Is the cat alive, dead, both or unknown
  • Context: High School
  • Thread starter Thread starter Science2Dmax
The discussion revolves around Schrödinger's cat thought experiment, specifically addressing the interpretation of the cat's state while it is in the box. Participants explore concepts of superposition, uncertainty, and the implications of quantum mechanics on the understanding of the cat's status as alive, dead, or unknown.
  • Some participants suggest that the cat's state should be considered "unknown" rather than "both alive and dead," emphasizing the distinction between these interpretations.
  • Others argue that the cat is in a superposition of two states, which is a technical interpretation of quantum mechanics.
  • One participant notes that the probability of the cat being alive or dead can be calculated based on the half-life of a radioactive atom involved in the thought experiment.
  • Several participants discuss the difference between a superposition and a mixed state, with some asserting that improper mixtures can be considered superpositions while others disagree.
  • There is a contention regarding the implications of tracing over the environment in quantum mechanics and how it affects the classification of states.
  • Some participants reference external sources and literature to support their claims about the nature of superpositions and mixtures.
Participants express differing views on the interpretation of the cat's state, with no consensus reached on whether "unknown" and "superposition" are equivalent or distinct concepts. The discussion remains unresolved regarding the implications of improper mixtures versus superpositions.
The discussion includes complex technical arguments about quantum mechanics, superposition, and mixed states, with references to specific mathematical formalism and external literature. Some assumptions and definitions are not fully explored, leading to potential misunderstandings.
Science2Dmax
my girlfriend is wondering if while shroodingers cat was in the box, we should consider it as both unknown rather than both alive and dead. please shed some light on the subject.
Unknown, or more technically, in the superposition of two states.
You'll find a bunch of threads on Schrödinger's cat here if you search. The mainstream answer is also the commonsense one: The cat is either alive or dead, just as a tossed coin is either heads or tails even before we look.
I should add that that's pretty much always been the standard answer. When Schrödinger posed his famous though experiment almost a century ago, it wasn't because he or anyone else was seriously suggesting that the cat would somehow be "both alive and dead" or "in a superposition of alive and dead". He was pointing out a problem in the then-current understanding of quantum mechanics: nothing in the mathematical formalism clearly explained why the cat would be either dead or alive but not something in between.
Unknown. It "is" in a superposition of two states, but we don't now what that means. Quantum mechanics is not about what "is", but about what we can predict about what we will observe.
Unknown, but we DO know the probability of the cat being either alive or dead.
The thought experiment involves a radioactive atom, which when it decays triggers the mechanism which kills the cat.
The atom type has a known half life, and after this amount of time has passed the probability of the cat being alive or dead is 1:1.
If the cat is left in the box for a longer time the probability of it being dead increases and given sufficient time it become a near certainty.
So never, never, put a dead cat in "the box", at the beginning... such an action would have a probability of
creating fundamental disturbances in the Force, or at the vary least, a minor "tremor"... :oldwink:
"Unknown" and "in the superposition of two states" are not the same thing.
If toss a coin, it's either heads or tails but I don't know which until I look at it. That's "unknown".
A spin-1/2 particle with its spin aligned up along the z axis is not in an unknown state. It's in the up eigenstate of the ##S_z## operator and that's a complete and unambiguous specification of its state that leaves nothing unknown. However, that state is also a superposition of spin-up along the x-axis and spin-down along the x axis.
Indeed.
Technically its the difference between a superposition and a mixed state. If you don't know the difference look it up.
Thanks
Bill
What Bhobba said.
You have to use the density matrix formalism to see the difference. Googling for "quantum density matrix" will find some good links - it's unfortunate that this is not covered by some intro textbooks.
Thanks for the correction.
bhobba said:
Indeed.
Thanks
Bill
Nugatory said:
What Bhobba said.
But since this is the density matrix before the measurement outcome, it could be an improper mixture, which is a superposition.
Improper mixtures are not superpositions from the very definition of a mixture. Its called improper because its physical origin is different to a proper one - not that its not a mixture - which it obviously is.
Thanks
Bill
Improper mixtures are superpositions which is why they are not proper. A superposition refers to a pure state, which is what an improper mixture is.
An improper mixture is NOT a superposition.
Outside the system it remains in superposition - inside it isn't. That is the key difference - see the section 1.2.3:
http://philsci-archive.pitt.edu/5439/1/Decoherence_Essay_arXiv_version.pdf
It is removing system B from our control by tracing over the environment that does it.
