pervect said:
none of Newton's laws apply directly in an accelerated frame of reference such as the elevator.
They do if you are willing to include "inertial forces" in your analysis. See below.
pervect said:
if one is standing in an elevator, there is only one real force, that is the force on one's feet pushing you up to make you accelerate along with the elevator.
No, there is also another real force, the force of your feet pushing back down on the floor of the elevator. As others have pointed out, this force is the one that is paired with the force of the elevator on your field by Newton's Third Law. So Newton's Third Law applies just fine.
Newton's Second Law also applies just fine in the non-inertial elevator frame, provided, as I said above, that you are willing to include an "inertial force" in this frame, which points downward (i.e., towards the elevator floor) and has a magnitude equal to the acceleration of the elevator times the mass of whatever object is being accelerated by it. So, for example, if you are standing on the floor of the elevator and let go a rock, the rock will be acted on by this inertial force, which causes it to accelerate downward. And the magnitude of this force obeys Newton's Second Law, ##F = ma##.
Furthermore, if we want to explain why you, standing on the floor of the elevator, don't accelerate upward as a result of the force the floor exerts on you, we have to appeal to this same inertial force, which acts downward and has a magnitude exactly equal to that of the upward force of the floor on you. So the net force on you is zero, and you remain at rest in this non-inertial frame.
Of course some will object that all of the above is true only because we
defined the "inertial force" in order to make it true. This is correct; but it doesn't make the above analysis invalid. It just makes it conceptually limited; we obviously can't use the above analysis to argue that inertial forces "must be real" (or words to that effect), because that would be arguing in a circle.
pervect said:
Having noted the distinction between inertial forces (represented by rank 1 tensors) and non-inertial forces (represented by non-tensorial Christoffel symbols)
I think you mean this the other way around, correct?
