesn't make sense to say it's a localize "pointlike" object.
DrChinese said:
3) We have already well settled the fact that there are no subensembles of (1&2)x(3&4) in which 1&4 share any entanglement (or correlations) whatsoever. From our swapping example: "We confirm successful entanglement swapping by testing the entanglement of the previously uncorrelated photons 1 and 4." But sure, go ahead and ignore the results of Nobel winning experiments.
But the results of these Nobel-winning experiments precisely are that you can select (even post-select) sub-ensembles where 1&4 are entangled, namely by projecting based on a local measurement on the pair 2&4. As I said many times before, that's just a more sophisticated realization of a teleportation protocol. Read Zeilinger's original papers (around 1997 or so), where this is make very clear.
  • #156
Only if you include the BSM in the "preparation procedure".
And teleportation has all of the same issues, which you can't just handwave away by saying that QFT satisfies your preferred definition of the term "locality". We have had this discussion before. You can't dictate physics by fiat by defining words.
Also please bear in mind the fact, which I have already pointed out in an earlier post, that this is the interpretations forum and disagreements about QM interpretations are ultimately not resolvable. The best that can be done is for all sides to state their positions and give whatever references they can. We're pretty much at that point in this thread.
  • #157
vanhees71 said:
1. The Nobel committee's formulation is of course inaccurate.
2. "Long-distance entanglement" of course can occur and is observed with all these experiments we discuss here. It's, however, a correlation due to the preparation procedure and not caused by mutual local measurements on each other that violate Einstein locality.
3. But the results of these Nobel-winning experiments precisely are that you can select (even post-select) sub-ensembles where 1&4 are entangled, namely by projecting based on a local[sic this is nonlocal] measurement on the pair 2&4[sic - I'm sure 2& 3 are intended]. As I said many times before, that's just a more sophisticated realization of a teleportation protocol. Read Zeilinger's original papers (around 1997 or so), where this is make very clear.
1. I think your viewpoint speaks for itself here. As I mention, yours is NOT mainstream science - while that of the Nobel committee is mainstream almost by definition. I would even call them slow and deliberate, considering that Bell died before he could be recognized properly by them.
2. The swapping preparation procedure is nonlocal, and you say that in your 3 (whether you meant to or not). The BSM on 2&3 is performed far from the 1 & 4 photons, and can of course even be performed after they are detected with no change of statistics.
3. Yes, swapping and teleportation use the same underlying technique. I use swapping experiments because they allow one to see the underlying nonlocality with more clarity.
Really, nothing you are saying here has anything to do with this thread. No point in us belaboring these points here yet again.
  • #158
Since when is standard relativistic QFT not "mainstream science"?
It's entirely local. The projection is done by a local measurement on photons 2 & 3. The correlations ensuring that then for the so prepared subensemble also photon 1&4 are entangled is due to the initial preparation of the four-photon state. That's mainstream science.
There is no nonlocality, i.e., no violation of Einstein causality. It's inseparability that's described by entanglement of this kind! That may be not "main-stream terminology" but it's main-stream physics!
  • #159
@vanhees71, we have had the discussion about terminology too many times. Enough is enough. I have now banned you from further posting in this thread.
Likes weirdoguy and Motore
  • #160
For the record, this has been addressed multiple times already in this thread: the operations you describe are local, but the wave function is not.
  • #161
PeterDonis said:
Following up post #79, here is how the MWI describes the version of the entanglement swapping experiment I gave the math for there, where photon 1 is measured before the swap/no swap operation. (I will also consider below the version where both photons are measured before the swap/no swap operation.)
(I should note once again that in post #79 and here, I have switched the entangled states I am talking about so that they are the singlet state, i.e., ##HV - VH##, since that is the one that seems to be used most often in these experiments.)
1. The branching for the photon 1 measurement is of course simple: we end up with two worlds, one in which photon 1 is H (and photon 4 is V), the other with photon 1 V (and photon 4 H).
2.
Now we look at the swap operation. (The no swap operation, as noted already, is just the identity, which does not induce any branching.) I said in an earlier post that the only branching induced by the swap/no swap decision is "swap" vs. "no swap"; that means that the state I wrote in post #79 as ##U_S \Psi_{1A}##, i.e., the state in the "swap" branch, should not have any further branching. And indeed it doesn't: we still have just two branches, corresponding to the two branches induced by the photon 1 measurement as described above. All that has happened is that the photon 2 and 3 degrees of freedom have undergone the unitary operation described for ##U_S## in post #79.
3. The final branching is now the photon 4 measurement, which, as we can see from post #79, also produces no further branching in the "swap" branch. In other words, the two "worlds" in the "swap" branch already have the correct photon 4 states for the expected entanglement with photon 1, and no others. So once again, the wave function enforces the correlations, just as the MWI says.
We could do a similar analysis for the case where photon 4 is measured, then the swap/no swap decision occurs, then photon 1 is measured. The result would be the same. So, to summarize, we have analyzed three cases of time ordering, with results as follows:
Case 1: swap/no swap, then photon 1 & 4 measured: "swap" and "no swap" branches, then two further branches in the "swap" branch (since 1 & 4 are entangled so only the correlated results have amplitudes), and four further branches in the "no swap" branch (since 1 & 4 are uncorrelated in this branch so all four possible combinations have amplitudes).
Case 2/3: measure 1 (or 4), then swap/no swap, then measure 4 (or 1): two branches at the first measurement, then each branch gets two further branches ("swap" and "no swap"), then no further branching in the "swap" branch (since the swap operation has rotated the photon 2 & 3 branches in just the right way to enforce the right correlations between photons 1 & 4). We haven't explicitly analyzed the "no swap" branch for this case, but the result is that we get a further two-branch split so that there are four final branches that have "no swap" results. And, since everything commutes, the two "swap" branches are the same (in terms of their wave functions) as the two "swap" branches in Case 1 above, and the four "no swap" branches are the same as the four "no swap" branches in Case 1 above. The order of the branching is different, but the final resulting branches are the same.
That leaves one more case:
Case 4: measure both 1 and 4, then swap/no swap. Here we get four total branches from the two measurements. The "no swap" branch induced by the swap/no swap decision is now trivial: it's the same four branches that are the final result in the "no swap" cases above. (The "no swap" operation is just the identity, as noted above, so this should come as no surprise.) But what about the "swap" branch?
