Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #13,381
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120528/0945_4gouki.html In July, Tepco will remove two fuel assemblies from unit 4's spent fuel pool as a test. These two fuel assemblies will be two of the 204 unused fuel assemblies stored in the pool. Tepco has to check how much these fuel assemblies were damaged by the seawater. In comparison with the spent fuel assemblies, the unused fuel assemblies are comparatively less dangerous to remove.
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02z.pdf Check of soundness of new fuel (unirradiated fuel) in unit 4 spent fuel: This a document from the 6th mid-long term government-Tepco meeting held on 28 May 2012, with details about the removal of unused fuel, and the concerns about corrosion.
http://www.tepco.co.jp/en/press/corp-com/release/2012/1204777_1870.html "Receipt of [NISA] instruction document regarding the seismic safety evaluation of Unit 4 at Fukushima Daiichi Nuclear Power Station"
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02j.pdf Endoscope mission into unit 1's PCV scheduled in the last ten days of August and the first 10 or 20 days of September 2012 (document from the 6th mid-long term government-Tepco meeting held on 28 May 2012). On page 4/8 you can see the two types of cameras that they are going to use. One of them can be tilted and will be used above the grating. The other camera is going to go below the grating.
  • #13,382
Rive said:
Overpressure building up fast inside the building might be enough to explain some unexpected, but less dramatic changes on the webcam picture.
Yes, there seems to be a slight expansion of the building in frame #-4 to #-1 due to overpressure (by the leakage?). The next plausible step suggested MadderDoc: "Hydrogen jets are prone to autoignition[...]". In the next frame #0 (after autoignition?) the building contracts on the upper floor (by eaten up oxygen 2H2+O2->2H2O?). Roof parts sucked-in/collapsing? The roof panels found around the SFP could be also from this early implosion. The later fireball from above had another downward component onto the panels.
In #0 and #1 we see the beginning of the expansion phase IMHO, when everything heats up by the H2/O2-reaction, and devastions as in your szenario happen:
MadderDoc said:
More likely the concrete pillars were left temporarily standing while the panels were blown away, only to tumble to the ground in good order, in connection with the total collapse of the roof.
Rive said:
And such kind of flame would give you that kind of constant heat what the blast can't (source of the heat marks on the roof components?).
MadderDoc said:
However, likely the water in the PCV would be flash boiling once the hydrogen pressure were to be relieved, which would make up for a massive temporary source of steam.
Good points, but its hard for me to imagine, that this huge mushroom cloud has its source in three or four of these tight leaks in the gate area:
  • #13,383
Uagrepus said:
<..>its hard for me to imagine, that this huge mushroom cloud has its source in three or four of these tight leaks in the gate area:
I'd say that the source of the huge mushroom cloud is the huge vertically rising eruption cloud that was initially formed over the building. Expressed like that it becomes clear that a considerable explosive expansion is involved, through a restricted opening pointing generally up. In short, there is vertical thrust. When we first see the initial eruption cloud it has an ascent rate of impressive 75 m/s (unlike the mushroom cloud which emerges from the top of the eruption cloud at about 5 seconds after the blast; the continued rise of the mushroom cloud is at a more leisurely yet still impressive pace of about 20 m/s.
It is difficult to imagine the scale of things in these reactor buildings. I still can only abstractly grasp that the house I am sitting in, including the annex out in the back could be put into that equipment pool, and it wouldn't even be a tight fit.. The 'tight leak' the steam is apparently escaping from in that photo is a gap of about 0.2 x 1 meter. Now I am not at all sure this gap was not produced by the erupting steam, rather than pre-existed it to allow it to escape, however in any case this ultimately ends out in a question of mass flow. We would be looking at in the order of magnitude 100 tons of liquid water 'wanting' to come out and expand into 100000 cubic meters of steam. This is heavy stuff, a considerable work force. We would need it to escape over a brief span of time, say 2 seconds. Assuming 5 'tight leaks', that would be an opening of 1 square meter, and a mass flow through that opening of about 50 tons/second.
  • #13,384
MadderDoc said:
[...] huge vertically rising eruption cloud that was initially formed over the building.
