Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #3,721
|Fred said:
yep elevator is human service, as you can see remains on the roof tops of unit 1.
I'm not convince the location is the same (N/W) for unit 4, I think I could be S/W.
Also I'm not convince that there is a temporary cast pool, sofar I'm voting for cast operation handled in the main SFP.
I believe the is an un accounted for crane structure above the utility pool adjacent to the reactor "opening" on unit 4
what is the truck size whit object at the bottom south of the west wall..
there is a fair amount of roof structure debrit on the south part of unit 4 where do they come from, the south part of the roof does not seems missing that many parts.
|Fred -
I believe it is probably some sort of insulation material. I also seem to recall a major HVAC ductwork structure overhead at the SFP end of the service floor on one of the priors.
Something just doesn't add up. If the fuel in SFP4 was only partially uncovered and most was not damaged, it just doesn't seem to match the degree of destruction seen in Bldg 4.
Here is another HVAC SWAG to think about . . .
Rather than the blast at Bldg 3 pushing anything through the connecting ductwork back into Unit 4, is it possible (perhaps even likely) that the blast at Bldg 3 would send significant pressure pulse of hot gas into the vent system, then up and out the vertical stack, in addition, of course, to the rest of the blast damage? That being the case, then, could a Venturi effect from the vertical stack shared by Units 3, 4 have created a sudden, transient negative pressure in the lower portions of Bldg 4 through the connecting vent system?
If so, then the a large volume of air is sucked out of the lower floors of Bldg 4, and a large volume of hydrogen gas that had accumulated above might be sucked downward into the building -- like smoke being pulled back into the bowl from one big puff off a giant briar pipe.
Pressure equalizes, hydrogen again rises, but it is now possible for it to accumulate in pockets along the ceilings of the lower floors. The partially exposed fuel in SFP4 continues to release more hydrogen, replenishing the fraction of hydrogen lost from the upper building. When, eventually, the hydrogen + oxygen mix explodes, then both the upper and lower floors are involved in the resulting blast.
(Talk about conspiracy theories . . .)
Could the pipe have held together long enough for that to happen? . . .
  • #3,722
MadderDoc said:
The pixel-resolution of the thermal imagery I've seen spares about 0.2 m/pixel on the ground. With dispersion and such the real resolution must be worse, I'd reckon no better than 0.4 m/pixel and I think I am being generous.
Anyhow, what is that thing we see glowing -- all alone by itself :-) -- between unit 3 and 4, on the imagery from March 25th (attached thermal image and scale)?
Concrete truck?
  • #3,723
TCups said:
|Fred -
I don't think that could happen. Firstly you need a specific geometry for venturi effect, secondarily, even if the pipe is at absolute vacuum, I do not believe it would suck in enough air. The air speed at the leak into vacuum (a hole in a space station) is ~= speed of sound. Just look at cross-section of pipe versus cross-section of entire upper floor to determine air inflow rate here. You're better off speculating that the wind blew through some hole and blew hydrogen down, except that doesn't make sense either because a hole would rather let hydrogen out.
  • #3,724
Krikkosnack said:
in Tokaimura Criticality Accident
http://www.world-nuclear.org/info/inf37.html
The criticality continued intermittently for about 20 hours. It appears that as the solution boiled vigorously, voids formed and criticality ceased, but as it cooled and voids disappeared, the reaction resumed. The reaction was stopped when cooling water surrounding the precipitation tank was drained away, since this water provided a neutron reflector. Boric acid solution (neutron absorber) was finally was added to the tank to ensure that the contents remained subcritical. These operations exposed 27 workers to some radioactivity. The next task was to install shielding to protect people outside the building from gamma radiation from the fission products in the tank. Neutron radiation had ceased.
"mumble...mumble"
Now imagine this with many meters of water column on top of it, preventing quick expansion of bubbles. Then imagine this in a huge volume, where rapid formation of bubbles on one side compresses bubbles on another side.
Other very interesting reading (article from 2007):
http://search.japantimes.co.jp/cgi-bin/nn20070323a3.html
  • #3,725
Storage tanks, pumps and monitoring equipment from Savannah River Site will be shipped from South Carolina to Japan to help in the battle to stabilize the damaged nuclear reactors at Fukushima.
Special
R-56 diagram: A high-tech, self-contained piece of equipment known as a “Radioactive Liquid Transport Assembly,” or LR-56, is being sent to Japan to help government officials who are monitoring contamination levels in the vicinity of the Fukushima nuclear power plant.
"This is what we can send them at this point to support their activities," said Jim Giusti, a U.S. Energy Department spokesman.
Equipment is also being gathered from other federal nuclear sites around the county, he said. Its transfer is being expedited as a "government to government diplomatic exchange" that will convey the gear directly to the Japanese government.
The primary items from SRS, identified by its management contractor, Savannah River Nuclear Solutions, include a "radioactive liquid transport assembly," a high-tech, self-contained, trailer housing a 1,000 gallon tank, pumps and a monitoring system. http://chronicle.augusta.com/latest-news/2011-04-14/srs-equipment-headed-japan?v=1302791614
  • #3,726
I also see a big green machine at the north end, over the utility pool.
I have no idea what the truck size object is. From looking at imagery from before the explosion I get the impression that it was there then, too. (see attached)
As to the debris at the south side, I believe it is a fair amount of the roof covering, on top of the concrete pillars and panels from the holes in the wall above (certainly mixed with assorted foobar, but quantitatively a small proportion)
  • #3,727
OK, how about just the straightforward mechanism of a large blast with a vertical plume at Bldg 3 sucking the ground air upward and creating a large, but transient negative pressure region at "ground zero"? I am grasping here for some mechanism to explain a transient, negative pressure gradient in the lower portions of Bldg 4 . . .