Let's look again at the math: we apply the photon 1 and 4 measurement operators (which just put bars over those photon kets) to the state ##\Psi_0##. What do we get? We get this:
M_1 M_4 \Psi_0 = \bar{H}_1 V_2 H_3 \bar{V}_4 - \bar{V}_1 H_2 H_3 \bar{V}_4 - \bar{H}_1 V_2 V_3 \bar{H}_4 + \bar{V}_1 H_2 V_3 \bar{H}_4
If we then apply ##U_S## to this, we see something that might seem strange: the middle two terms in the above, the ones where the photon 2 & 3 kets are the same, get annihilated. (##U_S## applied to those combinations of photon 2 & 3 states gives zero, as shown in post #79.) What does this mean?
What it means is that, in those branches of the wave function ##M_1 M_4 \Psi_0##, i.e., for "worlds" in which the photon 1 & 4 measurement results are already recorded to be inconsistent with entanglement, the swap operation cannot take place.
This is addressing your post #81:
1. I assume you mean photons 1 & 2 - and not 1 & 4. At the time of the measurement of photon 1, there is no association of the 1 & 2 system with any other system in the universe. In fact, there is no requirement 3 & 4 yet even exist.
2. The branching between your swap and no swap is both partially accurate and excessively over-simplified at the same time. I'll explain.
If a swap occurs, it is only because the 2 and 3 photons were indistinguishable. If no swap occurs, it is only because the 2 and 3 photons were distinguishable. Indistinguishability is a physical requirement if MWI is to give us the same experimental results as predicted by QM. (And note that we are assuming there are to be relative coincident clicks within the specified time window for Photons 1 & 4 in all cases we consider.) Do you see the problem here? Nothing happening is in fact a fork of some kind, if we say the other fork is a swap.
3. In the experiment, we are only considering cases of 4 fold coincidences. That's true, swap or no swap. So assuming the no swap case is creating by delaying Photon 3 by 30 ns and the window is 13 ns wide, we end up with something like a. and b. below. Note that the times I give are adjusted for path length, except Photon 3's length adjustment does not consider the extra 30 ns delay that may or may not be added by the experimenter.
(Arrival times in ns, where 0 is the first measured.)
a. Successful swap example, all detections within 13 ns window:
Photon 1=0
Photon 2=2
Photon 3=6 (no delay by the experimenter)
Photon 4=3
b. No swap example, one BSM detection is outside the 13 ns window (because the experimenter chose "no swap"):
Photon 1=6
Photon 2=0
Photon 3=32 (a 30 ns delay was performed)
Photon 4=5
Now, all of the detections are made by 8 APD type detectors after each photon passes through 1 of 4 polarizing beam splitters (PBS). There are actually 4 variable orientations for the PBSs, yielding an H> or V> for their direction. (For simplicity's sake, we consider the 2 & 3 permutations in which one of the two identifiable Bell states appear. For our purposes, it really doesn't matter which ones as we assume the experimenter can see this and and will report accordingly. Let's call one a +swap and the other a -swap, where a +swap means 1 & 4 will be correlated and a -swap means 1 & 4 will be anti-correlated. Of course, we can still have Nswap which is the no swap case.) There will always be a click at 2 of the 4 BSM detectors (ideal case of course). And if they are within the time window, there will be a +swap or a -swap. Hopefully, we are in agreement to here.
So here is where we need help from the MWI proponent. The Nswap must mean the 2&3 photons did not swap because they did not overlap sufficiently closely in the beam splitter (BS). The +swap and -swap cases result from suitable overlap followed by polarization measurements on 2 & 3 which indicate which type resulted.
So what we know, IF there is a swap: there were 2 branches created by measurement of photon 1 (H> or V>) and that doubled when the swap was detected as + or -.
Photons 1&2&3:
H>+swap>
H>-swap>
V>+swap>
V>-swap>
Plus a doubling to 8 branches, if we now add photon 4 and measure it at the same angle as photon 1:
Photons 1&2&3&4, branches with a swap:
H>+swap>H>
H>-swap>H> X
V>+swap>H> X
V>-swap>H>
H>+swap>V> X
H>-swap>V>
V>+swap>V>
V>-swap>V> X
But 4 of those 8 cases (marked X) can NEVER occur (ideal case). How can the distant photon 4 "know" which photon 1 outcome it must be matched to? If MWI were local and deterministic, the outcome of the photon 4 measurement is independent of the swap being +swap or -swap. And in fact, the outcome of the photon 4 measurement is independent of the swap not occurring at all (the Nswap case), which happens whenever the experimenter so chooses.
Photons 1&2&3&4, combined swap/no swap branches:
H>+swap>H>
H>-swap>H> X
V>+swap>H> X
V>-swap>H>
H>+swap>V> X
H>-swap>V>
V>+swap>V>
V>-swap>V> X
H>Nswap>H>
H>Nswap>V>
V>Nswap>H>
V>Nswap>V>
Clearly, the correct outcomes for Photon 4 depend mightily on the branching that occurs elsewhere. It's outcome could not have been a result of propagation of a wavefunction change evolving such that it respects c. And saying that the disallowed combinations have a weight of 0 while the allowed combinations have a weighting of 1 doesn't change the question.
  • #162
I was referring to the state after a swap has occurred (if it occurs). Before the swap, I agree that photons 1 & 2 are entangled and there is no relationship between photons 1 & 4.
I agree in general that "nothing happening" can be a decoherent branch.
However, in the case of the swap/no swap, we have distinguishable states of the detectors in the output arms of the BSM, so there is no "nothing happening" option in which no macroscopic change occurs at all. If a swap occurs, one photon is detected in each output arm of the BSM. If no swap occurs, then either there is a detection in only one output arm and not the other, or there is no detection in either output arm. All of these are macroscopically distinguishable changes, since we also have a narrow time window for the detections, if any, to occur.
As for the "no swap" decision by the experimenter creating distinguishability by forcing photons 2 & 3 to arrive at sufficiently different times at the BSM, I agree that that is being done, and it is included in what I was calling the "BSM" or "swap/no swap decision" operator. You can of course make a finer-grained time-based analysis of what is going on there, but it doesn't change anything about the MWI description I gave.
