Is thermodynamics a description rather than a mechanism?
Thermodynamics is viewed as a descriptive framework rather than a mechanistic one, particularly in systems lacking a well-defined temperature. This raises questions about applying thermodynamic laws, such as irreversibility, to such systems. Despite these challenges, many systems can still have a temperature equivalent, allowing for the application of thermodynamic principles. Traffic jams serve as an example of a phase transition that can be analyzed through this lens. Ultimately, the discussion emphasizes the role of Statistical Mechanics in understanding complex systems with numerous interacting components.
kmarinas86
It seems to me that it should be. For example, some systems do not have a well-defined temperature. How do you use laws of physics depending on temperature (such as the law of thermodynamics) when you have a system that doesn't have a well-defined temperature? How do you even go about discussing things like thermodynamic irreversibility when your systems do not have a well-defined temperature?
Science news on Phys.org
You'd be surprised in how many systems you can define a temperature equivalent and apply thermodynamics. Traffic jams can be viewed as a phase transition, for example.
But you are right. It's a mathematical tool. More generally, what you are looking at is Statistical Mechanics, which gives you means of describing system consisting of very large number of particles or sub-systems that interact with each other. Even if interactions are simple, accounting for each one is impossible, but you can still talk about behavior of the system as a whole.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
