Is there something wrong with this basic mechanics question?
  • Thread starter Thread starter Femme_physics
    Mechanics
The discussion centers on a basic mechanics question regarding reaction forces at a T-shaped support. Participants note that the solution appears to only consider the resultant force and torque from applied loads, omitting reaction forces at point A and the support. Clarification is sought on whether the original question specifically asked for the resultant force and torque due to applied loads. The conclusion reached is that the solution aligns with the interpreted question, despite the lack of context. Overall, understanding the problem's requirements is crucial for accurate analysis.
It looks like the equations are just working out the resultant force and torque due to the applied loads only. Is this the solution? Was the question something like 'work out the resultant force and torque due to the applied loads'?
Actually, Bruce, that makes perfect sense. The problem is that I only got this without the question. But, makes perfect sense. Thanks :)
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