Thanks
Bill
Thanks
Bill
There is no difference because the entire system is still in a superposition. Everything you do on the improper mixture has a counterpart in the full system.
Bernard d'Espagnat makes the distinction between an improper mixture v a proper mixture in his book "On Physics and Philosophy". atyy is correct in stating an improper mixture refers to a superposition (pure) state.
Of course. But we are talking about inside the system. That's what tracing over the environment does.
Thanks
Bill
It can't - by the definition of a mixed state. You have traced over the environment to do it.
Thanks
Bill
Just to expand further on the issue, Lubos has done an excellent post giving the detail - if I was to write something it would basically be what he wrote:
http://physics.stackexchange.com/qu...ake-the-partial-trace-to-describe-a-subsystem.
What's going on is you have the whole system A+B - that will be assumed to be a pure state |p><p| - here I have used the operator description of a pure state to avoid confusion later. The mixed state comes about because we are only interested in observations on A. But its entangled with B. Its that entanglement that leads to it being a mixed state because you need to do a partial trace over B due to only A being observed. It is this only observing A when it entangled with B that's the cause ie you are observing inside the system ie the state is (trace over B |p><p|) - which, lo and behold, turns out to be a mixed state - see equation 1.2.3 in the paper I linked to before. Outside the system its a pure state |p><p|, hence a superposition of all sorts of things, and remains in superposition, until, of course, it becomes entangled with something else. But because of the partial trace inside the system, since you are observing only A, its a mixed state.
Thanks
Bill
This thread is not about the radioactive atom, but about the cat which will be killed when that atom decays. The question is if the special state that the atom is in according to the theory, necessarily affects the cat because we don't know about it. It was Schrödinger's intention to ridicule that idea by means of his cat example.
- https://en.wikipedia.org/wiki/Schrödinger's_cat#The_thought_experiment
Thanks
Bill
The link you give itself shows that the the partial trace is equivalent to observing ##L_{A} \otimes \bf{1}## on the full system which is in a pure state. So the distinction you are making is rather arbitrary. In particular, with respect to your comment in on Nugatory's 'If toss a coin, it's either heads or tails but I don't know which until I look at it. That's "unknown".' - that refers to a proper mixture, not an improper mixture.
Ok - maybe what I said was a bit general so I will do a simple specific example and we can see exactly what's going on.
Suppose we have the following superposition |p> = 1/√2|b1>|a1> + 1/√2|b2>|a2>. This is obviously an entangled system where system A is entangled with system B. It's a pure state. It remains in a pure state until observed ie until its interacted with.
But now we will do an observation on just system A with the observable A.
E(A) = <p|A|p> = 1/2 <a1|<b1|A|b1>|a1> + 1/2 <a1|<b1|A|b2>|a2> + 1/2 <a2|<b2|A|b1>|a1> + 1/2 <a2|<b2|A|b2>|a2>
Now here is the kicker - since you are only observing system A the observable A has no effect on the B system or its states. So we have:
<p|A|p> = 1/2 <Aa1|<b1|b1>|a1> + 1/2 <Aa1|<b1|b2>|a2> + 1/2 <Aa2|<b2|b1>|a1> + 1/2 <Aa2|<b2|b2>|a2> = 1/2 <a1|A|a1> + 1/2 <a2|A|a2>
= Trace((1/2|a1><a1| + 1/2|a2><a2|) A) = Trace (p' A)
Here p' is the mixed state 1/2|a1><a1| + 1/2|a2><a2|. Thus observing system A is equivalent to observing a system in the mixed state p' - which by definition is the state from |p> by doing a partial trace over B. The observation will of course give |a1> or |a2> and the entanglement will be broken so that if you get |a1> system B will be in |b1> and conversely. We still have collapse if you like that language - but now it has a different interpretation - you are not observing a pure state - but a mixed one. Its not a proper mixed state because its not prepared the way a proper mixed state is prepared - but the state is exactly the same. Any observable A will not be able to tell the difference. This means we, in a sense, can kid ourselves and say, somehow, its a proper mixed state. If it was a proper mixed state then prior to observation it is in state |a1> or state |a2> with probability of half. Prior to observation its in superposition - after it isnt. Until observed it continues in superposition - its simply because of the entanglement it can now be interpreted differently. By observing 'inside' the system - ie only observing system A - it is in a mixed state - not a proper one - but still a mixed state. Because of that it allows a different and clearer interpretation that avoids a lot of problems.