Yes. That was the basis of my analysis.
The only real change you are introducing here is that in the "no swap" case, you are allowing either the photon 1 or the photon 4 detection to be between the photon 2 and photon 3 detections. My MWI analysis did not specifically include that case. However, since this can only occur in the "no swap" branch, it actually doesn't affect the MWI description, because in the "no swap" case the unitary operator on the photon 2 & 3 states is just the identity, so it doesn't matter at what point in time we apply it; it doesn't change the wave function at all!
The rest of your description is hard for me to follow (in fact it is almost unreadable because of formatting). But I have already thoroughly described the actual branching process in previous posts. If you think my description is wrong (I'm not sure you actually do--see comments at the end of this post about "nonlocal"), I would much rather that you either quote specific statements from those posts that you either disagree with or cannot understand, or at the very least adopt the same notation (and use LaTeX for it) that I did in my posts, to describe what you think the branching is, if it's not the same as what I said in my posts.
That said, I can comment on a few things:
Yes, that's the point!
Because the other possibilities are eliminated as never occurring--see above. (But note that I am not claiming that this process, in its entirety, is local--see below.)
Please note that I have not claimed that the MWI is "local and deterministic". In fact, as I have posted previously, I think that while the unitary operators involved are local (they only operate on degrees of freedom at their spatial location--for example, the BSM only operates on the photon 2 & 3 degrees of freedom), the wave function is not local (because it includes entangled degrees of freedom that are spatially separated). And since the unitary operators operate on the wave function, we have "local" plus "nonlocal" gives "nonlocal". So based on that I would say that the MWI is nonlocal and deterministic. Maybe that is a sufficient answer to the original question of this thread.
Likes mattt, vanhees71 and DrChinese
  • #163
PeterDonis said:
1. I was referring to the state after a swap has occurred (if it occurs). Before the swap, I agree that photons 1 & 2 are entangled and there is no relationship between photons 1 & 4.
2. However, in the case of the swap/no swap, we have distinguishable states of the detectors in the output arms of the BSM, so there is no "nothing happening" option in which no macroscopic change occurs at all. If a swap occurs, one photon is detected in each output arm of the BSM. If no swap occurs, then either there is a detection in only one output arm and not the other, or there is no detection in either output arm. All of these are macroscopically distinguishable changes, since we also have a narrow time window for the detections, if any, to occur.
3. Yes. That was the basis of my analysis.
4. The rest of your description is hard for me to follow (in fact it is almost unreadable because of formatting). ... I would much rather that you either quote specific statements from those posts that you either disagree with or cannot understand, or at the very least adopt the same notation (and use LaTeX for it) that I did in my posts, to describe what you think the branching is, if it's not the same as what I said in my posts.
5. Yes, that's the point!
Because the other possibilities are eliminated as never occurring--see above. (But note that I am not claiming that this process, in its entirety, is local--see below.)6. Please note that I have not claimed that the MWI is "local and deterministic". In fact, as I have posted previously, I think that while the unitary operators involved are local (they only operate on degrees of freedom at their spatial location--for example, the BSM only operates on the photon 2 & 3 degrees of freedom), the wave function is not local (because it includes entangled degrees of freedom that are spatially separated). And since the unitary operators operate on the wave function, we have "local" plus "nonlocal" gives "nonlocal".
7. So based on that I would say that the MWI is nonlocal and deterministic. Maybe that is a sufficient answer to the original question of this thread.
1. Fine.2. We are in agreement about the 2 & 3 detector clicks.
But there is one little stone left unturned. Indistinguishability is an absolute requirement of a swap. It is, by definition, not reversible (else there would be distinguishability remaining in at least one degree of freedom). Any irreversible process must lead to branching, right? And must be a physical process as well, wouldn't you agree (if it is in fact irreversible)? And this irreversible process can't itself depend on subsequent detector clicks... as those clicks just inform us whether we ended up with |ψ+| or |ψ-| (when 2 nearly simultaneous clicks occur at the BSM).
The detector clicks can occur as much later than the "indistinguishability event" occurs as we would like. The path length from the BS to the PBS can be any length, and the additional path length from the PBS to the detector can be any length. But the event itself must occur at the BS.
[Keep in mind that this process of indistinguishability is mysterious to me. I have never seen a good explanation of this in any paper or interpretation - I just know how the "theoretical" rule is applied in experiments. And I believe it is clearly a physical process (not an update of knowledge or a filtering process) - else inserting a delay (to distinguish photon 2 from photon 3) shouldn't matter. But this is the stuff for another thread...]3. All good.4. Sorry, I thought my presentation would be clear enough. |ψ+| is the same as +swap, |ψ-| is the same as -swap for photons 2&3.
I don't think it is really any different than yours, the difference is that I am trying to differentiate the branching according to a specific time line (and of course I realize that order shouldn't matter, but that is the point we are examining since MWI claims a deterministic description in which order might matter). The first when Photon 1 is measured, the second as Photons 2 & 3 are measured, and the last as Photon 4 is measured.
a. We started with a product state of 2 entangled states:
|12ψ->|34ψ->
b. After measurement of photon 1, we have 2 branches:
|1H2V>|34ψ->
|1V2H>|34ψ->
c. After measurement of photons 2&3, we have 4 branches (ignoring Bell states that can't be identified) that can occur and 4 that cannot:
|1H>|23ψ-|4V>
|1H>|23ψ+|4H>
|1V>|23ψ-|4H>
|1V>|23ψ+|4V>
|1H>|23ψ-|4H> X
|1H>|23ψ+|4V> X
|1V>|23ψ-|4V> X
|1V>|23ψ+|4H> X
d. Note that the counterfactual 4> cases are presented, I realize that an MWI proponent would deny these exist. You could just say:
|1H>|23ψ-|4>
|1H>|23ψ+|4>
|1V>|23ψ-|4>
|1V>|23ψ+|4>
e. But what we needed is this result after the swap:
|14ψ->|23ψ->
|14ψ+>|23ψ+>
f. If you don't want to comment on these, that's fine. You've invested a lot of time already. :smile:5. I know, hence the Xs. But there is no actual explanation of how "conflicting" states - the ones with Xs - are suppressed. After all, they are measured in separate places too far apart for any updating to be connected in a manner consistent with locality.6. Agreed.7. Probably sufficiently so in terms of this thread.
