Is My Mathematical Proof Correct?
  • Thread starter Thread starter Artusartos
Artusartos
Do you think my answer is correct? If not, can you tell me why it is wrong?
Thanks in advance
This looks fine, but you need to slightly re-adjust the inductive step. There you assume that ##|s_{n+k}-s_n|<\epsilon## and then carry on with
\begin{eqnarray*}
|s_{n+k+1}-s_n|
& = & |s_{n+k+1}-s_{n+k}+s_{n+k}-s_n| \\
& \leq & |s_{n+k+1}-s_{n+k}|+|s_{n+k}-s_n| \\
& < & \frac\epsilon2 + \frac\epsilon2.
\end{eqnarray*}
That last line should be "##\ldots<\epsilon+\epsilon##". Which means you need to go back in your proof and somehow ensure that ##|s_{n+k}-s_n|## and ##|s_{n+k+1}-s_{n+k}|## are together less than ##\epsilon##, not each separately.
\begin{eqnarray*}
|s_{n+k+1}-s_n|
\end{eqnarray*}
Ok, thanks a lot :smile:
\begin{eqnarray*}
|s_{n+k+1}-s_n|
\end{eqnarray*}
Question 10.6 in this link:
http://people.ischool.berkeley.edu/~johnsonb/Welcome_files/104/104hw3sum06.pdf
is the same as the one that I solved...
But in part (b), it says that this result is not true for |s_{n+1} - s_n| &lt; 1/n. And I was a bit confused...because can't I use the same proof for this one too?
Thanks in advance
Unfortunately your present proof doesn't work. Your assumption is that |s_{n+k} - s_n| &lt; \epsilon, and you know that |s_{n+ k +1} - s_{n+k}| &lt; 2^{-(n+k)}. The inductive step is then
<br /> |s_{n+k + 1} - s_n| \leq |s_{n+k+1}-s_{n+k}| + |s_{n+k} - s_n| &lt; 2^{-(n+k)} + \epsilon<br />
But, sadly, 2^{-(n+k)} + \epsilon &gt; \epsilon for all n and k. So you can't conclude that |s_{n+k+1}- s_n| &lt; \epsilon, even though this might be the case. (If your inductive step doesn't make use of the given bound on |s_{n+k +1} - s_{n+k}|, then your proof is almost certainly flawed.)
The best proof is probably the one given.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