I really can't explain it better - so if its still unclear then there isn't much more I can do.
Thanks
Bill
Suppose we have the following superposition |p> = 1/√2|b1>|a1> + 1/√2|b2>|a2>. This is obviously and entangled system where system A is entangled with system B. It's a pure state. It remains in a pure state until observed ie until its interacted with.
Thanks
Bill
How is observing A inside the system any different from observing A ##\otimes## I on the full system?
Anyway, the important point is that the improper mixed state does not correspond to Nugatory's definition of unknown - that is a proper mixed state.
Buzz Bloom said:
Note the following well known quote by Richard Feinman" "I think it is safe to say that no one understands Quantum Mechanics."
Everyone knows Feynmans quotes. But as you learn more about QM you understand plenty of people understand QM - what he meant was understanding it in usual everyday terms.
In particular you need to get used to the idea the primitive of the theory is observations.
Thanks
Bill
Let me see if I can use two different definitions of "unknown" to explain more clearly the point of view in which an improper mixture and a superposition are the "same thing".
In one definition of "unknown", the quantum system is in a definite state of reality, but we don't know what it is. All classical randomness is "ignorance interpretable" in this sense. In the quantum mechanical formulation, this most closely (but not exactly) corresponds to a measurement, followed by wave function collapse and the formation of a proper mixture. (I believe Nugatory gave this answer in post #3.)
In the definition of "unknown" that is the typical answer to the OP's question, the quantum system is in a definite state, but we don't know what that means because we don't understand whether the quantum state is real. It is in this sense that the pure state and the improper mixture are the "same thing", in that the randomness produced by each is not "ignorance interpretable". (This was my answer in post #4.)
Although there are two different definitions of "unknown" that are used to reply to the OP, it is known in some cases how to make the second definition into the first without wave function collapse, ie. give the quantum system a definite state of reality - by using nonlocal hidden variables.
At our current stage of technology, if nonlocal hidden variables do exist, we are not able to control them. So the second answer is more currently practical, in the sense that as long as we don't have enemies who are able to control such nonlocal hidden variables, then we can use quantum mechanics to produce "true" randomness for secure codes. Of course, if our enemies are much more technologically advanced than we are and can control the hidden variables, then quantum mechanics will not produce "true" randomness, and the enemies can use the determinism to break our codes.
Hi bhobba:
I am not a physisist.
From other material of Feyman's that I have read, I have come to believe that he had a more profound interpretation in mind than the one you give in your post. Unfortunaely, I can't at this time find any other relevant quotes of his I can post.
I think Feynman meant that the interpretive relationship between the QM math and the real physical world was, at the time of his quote, outside the realms of both math and physics. The relationship was (and may still be) entirely philosophical. That is, all the interpretations about this relationship that had been put forth by the best minds in physics soon after were seen to be apparent philosophical paradoxes. A relativelty recent example of this is the "action at a distance" interpretation of entanglement.
A physisist friend introduced me to an interpretation (one that I have been unable to find on the internet anywhere) that so far seems to me to be free of paradoxes, but it would require a somewhat lengthy exposition. As a brief overview, I offer: The interpretation of probability states involves multiple contingent parallel universes (not to be confused with any real parallel universes or multiverses). The instant of an observation (between the past and the future) constrains the collection of contingent universes to become a single real universe.
Regarding the cat: When the experiment has been set up, and the particle that will determine fate of the cat is emitted, two contigent universes are created, one in which tha cat will survirve, and the other in which the cat will soon after die. When the obsever opens the lid, one of these two contingent universes becomes the real universe in which the observer continues to exist.
Ok.
A question then.
In that thought experiment the particle detector clicks or not and that is what determiners if the cat lives or dies.
What has the lid opening got to do with anything?
The reason I ask is there is a lot of confusion about it and what it means. I could explain it, but I think its usually better if you think it through for yourself - and beside I may be wrong.
Thanks
Bill
  • · Replies 39 ·
  • · Replies 143 ·
13K
  • · Replies 42 ·
  • · Replies 17 ·
  • · Replies 31 ·
  • · Replies 30 ·
  • · Replies 46 ·
  • · Replies 97 ·