"Over the building" is not easy to locate in an exploding building, but there might be the key. The explosion kinetics changed IMHO in the moment, when most of the roof was open from the first implosion/explosion more or less inside the building. The two fireballs SE and NE mark the first explosion-events in this transition from inner to outer space on top of the building. While these events happened, most likely the eruption of hydrogen and steam from the PCV continued. Eventually being dispersed from the shockwaves around the eruption cloud rises and explodes (now surrounded by and mixed with enough air) over the structures formerly known as roof.
  • #13,385
Yes, alright, over the building is not too precise. In this animation, three small red dots are overlayed to mark the direction to the visible NW, SW, and SE corner of the building, thus roughly outlining the confines of the original building when things get messy in the images.
Frame 0 is the first frame which unambiguously shows damage to the building. I think it is safe to assume that between frame -1 and frame 0, an explosive combustion of hydrogen occurred inside the building. In frame 1 we see hydrogen apparently combusting outside the confines of the building, in white hot intensity. As regards the direction to this visual flame, it could be from either the south or the east wall of the SE corner. The three-lobed shape of the flame would indicate to me that it is from the east wall. The condensed combustion gases from this flame is, I believe, what we see eventually develop into a notably _whitish_ 'wart' in frame no 35, to the right bottom downwind side of the developing central eruption cloud. It would seem to me most likely from the observation, that between frame 0 and frame 1, hydrogen escaped from the building from its SE corner in an upwards easterly direction and burned there, outside the confines of the building.
Seeing hydrogen could escape from the building, it would seem to be implied there is hydrogen in it, so either hydrogen is burning still inside the building during frame 0-1, or frame 1 could represent a flash back to re-ignite hydrogen inside a oxygen starved building, now being fed air through openings in the roof.
  • #13,386
tsutsuji said:
Thanks for the news tsutsuji-san, quite interesting!
  • #13,387
The 6th mid long term meeting was held yesterday: http://www.meti.go.jp/earthquake/nuclear/20120528_02.html
The 5th meeting (23 April 2012) : https://www.physicsforums.com/showpost.php?p=3881074&postcount=12979
The 4th meeting (28 March 2012) : https://www.physicsforums.com/showpost.php?p=3838108&postcount=12764
The 3rd meeting (27 February 2012) has been translated into English on Tepco's website : http://www.tepco.co.jp/en/nu/fukushima-np/roadmap/conference-e.html
28 May 2012 government-Tokyo Electric mid and long term response committee, steering committee (6th meeting)
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02a.pdf Agenda
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02b.pdf Participants
Document 1
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02c.pdf Abstract of the proceedings of 5th steering committee meeting
Document 2: Plant status
Document 2-1: Plant status
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02d.pdf Plant parameters
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02e.pdf Accumulated water storage status
Document 3 Study and execution of each special plan
3-1 Cooling by closed loop water injection
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02f.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02g.pdf Summer season countermeasures for the reactor water injection equipments [page 3/5: unit 2's reactor temperature is expected to reach 65°C in July when the weather is the hottest]
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02h.pdf Results of the surveys on location concerning the environment improvement for the purpose of installing alternative thermometers in unit 2's RPV.