Locality in MWI:
No one has put up an argument that MWI is local, other than a few quoted claims of a few MWI proponents - who themselves don't seem to agree fully. By any reasonable analysis (of course represented in this thread LOL), MWI is as nonlocal as standard interpretations of QM. And certainly no less so.
Determinism in MWI:
a. And when we say MWI is deterministic: we simply mean every branch occurs - and which one we are in (consciously) is random.
b. And when we say MWI is deterministic: we also mean that it is NOT possible to trace back in time what branching occurred (or when or where); and we cannot select any particular prior branch as being a branch which gave "birth" to the one we are in.
c. And finally, when we say MWI is deterministic: we also mean that there is no way even in principle to predict what future branch we will occupy at any future date. Which is exactly the same as in every indeterministic interpretation of QM.
d. Moreover: Anything is possible, in fact every outcome is possible. In fact: not only is everything possible, everything WILL occur.
I guess ol' LaPlace's Demon wouldn't much recognize this "deterministic" universe. :smile:
  • #164
I'm not sure what you mean. "Indistinguishability" by itself is not an operation, it's a precondition for an operation. The actual operation, namely the unitary operator I called ##U_{S}##, is reversible--all unitary operators are. In this particular case, as I think I commented in a previous post, since the "swap" case involves one photon in each output arm of the BSM, just put in a mirror and a second beam splitter so you have a Mach-Zehnder interferometer for photons 2 & 3, and after the second beam splitter, the swap is reversed.
What makes the swap irreversible is the detection of one photon in each output arm of the BSM. But that means you have put detectors there instead of mirrors and a second beam splitter. You can't do both.
I did that already for every case I covered. As I said before, the only change you appear to be introducing is to capture the timing of the arrival of photons 2 & 3 at the BSM, in order to evaluate the indistinguishability criterion, separately from the operation of the BSM itself. But there is no measurement of the arrival times of photons 2 & 3 at the BSM, so there is no branching due to that. The only branching is due to the detection of photons (or not) in the output arms of the BSM. For my analysis, I separated out just one of the possible outcomes of that detection, namely "one photon detected in each output arm of the BSM", and called that the "swap" outcome; the other three possible outcomes, namely "photons only detected in output arm A", "photons only detected in output arm B", and "no photons detected in either output arm", were all included in the "no swap" outcome, because, as I said, they all correspond to the same operator on the photon 2 & 3 degrees of freedom, namely "nothing" (the identity). One could of course separate out the "no swap" outcomes further, but I didn't see the point for this analysis.
I don't understand this. I explicitly showed in the math exactly how this happens. You even reproduce the same math in your post, where you recognize that the "X" outcomes are ones that are eliminated in the wave function because they have zero amplitude. That is the explanation. What more do you want?
I agree. And as I said, I do not think it is, due to the nonlocal nature of the wave function.
Yes.
No. In so far as "consciousness" comes into play at all, it would have to be there in every branch. There is nothing in the wave function that would pick out any particular branch; there is no "random" element anywhere to make any such choice.
In other words, if I were to observe the result of one of the photon detections in this experiment, there would be two branches of my consciousness, just like there would be two branches of everything else, an "H" branch and a "V" branch. My consciousness, as far as the MWI is concerned, must be emergent from the wave function (though of course nobody has any real idea how), so there must be degrees of freedom in the wave function that underlie my consciousness, and those degrees of freedom are entangled with the detector ones so that the result I am conscious of is the result that is registered by the detector, in each branch.
In principle it is, because branching is unitary (all time evolution in the MWI is unitary). Whether it can be done in practice depends on what information is available to you. If you run an experiment that measures the time at which a particular detector gave its reading, and the reading is stored in a stable manner, then that information is sufficient to trace back in time what branching occurred.
Yes, we can, if we have the necessary information. See above. The same information that tells you when a branching occurred also tells you what prior branch was the "parent" of all the branches produced at that branching.
No. "What future branch we will occupy" is not a well posed concept. "We" occupy all branches. See above.
Every outcome with a nonzero amplitude in the wave function is possible. Many MWI discussions are very cavalier about that qualifier, but it's crucial. You can't just wave your hands and assert that anything is "possible" in the MWI with no supporting argument. You have to actually do the work of showing how the wave function includes the possibility.
Likes vanhees71, Motore and mattt
  • #165
I think you have some misunderstandings about how the MWI actually works. See my previous post.
Likes vanhees71 and Motore
  • #166
@DrChinese, the Many Worlds Interpretation has other problems (for example, the existence of conscious humans, in other branches, where they observe that the relative frequencies of the results of certain quantum experiments do not satisfy what we in this "our branch" call the Born rule), but it is of course completely deterministic.
What it changes is the ontology, "what there is" ("what the Universe itself is"), but given that its dynamics is entirely defined as a PDE, it is of course deterministic.
Most people don't like that it posits an ontology in which the versions of conscious beings in each branch can never "prove" the existence of the other branches.
But well, every interpretation of quantum mechanics has its own shortcomings...
It is nonetheless fun to dive in each of them, to see how the same mathematical structure can be dressed in so many different narratives.
  • #167
DrChinese said:
c. And finally, when we say MWI is deterministic we also mean that there is no way even in principle to predict what future branch we will occupy at any future date
Determinism is not the same that predictability, chaos theory is deterministic but unpredictable.
  • #168
physika said:
Determinism is not the same that predictability, chaos theory is deterministic but unpredictable.....
Chaos theory relies on nonlinear dynamics. The unitary dynamics of QM is linear.
  • #169
Well, there are proponents who conclude that the Born rule arises more naturally in MWI than other interpretations using the Principle of indifference -> see attachment (not a peer review article).
  • #170
I know how they try to recover The Born Rule in Many Worlds Interpretation, but that's not what I was trying to point out.
According to Many Words Interpretation, there will be conscious humans (there will be branches) that, in a quantum coin experiment (which according to what we, in this "our branch" call "The Born Rule", have a 0.5 probability of H and 0.5 probability of T) will observe 1,000.000 consecutives Heads (for example).
There will exist all kinds of "anomalous" branches (for example branches in which EVERY quantum coin experiment will give a million consecutive heads).
