Is there anything wrong with my solution?
  • Thread starter Thread starter Misr
The solution to the equation Cos X * [Cosec (270+X)][tan X] simplifies to -tan X, confirming its correctness. The identity used, Cosec (270+X) = -sec X, is accurately applied in the solution process. There is no indication of alternative solutions being valid within the discussed framework. The conclusion affirms that the derived answer is indeed correct. Overall, the discussion validates the mathematical approach taken.
Misr
Cos X *[Cosec (270+X)][tan X] = ....
Cosec (270+X) = - sec X
Cos X * sec X = 1
Cos X * -Sec X * tan X = - tan X
then the solution is
Cos X *[Cosec (270+X)][tan X] = - tan X
Is it right?Can it has another solution??
Thanks
It is right.
ehild
Great Thanks