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02j.pdf Execution of internal survey into unit 1 primary containment vessel (PCV) [endoscope mission in August-September 2012]
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02k.pdf Results of the survey into unit 3's TIP room in reactor building first floor
3-2 Treatment of accumulated water
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02m.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02n.pdf Subdrain purification test report (report No. 1)3-3 Countermeasures to reduce environmental radiations
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02p.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02q.pdf Management of debris, cut down trees, generated by the response to the accident
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02r.pdf Status of the preparatory works of the soil-covered temporary storage facility
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02s.pdf Countermeasures against fire for the cut down trees
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02t.pdf Consequences on water quality of the covering of the sea floor in the harbour
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02u.pdf Results of evaluation of additional releases from reactor building's primary containment vessels
3-4 Improvement of working conditions
3-5 Countermeasures for spent fuels pools
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02w.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02x.pdf Debris removal work, reactor building top part, unit 3
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02y.pdf Debris removal work, reactor building top part, unit 4
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02z.pdf Check of soundness of new fuel (unirradiated fuel) in unit 4 spent fuel pool
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02aa.pdf Results of inspection aimed at checking the soundness of Fukushima Daiichi unit 4's reactor building
3-6 Preparations for fuel debris removal
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02bb.pdf Schedule [a robot mission into unit 3's torus room is scheduled for the last 10 days of June]
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02cc.pdf Results of survey by robots into unit 1's reactor building: "development of remote controlled decontamination techniques inside buildings"
3-7 treatment and disposal of radioactive waste
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02dd.pdf Schedule
Document 4
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02ee.pdf roadmap progress (abstract)
28 May 2012 government-Tokyo Electric mid and long term response committee, technical development progress headquarters (6th meeting) (http://www.meti.go.jp/earthquake/nuclear/20120528_01.html )
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01a.pdf Agenda
Document 1
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01b.pdf Abstract of the proceedings of 5th meeting
Document 2
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01c.pdf Fiscal 2012 research and development plan (draft)
Spent fuel pool countermeasures working team
Document 2-1 http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01d.pdf Evaluation of long term soundess of the fuel assemblies removed from spent fuel pools (Fiscal 2012 and general plan)
Fuel debris removal preparation working team
Document 2-2-1 http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01e.pdf Development of remote controlled decontamination techniques inside buildings (Fiscal 2012 and general plan)
Document 2-2-2 http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01f.pdf Development of techniques to determine the leakage points inside PCVs (Fiscal 2012 and general plan)
Document 2-2-3 http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01g.pdf Development of techniques to repair PCVs (Fiscal 2012 and general plan)
Document 2-2-4 http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01h.pdf Development of techniques to survey inside PCVs (Fiscal 2012 and general plan)
Document 2-2-5 http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01j.pdf Development of techniques to assess the soundness of RPVs/PCVs (Fiscal 2012 and general plan)
Document 2-2-6 http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01k.pdf Development of techniques to manage debris criticality (Fiscal 2012 and general plan)
Document 2-2-7 http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01m.pdf Grasping the status inside reactors by the upgrading of accident progression analysis techniques (Fiscal 2012 and general plan)
Document 2-2-8 http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01n.pdf Characterization by using mock-up debris and development of debris treatment techniques (Fiscal 2012 and general plan)
Document 2-2-9 http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01p.pdf Building of material accountancy for fuel debris (Fiscal 2012 and general plan)
Treatment and disposal of radioactive waste working team
Document 2-3-1 http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01q.pdf Development of treatment and disposal techniques for the secondary waste products generated by the contaminated water treatment (Fiscal 2012 and general plan)
Document 2-3-2 http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01r.pdf Development of treatment and disposal techniques for radioactive waste (Fiscal 2012 and general plan)
Document 3
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01s.pdf Result of the public appeal for a technical catalogue in relation with the machinery and equipments used in the preparation of the fuel debris removal, toward the decommissionning process of Fukushima Daiichi units 1,2,3 and 4 (Tokyo Electric Power Company)
Document 4
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01t.pdf Status of the study of the conseption of research basic points
Attachment: http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_01u.pdf Symposium on machinery and equipments toward the decommissionning process of Fukushima Daiichi [held by the Japan Society of Mechanical Engineers on 27 May 2012][page 2: 2012 IEEE International Conference on Robotics and Automation (ICRA 2012) Symposium on Robotic Solutions Toward Nuclear Decommission May 18 (Friday), 2012 in Saint Paul, USA]
  • #13,388
I would vote for 2 east and 1 south, forming the "three-lobed shape of the flame":
Most of the roof-panels in the SE-corner of U3 are oriented east-west and many were thrown to the turbine-building following this direction.
  • #13,389
http://i49.tinypic.com/104l3cl.png
Agreed. From about frame 4, destruction of the south wall appears to have progressed to let the flame burn more generally out through the top of that wall. During frame 0-4, there seems to be no discontinuity in the exploding motion in the rest of the building that is set going in frame 0. From about frame 5 the fuel supply for the flame seems to be gradually cut of, while the development of the eruption cloud center is taking over the scene. Concurrently with this change material seems to start being ejected from a lower part (likely 4th floor) of the west wall.