Of course the conscious humans in those anomalous branches will never develop a theory like "our" mathematical quantum mechanics with "our" Born Rule ("our" I mean the branch in which you and me are, where "our" Born Rule is actually satisfied in "our" quantum experiments), because "our" Born Rule and in fact "our" mathematical Quantum Mechanics does not describe correctly the results of their quantum experiments.
I was just trying to emphasize in my previous post that to many people, an interpretation that postulates the existence of so many "impossible to prove" strange things (that we will never observe in this our branch) is maybe too much.
  • #171
  • Haha
Likes gentzen and mattt
  • #172
And would conclude (if all other quantum measurements confirm QM and the coin is fair) that MWI is the correct interpretation :)
https://en.wikipedia.org/wiki/Quantum_suicide_and_immortality
Ok, we are veering of topic, so I will stop it here.
  • #173
But that's the problem. There is an infinite number of different ways in which a set of experimental results (no matter how large the number of repetitions, or how varied the quantum experiments themselves) will not be correctly described by our Born rule, and yet for each of those strange set of experimental results, there will be a branch with exactly those experimental results.
I know this is off topic here (and we could start a new thread called: "is it reasonable to expect that in each and every branch with human beings, they all will infer that "our" mathematical quantum mechanics with " "our" Born rule is the correct description of the Universe?"), but I guess that they will not.
For example, there will be branches in which the relative frequencies of the possible results of any quantum experiment will not approximate any concrete limit (as they make more and more repetitions). In those branches there are no regularities, not even probabilistic.
  • #174
Yes, please start a new thread if you want to discuss that aspect of the MWI. It is a separate issue from the question under discussion in this thread, of whether or in what ways the MWI is local.
  • #175
1. I would love to see a reference for this experimental realization, because I don't think indistinguishability is reversible (by definition, else there is a distinguishable degree of freedom remaining). I have never seen any hint of this in the literature, but of course that alone means nothing.
Your idea, as I understand it: You place 2 mirrors in place of 2 PBSs, then recombine them at a new (second) BS. Are you saying they will then always emerge from that second BS in different directions, and they can therefore always be identified as to their source? I think your idea is that normally, constructive/destructive interference causes a photon to emerge from a single port of the second BS.
But I don't think entangled photons - at least in this case - will act the same as they would if they were not entangled. And of course, the entanglement is 1&2 and 3&4 until the swap occurs. Since the 1 photon could be used to determine which path information for photon 2, no constructive interference results. This isn't the greatest paper, but I think it shows the essential difficulty.
Two-Photon Interference Experiment in a Mach-Zehnder
https://opg.optica.org/directpdfacc...sk-7-2-113.pdf?da=1&id=194686&seq=0&mobile=no2. A technical point in your understanding of the swap variations of the BSM: 50% of the cases involve the 2&3 photons going into separate arms of the BSM, and 50% of the cases involve the 2&3 photons going into the same arms of the BSM. This is of course after the BS and before arriving at the PBS(s). Because only 2 of 4 Bell states can be identified, when the 2&3 photons go to the same arm, they must be polarized oppositely. From the reference:
"On the other hand, a coincidence detection event between either DQ1H and DQ1V or DQ2H and DQ2V indicates a projection on ψ+. [DQ1 is one arm, DQ2 is the other arm.]"
Of course, if there is an identifiable swap: 2 clicks occur at the BSM.
  • #176
I don't know if there is one; I was not referring to an actual experiment but to what seems to me to be an obvious implication of the way the BSM is done.
Again I am unable to make sense of this because indistinguishability isn't an operation. If you disagree, please write down for me the "indistinguishability" operator, the same way I wrote down the "swap" unitary operator. The "swap" operator is obviously reversible, since it's unitary. If you claim there is an "indistinguishability" operator that is not reversible, then write it down and show that it is not unitary and not reversible.
If by "2 PBSs", you mean the PBSs that are used in the detectors in the output arms of the BS that does the swap (so that the H and V photon states can be distinguished), yes, my proposal was to replace those with mirrors that reflect the photons into the input arms of a second BS.
Possibly not; that's why I added the caution in an earlier post that I have not done the math. I see you referenced a paper on a two-photon MZ interference experiment; I'll take a look at that.
The latter case involves a different final Bell state, correct? As I understand it, the first case (one photon in each output arm) indicates the singlet state; that's the one I analyzed. The second case (two photons in the same output arm but with opposite polarizations) indicates a different Bell state, which I didn't analyze. Since the two cases are macroscopically distinguishable, one could update my analysis to include two "swap" results (and two corresponding branches) instead of one. It wouldn't change anything material about the general conclusions, but it would change the details of how many branches there are at the end.
  • #177
PeterDonis said:
1. If you disagree, please write down for me the "indistinguishability" operator, the same way I wrote down the "swap" unitary operator. The "swap" operator is obviously reversible, since it's unitary.
2. Possibly not; that's why I added the caution in an earlier post that I have not done the math. I see you referenced a paper on a two-photon MZ interference experiment; I'll take a look at that.
3. The latter case involves a different final Bell state, correct? As I understand it, the first case (one photon in each output arm) indicates the singlet state; that's the one I analyzed. The second case (two photons in the same output arm but with opposite polarizations) indicates a different Bell state, which I didn't analyze. Since the two cases are macroscopically distinguishable, one could update my analysis to include two "swap" results (and two corresponding branches) instead of one. It wouldn't change anything material about the general conclusions, but it would change the details of how many branches there are at the end.
1. As I said earlier, I can't find enough references on the theory of indistinguishability (other than basic of course) to speak to it well. I will continue to look for something that would help us here.
I again don't see how an entanglement swap is reversible, so please provide a reference for that claim (unitary or not, I am talking specifically about the swap operation). How would you even start? I certainly have never heard of a swap being reversed, any more than you can reverse quantum teleportation.2. This may help: entangled photons do not self-interfere as do unentangled ones. From Zeilinger: See Fig.2. Although this shows an example for entangled double slit interference, I believe the example would apply equally to an MZI.3. Yes, this is fair. And probably why you might not have followed all of my example notation. I was showing both ψ- (what you call singlet) and ψ+.
