Is y a function of x or Sine in f(x)=sinx?
  • Thread starter Thread starter roger
    Sine
In the equation f(x) = sin(x), y is primarily a function of x, as sin(x) is dependent on the value of x. The notation af(x) indicates that the output of the function is scaled by a constant a, while f(ax) means that the input x is scaled before applying the function. Both transformations affect the graph of sin(x) differently; af(x) stretches or compresses the graph vertically, while f(ax) stretches or compresses it horizontally. Neither af(x) nor f(ax) alters the x-axis points where the original sin(x) crosses, as they still pass through the same x-values. Understanding these concepts clarifies the relationship between the function and its transformations.
roger
Hello.
Please can someone help me with this :
f(x)=sinx
For the above, is y a function of x OR is y a function of Sine ?
Secondly, I don't understand what it means by :
a f(x)
and f(ax)
where a is 2.
What I need to know is what does each do to the graph of sin x ?
Also do each of the two af(x) and f(ax) pass the same points on the x-axis as just sinx ?
Please help me
rog
For f(x) = sin(x), f is a function of x.
What is meant by af(x) is that the value of f(x) is multiplied by the constant a. The expression f(ax) means that x is multiplied by the constant a, and then function f is applied to that value.
Hope that helps! :)
f(x)=sin(x) is also a function of sin(x).
It depends how you look at it.
If you take y=sin(x), then f(x)=y. So f is clearly a function of y=sin(x).
However, since sin(x) is a function of x, f is also a function of x.
If f were given by: f(x)=sin(x)+x, it would not be a function of sin(x), but only of x.
