Is the Lagrangian a Function of Only Generalized Coordinates and Speed?
The discussion centers on the dependence of the Lagrangian on generalized coordinates and speeds, questioning whether it can also depend on generalized acceleration. It is generally assumed that the Lagrangian does not depend on acceleration, but this independence cannot be universally proven. The conversation explores the implications of including acceleration in the Lagrangian, leading to a modified Euler-Lagrange equation. The derivation suggests that if the Lagrangian includes acceleration, it alters the standard formulation of the equations of motion. Ultimately, the necessity of proving independence from acceleration is emphasized to maintain the integrity of the Lagrangian framework.
pardesi
Hmm how does one prove that a lagrangian is a function of just the generalized coordinates and the generalized speed and not the generalized "Accelaration"?
In general, one assumes that it does not depend on \ddot q_i (with q_i the generalized coordinates) because in most systems, it doesn't. But one cannot prove this independence, and indeed one can derive the Euler-Lagrange equations for a Lagrangian with does depend on them in the same way as usual.
One should check, however, that the "acceleration" is really independent, otherwise one cannot consider q and \ddot q as independent coordinates and one would have to impose a constraint (e.g. the original Euler-Lagrange equation for the Lagrangian which does not depend on the acceleration).
But in principle, I think this argument works:
Suppose we have a Lagrangian \mathcal L(q, \dot q, \ddot q). Then a variation of the action gives
\delta\left( \int \mathcal L \, \mathrm dt \right) = \int \left( \frac{\partial \mathcal L}{\partial q} \delta q + \frac{\partial \mathcal L}{\partial \dot q} \delta \dot q + \frac{\partial \mathcal L}{\partial \ddot q} \delta \ddot q \right) \, \mathrm dt.
Using that \delta\dot q = \frac{d(\delta q)}{dt}, etc. we get by partial integration (once on the second term, twice on the third term)
\delta\left( \int \mathcal L \, \mathrm dt \right) = \int \left( \frac{\partial \mathcal L}{\partial q} - \frac{d}{dt} \frac{\partial \mathcal L}{\partial \dot q} + \frac{d^2}{dt^2} \frac{\partial \mathcal L}{\partial \ddot q} \right) \delta q \, \mathrm dt
assuming that all the boundary terms from the partial integrations vanish. Now for this to vanish for arbitrary variations (under these conditions), the bracketed term must be zero and we find a new "Euler-Lagrange equation",
\frac{\partial \mathcal L}{\partial q} + \frac{d^2}{dt^2} \frac{\partial \mathcal L}{\partial \ddot q} = \frac{d}{dt} \frac{\partial \mathcal L}{\partial \dot q}
thanks!
hmm you i cud smell that but just wanted to confirm if i was missing out something
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