  • #178
I have already given the caveat that I have not done the math, and it's quite possible that entanglement changes things. When I get a chance I'll look at the two photon MZI reference you gave and see if that has something helpful in it. If not I'll have to try to check the math myself in my copious free time. :wink:
  • Haha
Likes bhobba and DrChinese
  • #179
Do you EVER sleep? :smile:
  • #180
PeterDonis said:
I'm not sure what you mean. "Indistinguishability" by itself is not an operation, it's a precondition for an operation. The actual operation, namely the unitary operator I called US, is reversible--all unitary operators are. In this particular case, as I think I commented in a previous post, since the "swap" case involves one photon in each output arm of the BSM, just put in a mirror and a second beam splitter so you have a Mach-Zehnder interferometer for photons 2 & 3, and after the second beam splitter, the swap is reversed.
OK, I found a better reference to help make my points, which are:
a) Indistinguishability is a requirement for a swap of the type we have been discussing;
b) Indistinguishability is a physical operation (the exact nature of which I cannot say) precisely because it is such a requirement; and
c) Indistinguishability is not reversible (this is pretty much by definition, else the photons are actually distinguishable). This is what I have added a reference to prove in this post.
Now, let's examine your idea that indistinguishability can be reversed in a Mach-Zehnder interferometer (MZI). Your idea is that if the 2 photon is sent into the MZI in one input port, and the 3 photon into the other input port, that according to standard MZI protocol: Each of those photons would emerge from separate ports of the MZI final beam splitter.
If the photons were distinguishable, this would in fact happen. But, it turns out this exact experiment has been performed recently (2022) on indistinguishable photons. And they come out the same port, not different ports. Here is the reference (which has a lot of interesting stuff about Indistinguishable photons:
https://arxiv.org/abs/2201.13333
Quantifying n-photon indistinguishability with a cyclic integrated interferometer
Crespi et al (2022)
"As mentioned above, the typical way to measure the indistinguishability of two single photons exploits the HOM effect. Namely, the photons are injected in the two separate input ports of a balanced beam-splitter; the delay between the two photons is scanned by varying the optical length of one of the incoming paths, while coincidence detections at the two separate output ports are monitored. A dip in the interference pattern, i.e. the suppression of coincidence detection, is observed for null relative delay, and the visibility of this dip quantifies the indistinguishability of the photon pair. [The HOM effect was demonstrated in the swapping reference we are using. The dip in coincidences of course is due to the photons emerging from a single port, rather than 2.]
"As a matter of fact, this experimental layout is not the only one that gives access to the latter quantity [as a measure of indistinguishability]. For instance, the two photons could be injected simultaneously in the separate input ports of a Mach-Zehnder interferometer with balanced arms, while again monitoring the coincidence detection of two photons at the two separate output ports. If the internal phase of the Mach-Zehnder interferometer is scanned, a quantum interference fringe is measured in the coincidences [30]. This fringe shows half of the period that would be observed in the case of classical light, and its visibility is directly linked to the visibility of the HOM dip, thus also providing a quantification of the two-photon indistinguishability."
If they are indistinguishable, they do not get separated by the MZI. Why does this matter to this thread?
The issue is whether a deterministic process (a la MWI) causes the swap. If it did, I would say that order matters. And I might suspect (as you do) that it might even be reversible. Certainly we normally say QM is indeterministic, and we certainly agree that order does NOT matter. And hopefully the newer citation will convince you that indistinguishability is not reversible.
So that determinism is something the MW Interpretation adds, not present in QM. In a clockwork universe, how can you say that making 2 & 3 indistinguishable can be done any time before, during or after measurement of previously unentangled photons 1 & 4? And it can be done at the discretion of a human experimenter of her own free will?
So I don't believe a suitable MWI explanation of the cited Zeilinger experiment is possible. Certainly, as I think we agree, there is none in which MWI is considered "local" by the usual standards.
  • #181
Thanks, I'll take a look.
  • #182
I didn't say indistinguishability could (possibly--I said I wasn't sure) be reversed. I said the swap could (possibly) be reversed.
  • #183
The "dip" is for the case where the photons arrive at exactly the same time at the swap beam splitter. And if they do so, as you say, they both come out the same output port. But if they do that, they can only swap into a limited number of the possible Bell states. In particular, they can't swap into the singlet state, which is the one in which we have one photon coming out each output port of the swap beam splitter. But that is the case that I am interested in doing an MZI analysis for. It is also the only case for which the "event ready" signal occurs in at least one of the entanglement swapping experiments you have referenced in the various threads we have had on that topic.
In other words, unless I'm missing something, the "dip" point, where the photons arrive at the swap beam splitter at exactly the same time, cannot be the only case where a swap occurs, and therefore cannot be the only case in which there is indistinguishability. There must be a finite window of time within which, if both photons arrive at the swap beam splitter, a swap can occur.
  • #184
I. Mmmm, let's make sure we are saying the same thing. There are 2 completely different Bell states being applied in the experiment:
i) The Bell state for entangled photons 1 & 2, and the Bell state for entangled photons 3 & 4. These are normally chosen to the be same state. That is of course a function of the source, which in this case is PDC. And you are quite correct, for this experiment, the source pairs are created in the singlet state. That being the |ψ−> Bell state. The choice of this for the source Bell state is mostly a matter of convenience. I think we agree here just fine.
ii) The Bell state for entangled photons 1 & 4 applies of course only if a swap occurs. That can be any one of 4 possible Bell states |ψ+>, |ψ−>, |φ+>, |φ->. However, only 2 of the 4 can be detected/differentiated by detector clicks at the BSM (for photons 2 & 3 arriving nearly coincident). The 2 that can be distinguished are |ψ+> and |ψ−>. These 2 allow for 4 fold coincidences. The other 2 Bell states (|φ+>, |φ->) are ignored because they only yield 3 fold coincidences (since Photons 2 & 3 end up in the same detector and only appear as a single click). Only 4 fold coincidences are considered, because the specific detectors that go "click" differentiate between |ψ+> and |ψ−> for Photons 2 & 3. These always occur with one H> click and one V> click. I think we agree here as well.
If those 2 clicks occur in the same output port of the beam splitter (BS), then the resulting Bell state is |ψ+>. If those 2 clicks occur in different output ports of the beam splitter (BS), then the resulting Bell state is |ψ->. At this point, it doesn't matter whether the Bell state chosen for i) is the singlet state or not. What matters is that the 2 identified states are |ψ+> or |ψ−>.