  • #13,390
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120526_01-e.pdf Accumulated water in unit 3 Radiation Waste Underground Storage Facility Building: "Accumulated water amount is approx. 610m3 in the entire building (including the unchecked areas). The property of the accumulated water is assumed to be either groundwater or rainwater".
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120529_03-e.pdf Plant Status of Fukushima Daiichi Nuclear Power Station, May 29, 2012:
May 28, 2012: The following Unit 2 PCV thermometers (monitored in accordance with Article 138 of the Technical Specification) indicated significant temperature changes (stepwise increase/decrease in temperature). Upon our temperature trend evaluation, we found that these temperature changes may have been caused by abnormality with the thermometers. On May 29, direct resistance measurement was done on these thermometers, and reliability evaluation will also be done. According to the radioactivity density of short half-life nuclides, there is no possibility of re-criticality.
- RETURN AIR DRYWELL COOLER (TE-16-114A) [Monitored] 58.0℃→64.7℃
- RETURN AIR DRYWELL COOLER (TE-16-114D) [Monitored] 43.7℃→47.6℃
- SUPPLY AIR D/W COOLER HVH 2-16A (TE-16-114F #1) [Reference] 41.0℃→35.0℃
- SUPPLY AIR D/W COOLER HVH 2-16C (TE-16-114H #1) [Monitored] 52.1℃→48.2℃
(Above data was acquired from 5:00 PM to 11:00 PM on May 28)
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120529_02-e.pdf Temperature inside the PCV of Unit 2, Fukushima Daiichi NPS (6 hour data)
  • #13,391
Most video footage of the explosion which have been or remain still available have been quite unfortunately re-sampled and re-compressed from an original 50Hz interlaced TV recording, to e.g. the commonly found 29.968fps on youtube. Unavoidably such a conversion produces horrible artefacts, and comes with loss and blending of the original information.
From a short lineage recording of an original TV broadcast, it has been possible to produce this http://www.gyldengrisgaard.eu/fuku_docs/unit3cloud50fps/ . Since the original is 50 Hz interlaced, utilising both fields yields a temporal resolution of 50 fps, or 20 milliseconds per frame. You won't find this better anywhere else on internet :-)
Those of you who have taken special interest in the explosion will note particularly the extra temporal resolution at around the time of the first signs of something happening with the building.
  • #13,393
  • #13,394
Translation:
4/8
5/8
6/8
  • #13,395
Translation:
7/8
8/8
  • #13,396
  • #13,397
tsutsuji said:
Translation:
Very thanks for the translation.
What do you think, would it worth to contact them somehow for suggesting a lights-off time during the survey? Based on some cherenkov (background) lights the cam might be able to pick up more details even in 'rainy' environment than with the small LEDs on the camera.
  • #13,398
Joffan said:
Thanks very much for the translation Tsutsuji. I'd still prefer one of these snake robots doing the inspection work.
They did not talk specifically about a snake bot, but in the March report they were open about "self propulsion of the extremity" in case the conventional endoscope technique is not workable for the insertion of the alternative thermometers at unit 2 :
tsutsuji said:
(3) mechanism for the inserted thermocouple, etc. (features to be developped)
* As the stroke is long, insertion might not be possible by pushing force only
Study of insertion mechanism
* Reducing the candidates to a short list, the features are checked in mock-up tests (it is possible that universal products won't pass the tests)
* Insertion resistance control method when insertion is performed in accordance with the pipe (it is necessary to feel elbows, orifices)
Solutions to (3)
* testing of the characteristics of materials and machinery ; suitability checking with mock-up
* If suitable materials and machinery don't exist, it is necessary to develop new ones as follows:
⇒self propulsion of the extremity (a new development is necessary, but as the diameter is small, it is difficult)
⇒self adjustment of the extremity (development of a mechanism to change the direction of the extremity so that the insertion is performed in accordance with an elbow, etc.)
⇒auxiliary mechanisms (study of insertion auxiliary methods using compressed gas, compressed water, etc.)
however, the mock-up tests performed last month showed that the conventional endoscope technique is likely to be OK or nearly OK.
