How can I calculate final pressures in a reversible argon expansion?
marissy
isothermal and adiabatic please help!
Hello,
I have been stuck on this problem for about an hour so any hep would be greatly appreciated!
One mole of argon at 25 degrees C and 1 atm pressure is allowed to expand reversibly t a volume of 50 L (a) isothermally (b) adiabatically. Calculate the final pressure in each case assuming ideal gas behavior.
The answers have been given and they are: (a) 0.489 atm and (b) 0.303 atm
I can't get either a or b for some reason I don't know what I am doing wrong! Please help me :(
Cv = 3/2 R Cp= 5/2 R
Boyle's law
my answers don't even come close...?
Show some work please. It's impossible to show you where you went wrong if you don't show us what you have done.
nevermind i got it all -- I just didnt have my P and V in the right units... anyway i found V1 using the ideal gas law, and the used boyle's law to find P2. Seems so simple when you have the correct units :)
for part b i did PV(5/3)=nRT to find V1 and then used boyle's law to find P2. I got 0.296 for the answer tough. maybe my sig. figs. are off? i can't find out why.
You will have to use the adiabatic condition:
PV^\gamma = \text{constant} \ne nRT
for part b). PV^1 = nRT
AM
Yeah, as AM has said, use the adiabatic condition, along with energy conservation to figure it out.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