II. I am sure you are aware of all this, so let's re-examine the HOM dip. This is telling us that the Bell state is not being discriminated, and the singlet output state experiences destructive interference within the beam splitter during an H-O-M test. That is exactly as you said above. You are wanting to present the analysis of the swapping experiment for just that case I guess, although I don't see why. Everything works exactly the same under every interpretation whenever there are 4 fold coincidences. Indistinguishability is a requirement regardless.
The fact that the arrival times for the H-O-M effect to appear is quite narrow means these two photons ARE interacting inside the BS. There is no way to reverse destructive interference. There is no way to distinguish the output photons once indistinguishable - even if you later attempt to check their polarization. Because if you knew (or could know) their polarization going into the BS, they wouldn't be indistinguishable, right?
So let's say we look at the singlet |ψ−> pairs coming out of your MZI. You are basically saying that they are orthogonally polarized (that's the hallmark, right)? That case can be identified, as easily as |ψ+>, which is also orthogonally polarized. So I say everything that applies to one case applies to the other.
I think what you are alluding to that the coincidence window for H-O-M effect (1-10 ps) is much smaller than the window for the swapping experiments (1-10 ns). I'm not sure I understand why those scales are so different, but I would guess it is related to the photon sources being independent and phase linked in some manner.
III. We still have the following in the swapping scenario for MWI:
a) Some window during which the 2 & 3 photons must overlap at the BS, and be swapped into 1 of 4 possible states. That is not reversible. Coincident with the 4 possible Bell states, there are 2 permutations for each (reflected/transmitted) . There must be MWI branching into 8 worlds here.
b) The subsequent distance to the PBS can be any length. However, in principle a polarization measurement is reversible. Ignoring that, each of the above 8 worlds can be expressed 2 ways in polarization terms. That's 16 worlds by my count.
c) The final distance to the detectors can be any distance as well. I don't see the detectors as being the spot where the branching must occur. Again, that ordering can be arbitrary.
IV. So I think we end up with a lot of issues for MWI to explain: when/where exactly is branching to occur per MWI? To be fair, QM is not exactly overly specific either - it just says look at the entire context. But QM does not specify observables have specific values at all times, which MWI apparently does make that claim. So when and where do those values change (discontinuously) if not at branching?
  • #185
To simplify the analysis, and because, as I mentioned before in at least one entanglement swapping experiment you linked to, that one case was the only one that caused an "event ready" signal to be generated. Adding in the other possible Bell states that the BSM can project into doesn't change anything essential, it just adds more terms to the equations.
Yes, that was my understanding; the HOM "dip" time window is much shorter than the time window required for a swap to occur.
I've already answered this: wherever decoherence occurs. In the scenario under discussion, that happens whenever a photon detector registers a photon, or whenever a time window for a photon to reach a detector expires and the detector does not register a photon (which means the photon escaped into the environment and is lost). So what I was calling "swap" vs. "no swap" is just distinguishing between "one photon is detected in each output arm of the BSM beam splitter" and all the other possible detection/no detection outcomes. Again, that was for the reasons given above.
No, it doesn't. In the MWI, the wave function is all there is. Observables only have specific values in particular branches when the appropriate entanglements are present due to previous unitary interactions (for example, between a photon and a detector).
  • #186
PeterDonis said:
1. ...as I mentioned before in at least one entanglement swapping experiment you linked to, that one case was the only one that caused an "event ready" signal to be generated. ...
2. Yes, that was my understanding; the HOM "dip" time window is much shorter than the time window required for a swap to occur.
3. I've already answered this: wherever decoherence occurs. In the scenario under discussion, that happens whenever a photon detector registers a photon, or whenever a time window for a photon to reach a detector expires and the detector does not register a photon (which means the photon escaped into the environment and is lost). So what I was calling "swap" vs. "no swap" is just distinguishing between "one photon is detected in each output arm of the BSM beam splitter" and all the other possible detection/no detection outcomes. Again, that was for the reasons given above.
1. That was in fact the case in some swapping experiments, where a single Bell state is easier to discern than two. The Zeilinger reference did 2 of the 4.
2. I will keep looking for a reference which can suitably explain this. As best I can tell, it is at the beam splitter of the BSM where the tight timing is required for indistinguishability - which certainly makes sense.
3. Just a minor point here: Yes, photons do get lost. But at the BSM, when there is only 1 detector clicking, that almost always means that photons 2 & 3 went to the same detector (same arm, same polarization). Nothing was actually lost. Current detector technology cannot discriminate between 1 photon arriving at a detector versus 2 photons arriving within a few hundred femtoseconds.
But I don't really think what you call "decoherence" matches the MWI concept of branching. Unfortunately, I cannot find enough agreement between sources on MWI to really nail this down one way or the other. I.e when and where does a swap occur?
a. In orthodox QM: the rule is to look to the *entire* context for an answer - and timing/ordering of individual components doesn't matter - ditto for precise location of actions. I might say, for example, that the swap occurs within the Beam Splitter at the point the 2 & 3 photons are irreversibly indistinguishable. However: at that point, which specific Bell State (1 of the 4 possibilities) itself has not yet been determined - and it can't be until the irreversible clicks occur after those photons pass the reversible polarizers. That explanation might be correct, but it is no more specified in standard QM than saying no swap at all occurs at all until the 4 detectors click within the time window (exactly as you say).
b. I don't really think the same can be said for MWI. If MWI is to be meaningful, there should be more detail on precisely when/where branching occurs.PS I think we've arrived at a point where we are close enough in agreement that further effort from you might not be fruitful. :smile: Thanks for all your efforts. Of course, I always welcome more discussion from you or anyone.
Likes Lord Jestocost
  • #187
Decoherence is not identical with the MWI concept of branching. It is just a prerequisite for the MWI concept of branching. But branching itself is a separate concept from decoherence. The best simple way I know to describe the connection between the two is that decoherence explains why the branches can't interfere with each other, which is the key fact that allows the MWI to treat each branch as a separate, independent "world".
