Isobaric Compression: Calculate Q, W and \Delta E
In summary, " and nothing before it:In summary, we have an ideal gas of N particles with mass m and temperature T and volume V. The value of \langle E_{kin} \rangle is \frac{3}{2}N k_B T. During the reversible compression of the gas from volume V to V/2, heat Q is added, work W is done on the gas, and the energy of the gas changes by \Delta E. If the compression is isobaric, Q = N k_B T, W = \frac{N k_B \Delta T}{2}, and \Delta E = \frac{N k_B \Delta T}{2}.
SoggyBottoms
59
We have an ideal gas of N particles with mass m and temperature T and volume V.
a) Calculate [itex]\langle E_{kin} \rangle[/itex]
We now reversibly compress the gas from volume V to V/2. During this compression heat Q is added, work W is done on the gas and the energy of the gas changes by [itex]\Delta E[/itex].
b) Calculate Q, W and [itex]\Delta E[/itex] in case the compression is isobaric.
a) This one I know how to do, the answer is [itex]\langle E_{kin} \rangle = \frac{3}{2}N k_B T[/itex]
b) The change is isobaric and the work done on the gas is positive, so [itex]W = p \Delta V = p(V - \frac{V}{2}) = \frac{N k_B \Delta T}{2}[/itex].
We also have that [itex]\Delta E = \Delta U = C_V \Delta T = \left(\frac{\partial \langle E_{kin} \rangle}{\partial T}\right)_V \Delta T = \frac{N k_B \Delta T}{2}[/itex].
Now: [tex]\Delta Q = \Delta U + \Delta W = \Delta T (\frac{N k_B}{2} + \frac{N k_B}{2}) \\
= N k_B \Delta T[/tex]
So [itex]Q = N k_B T[/itex]
Is this correct?
It is true when the gas is mono-atomic.
It is NKbT1/2. Do not write ΔT.
Cv=3/2 NKb for the mono-atomic gas. What is the change of temperature during the isobaric compression?
ehild
What is isobaric compression?
Isobaric compression is a thermodynamic process in which the pressure of a gas remains constant while its volume decreases, resulting in an increase in temperature.
How do you calculate Q, W and ΔE for isobaric compression?
To calculate Q (heat transfer), you can use the formula Q = nCpΔT, where n is the number of moles of gas, Cp is the specific heat at constant pressure, and ΔT is the change in temperature. To calculate W (work done), you can use the formula W = -PΔV, where P is the constant pressure and ΔV is the change in volume. ΔE (change in internal energy) can be calculated by using the first law of thermodynamics, ΔE = Q - W.
What are some real-life applications of isobaric compression?
Isobaric compression is commonly used in refrigeration and air conditioning systems, as well as in internal combustion engines. It is also used in industrial processes such as natural gas processing and chemical production.
What factors affect the efficiency of isobaric compression?
The efficiency of isobaric compression depends on factors such as the type of gas being compressed, the initial and final temperature and pressure, and the work done on the gas during the process. The efficiency can also be affected by external factors such as friction and heat loss.
What is the difference between isobaric compression and isothermal compression?
The main difference between isobaric and isothermal compression is the change in temperature during the process. Isobaric compression occurs at constant pressure, resulting in an increase in temperature, while isothermal compression occurs at constant temperature, resulting in a decrease in pressure. Additionally, the work done in isothermal compression is greater than in isobaric compression, and the change in internal energy is zero in isothermal compression but not in isobaric compression.
