Is the mass of the electron constant?
The mass of the electron is considered a fundamental constant of nature, remaining unchanged over time according to the Standard Model of particle physics. Any variation in electron mass would significantly impact atomic orbits and light spectra, potentially explaining cosmic redshift, but current evidence does not support this idea. Extensive studies have shown that fundamental constants, including the fine structure constant, have not changed at detectable levels throughout the universe's history. The observed redshift is attributed to the expansion of the universe rather than changes in electron mass. Overall, the hypothesis of changing constants faces substantial skepticism due to a lack of empirical support and the consistency of experimental results.
Henry_F
If the mass of the electron has been changing during the evolution of the universe, then the orbits of the electrons would also change, which will shift the light spectrum of each atom.
Could this explain red shift of far galaxies, and the shift is not because the universe is expanding?
Henry
No. Besides, we have no reason to think that electrons (or any other particle) mass changes with time.
The mass of the electron is, as far as we know, a fundamental constant of nature. In the framework of the Standard Model of particle physics, which describes the fundamental particles and their interactions, the mass of the electron is considered a constant. This means that under normal conditions, the mass of an electron remains the same, and it doesn't depend on its velocity or other factors.
In scientific measurements, the mass of the electron is approximated as 9.10938356 x 10^-31 kilograms. This value is used in a wide range of scientific and engineering applications and has been measured with great precision. Any changes to the mass of the electron would have profound implications for our understanding of the fundamental laws of physics.
It's worth noting that there are theories and experiments aimed at testing the constancy of fundamental constants like the electron mass. These experiments are conducted with extreme precision, but so far, there is no conclusive evidence to suggest that the mass of the electron is not a constant. However, some theories beyond the Standard Model of particle physics do propose variations in fundamental constants, and these ideas continue to be explored by physicists.
The mass of an electron is a dimensionful constant, so you can simply define units such that it cannot change by definition or units such that it is changing by definition. There is no physical consequence to either choice of units.
For questions like this you need to find the relevant dimensionless constants.
The constant which controls this in a physically meaningful way is the dimensionless fine structure constant. There have been extensive studies of possible variations over the lifetime of the universe. Any such variations are below the level of experimental detection. It cannot account for the observed red shift.
Likes ohwilleke, nasu and PeterDonis
I fail to understand.
Changing of the mass of the electron is dimensionless (the mass has dimension, not the change).
Are there studies that such constants have too low changes to be detected?
How such studies could be made?
it must be calculated relatively to other constants, such as length or time, but what if all change?
Henry
##\Delta m## has dimensions of mass. ##\Delta m/\Delta t## has dimensions of mass over time.
Yes, for the fine structure constant and probably other dimensionless constants.
That is why you need to use dimensionless quantities.
If they change in such a way that the fine structure constant (and other dimensionless ratios) do not change, then all we've done is redefine the kilogram and our other units. All experiments will still yield the same outcomes, the needles on our dials will still point to the same places, chemistry and every else driven by the physics of orbital elections will stay the same, the energy levels won't change, ... It's no different than doing physics using the old english units instead of metric.
To actually get something physical to change (for example, in the first post of this thread you asked about atomic spectra changing over time) one or more of the dimensionless ratios like the fine structure constant would have to change. Thus, your question is really about whether these ratios have changed over time, not the mass of the electron.
The issue here is basically the same as a question that is asked here much more often: Suppose the speed of light were to change? You might want to search out some of those threads; the discussion there will be more complete. Also, be sure to check out the recent redefinition of the kilogram; it will reinforce the essential arbitrariness of the numerical value of the masses we assign to particles. The physics is in the ratios between these values, not the values themselves.
Likes dextercioby, Klystron and PeroK
Shouldn't we rather say the electron's energy content does not change since when photons are emitted or absorbed, there is presumably a Δm = ΔE/c^2 change?
Edit: contradiction here since both are changing but then what property is it that doesn't change ?
The property that doesn't change is the electron's rest mass, which is what we're talking about when we say "the mass of the electron" without further qualification. Rest mass and rest energy are equivalent, so we can go with "energy content" as you suggest; it's just the a matter of whether we use units like MeV or kilograms to specify it.
So now which electron has "rest" mass/energy: the one that (for eg) sits safely in Hydrogen's 1s orbital or the one that's energized sufficiently to become a 'free' electron?
You need to, first of all, establish the validity of this statement. You need to show ample evidence to support it. This is before you start to consider the consequences of it.
Otherwise, you're asking us to explain why the unicorn has pink horn.
Zz.
This is precisely why a free electron cannot emit or absorb a photon. It must be bound in an atom. The mass of the atom as a whole increases or decreases according to the amount of energy emitted or absorbed. A free electron cannot do that since its mass cannot change, so all it can do is scatter a photon.
All electrons have the same invariant (aka rest) mass. However, the mass of the hydrogen atom is slightly less than the mass of a free proton plus the mass of a free electron.
