Is the Motion of Particle P Simple Harmonic?
The discussion revolves around determining whether the motion of a particle P, attached to a spring, is simple harmonic after receiving an impulse. Participants suggest using Newton's second law or the Euler-Lagrange equation to set up the equation of motion. The impulse of 0.5 Ns leads to a calculation of the initial velocity of the particle. Once the initial conditions are established, the equation of motion can be derived. The thread concludes with the original poster successfully finding the answer.
mr bob
A particle P of mass 0.2kg is attatched by an elastic spring of modulus 15N and natural length 1m to a point A of the smooth horizontal surface on which P rests. P receives an impulse of magnitude 0.5Ns in the direction AP. Show that while the string is taught, the motion of P is simple harmonic and calculate the period and amplitude of the motion.
I don't know how to even begin this one,
Any help is really appreciated.
Rob
How about setting up the equation of motion (Newton's 2nd law F=ma, or the Euler-Lagrange equation) and solve?
How would i do this, impulse is applied. Would it be:-0
0.5 = 0.2v, where v is velocity?
Yes. So then you have its velocity in the centre of motion, when t=0 and can hence derive equation of motion.
Thank you both so much!
I finally got the answer.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