I don't see why. Branching in the MWI is just as "fuzzy" in time as the corresponding concepts are in other interpretations (like "when does collapse occur" in a collapse interpretation, or "when does the swap occur" in your description). The "fuzziness" here is partly due to limitations in our ability to measure and record what happens on very short time scales. But it's also partly due to the inherent arbitrariness in the concepts; we are trying to draw bright lines when the actual physics, as far as we can tell, is continuous. Asking exactly when branching occurs (or collapse, or the swap, etc.) is like asking exactly where on the isthmus of Panama the boundary is between North and South America. Any answer is going to be arbitrary: in the actual geography of the Earth, independent of human ideas, there is no sharp boundary, just a continuous strip of land. Similarly, in the actual physics of the quantum events we are discussing, independent of human ideas, there is no sharp boundary between "not yet branched" and "branched" (or between "not yet collapsed" and "collapsed", or between "not yet swapped" and "swapped"), just a continuous process--at least as far as we can tell with our current knowledge. Maybe at some point we will do experiments on short enough time scales that will explicitly show a sharp boundary--and then we will have to update our theories accordingly.
Likes kered rettop, vanhees71, mattt and 1 other person
  • #188
gentzen said:
But in most other interpretations, there also exists something which lives in normal 3+1 dimensional space. If you deny the existence of that 3+1 dimensional space, or at least the existence of anything living in that space, then the locality notion of that 3+1 dimensional space no longer applies to you.
I disagree. For the purposes of this discussion, locality should be framed in terms of the definitions associated Bell's papers. As such, all theories of QM are non-local. We can just consider the unobservable features of MWI as another form of hidden variables.
  • #189
martinbn said:
You say that MWI is alocal because the wave function lives in a higher dimensional abstract space. But that is not specific to this interpretation, it is true for all of them. This just introduces a new word for something different!
Agree, IMO, these are just another form of hidden variables.
  • #190
Not really. "Hidden variables", in Bell's formulation, means variables in addition to the ones that appear in standard QM. The wave function appears in standard QM; it's not a hidden variable. And in the MWI, the wave function is literally the only thing there is. So the MWI is not a hidden variable interpretation. It's just a "take the wave function literally in all respects, no matter how extreme and outlandish it turns out to be" interpretation.
  • #191
Wait, do you disagree with me, or with Demystifier? I just explained why Demystifier's argument makes sense as an argument, like martinbn interpreted correctly:
martinbn said:
Are you saying that @Demystifier says that in MWI the 4 dimensional space-time doesnt exist or nothing exists in it? My understanding of MWI is that there is no such claim, of course i might just not know enough about MWI.
Demystifier's original comment was:
Demystifier said:
In my view, MWI is neither local nor non-local. It is alocal. See https://arxiv.org/abs/1703.08341
My personal opinion of MWI is that just like Copenhagen, it is not a single interpretation, but different proponents mean quite different interpretations when they say MWI. And those different interpretations contradict each other when you start to dig into details.
  • #192
This would leave interesting questions on the table. E.g. Brown and Timpson argue that the non-separability of the wavefunction frees MWI proponents from relying on Bell's local causality as an account of locality, without giving up the idea that correlations in quantum experiments have explanation.
  • #193
This paper seems questionable to me, at least as far as the MWI is concerned. I find this statement on p. 2:
There is a consistent Lorentz covariant model of quantum phenomena which violates local causality but is local in Bell’s 1964 sense: the Everett picture.
AFAIK there is no accepted relativistic formulation of the MWI (i.e., one that uses quantum field theory instead of non-relativistic QM), so the "Lorentz covariant" claim here is simply false. (It also seems odd on its face, since in a QFT context "local causality" means "operators at spacelike separated events commute", which is true--so Lorentz covariant QFT does not violate "local causality", yet the claim above implies that it does.)
Also, it's not clear to me how even the non-relativistic MWI is "local in Bell's 1964 sense", since that would mean Bell's factorizability condition was met: but the factorizability condition is a condition on the observed correlations, and any QM interpretation violates that condition, since QM's experimental predictions do.
Likes vanhees71 and gentzen
  • #194
Indeed, this paper also seems questionable to me, at least as far as its references to Tim Maudlin are concerned:
gentzen said:
For MWI, there are nearly as many schools as there are variants of Copenhagen, and some of those schools are somewhat problematic in their behavior and claims:
  • #195
I think that is too narrow of an interpretation. IMO, the wave function should be considered hidden, hence, it's state is a hidden variable.
  • #196
On this view, every QM interpretation is a hidden variable interpretation, since QM itself, independent of any interpretation, is a hidden variable theory. Which makes the term "hidden variable" useless, since the whole point of the term was to distinguish between QM interpretations.
  • #197
MWI proponents seem to assume an Everettian interpretation is extendable to relativistic theories. (See e.g. Rubin). Do you have reverences discussing difficulties with extending MWI to relativistic theories?
Bell's local causality is different from local commutativity. (See Bell's "La nouvelle cuisine")
  • #198
Wrong question. The question is, do the MWI proponents who "seem to assume" that the MWI is extendable to relativistic theories, have references that actually do that? As far as I can tell, the answer to that is "no". The Rubin paper you reference doesn't give any such extension; it uses nonrelativistic quantum field theory for its computations.
(The Rubin paper is also too quick to dismiss Bell-type nonlocality for the MWI. Bell's original formulation made assumptions about single outcomes, but there are later formulations that don't--they are formulated purely in terms of observed correlations, which applies to the MWI just as much as any other interpretation. In the MWI they become observed correlations in particular branches of the wave function, but they're still there and they still count as "nonlocality" since they violate the relevant inequalities.)
Yes, Bell's "local causality" is not the same as relativistic QFT's "local causality". But to just blithely say that relativistic QFT "violates local causality" without even mentioning the different usage of that term in the QFT community vs. the QM interpretation community, does not seem to me to be justified.
  • #199
From the paper:
Indeed, there is a simple line of argument which leads to the conclusion that Everett-interpretation Heisenberg-picture quantum field theory must be local. The dynamical variables of the theory are field operators defined at each point in space, whose dynamical evolution is described by local (Lorentz-invariant, in the relativistic case) differential equations.
I am asking you to clarify your position: Are you saying the relativistic case cannot in fact be constructed, based on some fundamental objection or non-generalizeable character of Everettian interpretations, or are you simply saying you have not seen the relativistic case in literature?
The context is made explicit in the introduction.
  • #200
The latter.