Likes dextercioby, PeroK and davenn
Back to the future
When I asked about a change in the mass of an electron, it is the (mass after) / the (mass before) in some 2 points of time. This ratio is dimensionless.
If all other constants are also changed, does it means that the emitted spectrum stays unchanged?
Other constants must to be change at the same ratio, or the constant could be in power of something (f.e. meter is in power 2 in calculating the EM force).
Can we realty say something about all these constants, what define them? why are they constants? how did they behave during the evolution of the universe?
Henry
Henry_F said:
Back to the future
It is, but it also impossible to measure - you'd need to have last year's electron and this year's electron together at the time to measure that ratio, and that is clearly impossible.
The best you can do is to find the ratio of the electron mass to something else at one time, then at some later time see if that ratio has changed. For example the ratio of the proton mass to the electron mass is 1836.15267389, and if that were to change over time it would be a very big deal with clearly detectable physical consequences.
Suppose we were to find that that ratio is increasing over time (although all the available experimental evidence, and that's a very large amount, says that it is not changing at all). Does that mean that the proton mass is increasing or the electron mass is decreasing? That depends only on how we've defined the units that we're using; the physics is all in the dimensionless ratio.
Likes dextercioby
I think this thread has gotten tangled up in knots, or at least ratios of knots. (Look - a box of electrons from 1927!)
We can ask the question is there any atomic physics whatsoever that can fake the Hubble Law, and the answer is definitely no. We see redshifts of light apart from atomic spectra, light from blackbodies. We see time dilation in supernova and GRB durations - not an atomic process. And when we have multiple measurements from atomic and non-atomic processes, they agree.
Likes Drakkith, phinds, mitchell porter and 2 others
Ah, ok. That is not what people usually mean when they say “change of x” which usually means ##x_{after}-x_{before}=\Delta x##.
So the proton/electron mass ratio is close to what you want. Not exactly, but what you are specifically asking about is not studied, for the reasons pointed out above. The proton/electron ratio is constant to the best of our measurements.
In order not to complicate things, I would like to stay in 2 fix points in time, so I look at the relative changes of constants, and not at the rate of the changes.
Let’s assume that the energy of the electron in the atom's orbit E ∝ me^4
The Hubble effects states not only the shift to red, but also that is it greater the farer the object is, which means the sooner it is after the bang.
It could be because of 2 reasons (at least), the Doppler effect, and the change in me^4 during the expansion.I can understand how difficult it is to try to see the differences over time of me^4, but to look after the dark matter is also not a piece of cake (not to speak that both effects could contribute to Hubbel’s effect).
I can not understand the assumption that these constants were always fix, only because our time interval of measurements is too short to see differences.
Why the dark matter receives such a priority over changes of constants (which will better suit Einstein's first intuition) in astrophysics ?
Henry
All light, not just light produced by processes that depend on the energy levels of the bound electron, is red shifted identically. Thus, we'd need independent changes in multiple different and unrelated physical processes, and these ostensibly independent changes would have to each be of exactly the right size to produce exactly the same redshift over time. That's starting to sound a bit implausible.
Furthermore, some of these changes over time would have effects that are detectable in lab experiments. These experiments have been done (see the paper Dale cited in post 7 above, for example) and the effects have not been seen.
Thus, the change-in-constants hypothesis requires that we accept a series of remarkable coincidences and reject a substantial body of other evidence that shows the constants don't change. The dark matter hypothesis requires only that we accept the possibility that our telescopes aren't yet good enough to see everything that there is - not much of a stretch at all.
This forum has some threads on this "why dark matter?" question, and some of these go into much more detail about why dark matter is by far the most promising hypothesis. You might want to search some of them out for more on the subject.
Henry
When Einstein first developed GR it predicted an expanding universe. There's a common misconception that the expansion is due to dark energy. It's not. Even without dark energy (zero vacuum energy density) the universe would be expanding. Dark energy is responsible for increasing the expansion rate.
So, basically, if you want a static universe, you have to rework GR, or fudge it in some way.
There is no model of changing constants that fits the redshift data. And, there is no atomic theory that says why the ratio of proton to electron mass might be changing. So, basically, you have a "shot in the dark", that has no theoretical model to support it and it doesn't fit the available data in any case.
The dark energy model fits easily into GR and a constant vacuum energy density fits the data. That leaves the problem of explaining dark energy and the value of the energy density.
There's no comparison here between a solid theory with a piece missing and a wild speculation that has no theory or data to support it.
I miss the days when we didn't discuss personal theories on PF.
Henry, this proposal of yours requires no fewer than six new physics effects. You need three to explain the Hubble Law in three different physical phenomena (see my earlier message) and no fewer than three more to explain why the first three effects are hidden in other experiments and observations.
Likes davenn and PeroK
Did you not read the paper I posted above? The validity of our assumptions is always a subject of scientific inquiry.
Because changes in those constants have been investigated and shown to be very small.