Can radio waves penetrate through the PCV wall ? If not, the snake would still need a cable to send data and to receive control signals.
  • #13,399
The snake robot shown was on an umbilical - probably for power, data, and pull-back. They'd probably need to protect the edges of any drilled holes.
  • #13,400
Fresh fuel would not be dangerous itself - I've handled fresh fuel (even pellets) with gloves - however, the surfaces would be contaminated with whatever radionuclides were deposited from any fuel that failed in the pool (or from whatever fission products were released to the spent fuel pool) during the accident.
Ordinarily, damaged fresh fuel is often returned to the manufacturer (in this case, after decontamination) and defueled. The UO2 is recycled and the Zircaloy is scrapped. It could be remelted and recycled if the impurities are less than ASTM spec.
  • #13,401
tsutsuji said:
http://www.meti.go.jp/earthquake/nuclear/pdf/120528/120528_02z.pdf Check of soundness of new fuel (unirradiated fuel) in unit 4 spent fuel pool<..>
I wonder what kind of sick paranoia has led to the blocking out of the rack number in the photo on page 5 of that document.
(It is rack number 26, if someone should want to know.)
  • #13,402
  • #13,403
Translation:
4/8
5/8
6/8
  • #13,404
Translation:
7/8
8/8
  • #13,405
MadderDoc said:
They are from the west wall of the pool, 4th floor, the same wall section which the recent announcement is showing a lower portion of in a sharp angle, the photo bottom right in
http://2.bp.blogspot.com/-e4hpgfA9W...jMc2lWo/s1600/fukushimareactor4SFPMay25-7.JPG
(The photos are from the original survey of Unit 4 damages done in Nov. 2011, source:
http://photo.tepco.co.jp/en/date/2011/201111-e/111110_01e.html)
Perhaps I'm being too finiky but the images from 2011 don't quite show the "west wall" of the SFP as such.
The 2011 images cover the areas marked in green here.
  • #13,406
turi said:
Thanks for the link. Does anyone know what the vertical orange "thing" in the unprocessed image is? The processed image doesn't have such an artifact. What kind of processing is done anyway? Adjustment for the distance of the radiation source from the camera?
I don't know what the artifact is but the "unprocessed" & "processed" images are framed differently so perhaps not even the same actual image. The second pair look like they ARE the same image, pre and post processing.
http://www.tepco.co.jp/en/nu/fukushi...20525_06-e.pdf
  • #13,407
MadderDoc said:
I of course agree on all points above. So there's a document which includes photos for apparent documentation which are totally unsuitable as evidence for or against cracks in the context of the inquiry, but it is perfectly alright with Tepco if the reader will conclude from looking at the photos that there are no cracks there at all. In fact that appears to be the intention of the document. I am not worried about that crack, but I don't like to be bs'ed.
On the other hand, the possible crack we have observed in the 2011 images could be easily misconstrued so tepco kept it out of frame as it's not relevant to the SFP wall as such. That the possible crack we have seen is closer to the PCV than the SFP is another thing.
Edit: Of interest perhaps is that the translation I got may not be correct but the Japanese Tepco document is talking about "local bulges". not cracks.
  • #13,408
http://i1185.photobucket.com/albums/z360/fukuwest/misc/u4sfpwalls.png
Well, whatever the terminology, the 2011 photos are of the same wall section as shown in the bottom right photo in the recent Tepco announcement:
  • #13,409
MadderDoc said:
Something is necessary to explain the particular damages of the SE corner of the roof.
Did anyone suggest that the extensive damage might be due to the debris falling from the explosion, a lot of which seemed to fall on the SE corner of the RB?
Or is this a different aspect of the damage we are talking about?
Marked video clip
  • #13,410
Marked video clip
I don't remember anyone suggesting that, but I've had the thought myself, however I left it at the wayside, as it did not appear to me to be sufficient to explain those extensive damages. It would seem weird to assume the fire phenomenon of that corner didn't leave its special marks of damage, as weird as assuming that tons of debris hitting the area from aloft seconds later didn't add to it.
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
467K
21K
  • · Replies 763 ·
282K
  • · Replies 38 ·
16K
12K
