Jacobians change of variable integrals
Liquidxlax
edit* proper problem
change to polar
Integral(0 to infinity)Integral(0 to infinity)e-sqrt(x2 + y2[/SUP)dxdy
the one below isn't the right problem, but i'd still appreciate help on the one below
Make the change of variables u=x-y, v=x+y to evaluate the integral
Integral(0 to 1)dy Integral(0 to (1-y)) e(x-y)(x+y)dx
J = J((x,y)/(u,v)) = partial((x,y)/(u,v)) = det(partial((x,y)/(u,v)))
PROBLEM 1
Not sure how to do a jacobian for this or even if its needed. It looks as if i would just stick in y=rsint x=rcost.
PROBLEM 2
I did the determinant which came to
{1, 1}, {-1, 1} = 2
integral()integral()f|J|dudv = integral()integral()2euvdudv
not sure if this is right, but if it is I'm not sure how to change my limits
thanks
For (2), you need to determine how the area of integration in x and y is transformed to a new area of integration in u and v under the transformations u=x-y and v=x+y. So first draw a simple plot of the area in x and y for:
\int_0^1 \int_0^{1-y} f dxdy
That's just the triangular region between (0,0), (1,0) and (0,1) right? Ok, so just take the line segment along the x-axis from 0 to 1 and see how that line is transformed to a new line in the u-v coordinate system. So, y=0 for that and x goes from 0 to 1 so:
u=x
v=x
v=u
then the line along the real axis from 0 to 1 in the x-y coordinate plane is mapped to the line v=u from u=0 to u=1 in the u-v coordinate plane. Now, do that for the other two lines around this area, and that will give you the new region in the u-v plane to integrate over.
can anyone help with my first question.
You don't "need" the Jacobian if you remember that the "differential of area" in polar coordinates is r drd\theta.
Of course, "r" is the Jacobian:
\left|\begin{array}{cc}\frac{\partial x}{\partial r} & \frac{\partial x}{\partial \theta} \\ \frac{\partial y}{\partial r} & \frac{\partial y}{\partial \theta}\end{array}\right|= \left|\begin{array}{cc}cos(\theta) & -r sin(\theta) \\ sin(\theta) & r cos(\theta)\end{array}\right|= r
yes i seen that in previous chapter in my textbooks. but I'm not sure how easy this question is supposed to be. When i applied what you put up top
re^{-\sqrt{(rcos\vartheta)^{2}+(rsin\vartheta)^{2}}}drd\vartheta
re^sqrt(...) since i can't get the text to sit right
which would reduce to re-r
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