Thanks, I read the paper, but I could not understand if it proves that there were negligible changes in the beginning of the expansion.
One could think about changes in few parameters that leave constant what we are looking, but not the me^4.
Well, I understand that this possibility requires too many changes in the current theory, so it is not elegant enough in order to start and investigate it.
I hope we are not looking for the key under the street lamp, only because there is light there,
but of course we can not invest a lot of energy into any crazy direction.
Henry
@Henry_F I have to admit that I am starting to join V50 in his sentiment here. Your original question on variation of the electron mass has been answered. The ratio you are describing is not something that can be investigated, instead temporal variation in other dimensionless constants that are both directly relevant to the theory and experimentally accessible are investigated and found to not vary.
Furthermore, as has been pointed out, there is no plausible variation which can account for the observed redshift even in principle. Certainly, variation in the electron mass would not do it.
Do you have any specific question about the mass ratio investigated or any remaining confusion about why your specific ratio is not investigated?
It does not. However, the observed redshift comes from times substantially after that.
Thanks to all.
Henry
Interesting thread. What I would also like to clarify: What would be different in an expanding universe in which the Compton wavelengths of all atomic particles would always be in a fixed ratio to the Hubble radius? That is, the atomic particles inflate just like the entire universe. Would anything be phenomenologically different in this universe than in ours? All of the dimensionless constants (fine structure constant, ratio of mass proton/electron) should also be constant over time in this universe.
There's no good answer to that question, because we do not live in a universe in which "the Compton wavelengths of all atomic particles [are always in] a fixed ratio to the Hubble radius". Thus the question is tantamount to asking what we learn by applying the laws of physics in a situation in which they do not apply - and the answer is that they tell us nothing because they don't apply.
Likes Vanadium 50, vanhees71 and Ibix
I am probably way out of depth here but do I understand correctly that the "Zitterbewegung" predicted by Dirac's equation implies the electron oscillates (at very high frequency) between positive and energy states? That is to say electron energy/mass oscillates. I understood this to be in the context of bound (rather than free) electrons since it is driven by the coulomb force between electron and atomic nucleus.
https://arxiv.org/pdf/2006.16003.pdf
The Zitterbewegung (German for something like "jiggling motion") is based on an old-fashioned formulation of quantum electrodynamics, called "relativistic quantum mechanics". It's an attempt to formulate relativistic quatnum theory in terms of the "1st-quantization formalism" only to realize as soon as one tries to describe interacting particles (or even only quantized electrons moving in a classically treated external electromagnetic field, the socalled semi-classical approximation) you have to introduce the infamous "Dirac sea", and then fill up the negative-energy states with electrons and declare this as the vacuum (without ever explaining, why the vacuum is uncharged, i.e., you just forget about the infinite charge of all these electrons in the negative-energy levels) and interpret holes in the Dirac sea as positrons with positive energy. This is all very confusing and that's why today we (should!) teach relativistic QT only as relativistic local quantum-field theory, which is already from the beginning a many-body theory, describing the creation and annihilation of particles in scattering processes or when moving in strong external electromagnetic fields (in the semiclassical approximation).
As (I think) Weinberg somewhere put it: Fermi's advantage against Dirac is that the former's sea does exist.
Likes neilparker62, PeroK and Dale
  • #31
This answer surprises me. The great strength of mainstream physics is that it can always explain what phenomenological nonsense - or at least what contradictions to empirical findings - would happen if one were to replace the established model with a crank idea at any point. You did that pretty well above - a universe in which only the electron changes its Compton wavelength over time, but not the other particles, would look completely different from ours because of the change in mp/me over time.
  • #32
Here's an example of such a study from ten years ago. There have been similar updates of this approach every year or two since then.
  • #33
Another nice article that shows or rather admits that the sole variation of the electron mass can be empirically refuted, but not a coordinated variation of the masses of all subatomic particles ("Of course, it is possible that several of these quantities are varying, and just by chance all the variation cancels out of the electron mass to proton mass ratio ... So there's a caveat, but it is a small one." ).
Ultimately, everyone can decide for themselves how big or small this caveat is. Just as everyone can answer the question for themselves whether they are convinced that darth... uh dark matter and dark energy (or at least one of both) will be directly detected during the rest of their lifetime.
In making this decision, I myself would pay more attention to the muon precision experiments from 2010 and 2013 (see proton radius puzzle), in which a proton radius of around 0.8412 fm was determined. Thus the ratio of the reduced Compton wavelength of the electron and the proton radius corresponds almost exactly to a quarter of mp/me. The whole confinement approach has no explanation for this match.
Suppose there were two projects to choose from: a new fancy telescope that could finally detect dark energy, or another precision experiment to confirm the conjecture that the proton radius is in a simple numerical relationship to the Compton wavelength of the electron. I bet you that the latter is more promising.
  • Skeptical
Likes weirdoguy, ohwilleke and PeroK