  • #3,728
Giordano said:
Concrete truck?
No, the resolution is actually pretty good, but there is "blooming" of the heat signatures. The hot object is probably about 25ºC and looks to be about where debris have been cleared and a new "plate" of some sort is now on the ground, near the center of this photo.
In the thermal imagery, you can see the pipe, the tower, and actually, a fair amount of ground detail in the blue scale.
  • #3,729
Giordano said:
Concrete truck?
I don't think so. The thermal image with this clear hotspot in the yard between unit 3 and 4 was taken somewhere between 6.34 am and 07.19 am on March 25th. It was a cold morning, as you can well see from the image, only about 2 deg. C. The location is right under some huge pipes, not exactly where one would think to place a concrete truck. Anyhow, Tepco states clearly that the concrete pump was not used at that time for doing anything to unit 3.
'Today's work for cooling the spent fuel pools
- At approximately 5:35 am, we started injecting seawater into the fuel
spent pool of Unit 3, using Fuel Pool Cooling and Filtering(clean up)
system (FPC) and finished at 4:05 pm.
- At around 2:35 pm, spraying to unit 4 by concrete pump track and
finished at around 5:30 pm.
- We are considering further spraying at other units and others subject
to the conditions of spent fuel pools.' (Tepco press release on the morning of March 25th)
  • #3,730
Astronuc said:
That is the intent. However, if there are leaks in the piping systems connected to the reactor pressure vessel (RPV), then the water level achieved may not cover the core, which is the objective. In such an event, they would be expected to flood the drywell in order to ensure that the water level is maintained in the RPV. However, if there are leaks in containment, then they may not be able to flood containment to the elevation required to cover the core. Then there is the matter of the evaporation of the water, which must be made up.
According to the available data, the water level measurements indicate that the core is not completely covered. But then, it could be that the instruments have been damaged (?).
Could it also be that core no longer exists at that height? IOW, has 50+% of the core relocated lower in the RPV? (All three units.)
  • #3,731
of bldg4 ... but not of bldg 2? Also, the explosion of #4 happened at different time.
I think at this point we sadly have to include some conspiracy/coverup in the explanation. But this also means we have no real data to make explanation from.
  • #3,732
Giordano said:
Concrete truck?
Something big, hot - and mobile, that's for sure. The other thermal images shows no hotspots at the same point.
But: there are earlier aerial photos (I could not find the date, but here is a link: http://cryptome.org/eyeball/daiichi-npp/pict6.jpg), showing a broken pipe of the venting system and some debris near the hotspot: and on later images the same pipe is near the reactor building and the area is clean from debris.
So: I think the thermal image shows the truck which cleaned up the area.
  • #3,733
Because nothing says everything is under control like the government doing a runner
http://www.novinite.com/view_news.php?id=127294"
As powerful earthquakes continue to jolt Japan and radiation levels near Tokyo are rising, the Asian country's authorities are considering moving the capital to another city.
The most probable location for a new capital are Osaka and Nagoya, according to ITAR-TASS. Both cities are located near international airports.
The main conditions the new capital has to provide are a population over 50 000 and a sufficient capacity to accommodate the parliament, the government, the Emperor's residency and the foreign diplomatic missions.
  • #3,734
? Are we talking about the same thermal image?
https://www.physicsforums.com/attachment.php?attachmentid=34365&d=1302808699
If so, then I don't see anything even near the size of a concrete truck between Bldg 3 and 4.
  • #3,735
Are you referring to this thermal image attached to the original post asking about the object between Bldg 3 and 4?
If so, something is way off. Nothing remotely resembling a truck is in this thermal image.
  • #3,737
  • #3,738
PietKuip said:
Increasing iodine in unit 2, decreasing (as it should) in the other drains.
As far as I can see, it's increasing in unit 1 as well... what's with the constantly rising core pressure and missing drywell radiation in Unit 1 which can be observed in Jorge's plot?
  • #3,739
criticality - i do expect criticality. Someone posted report where they said the fuel above water line turned into small dust on the bottom of PV. It's 3 reactors with significant fraction of fuel on the bottom of pv, what are the chances that none will go critical? The dust fuel can get stirred into water and go critical in that form, if it is not critical as a lump. They better be borating the water, but as they don't have cooling loop, they'd run out of boron-10 fairly quick. Unless they cool it by evaporation, in which case they'd be venting into atmosphere a lot of stuff.
you got to be kidding me. That better be a joke.
  • #3,740
Giordano said:
Concrete truck?
I do believe the area had been cleared for passage already by March 24th. See 'before and after 'cleanup'' attached. The position of the hotspot is at the far foot of the exhaust tower.
On later thermal images, it appears that the pool has been regularly douched from a firetruck about at the time of thermography, and the truck blocks the view to the hotspot.
  • #3,741
Astronuc said:
A subcritical (k < 1) system decreases in power to some low level which is that left by spontaneous fissions or other neutron sources. A subcritical system would not cause a steam explosion.
I must be using the wrong terms. Presumably your k is the expected number of first-generation children of a single neutron introduced in the mass. If k > 1, as you say, the number of fissions increases exponentially in time, and we get a standard nuclear explosion.
On the other hand, if k < 1, then a spontaneous neutron created within the mass will generate T = k + k^2 + k^3 + ... = k/(1 - k) fissions in total, before all neutrons get lost. When k << 1, T is approximately k and therefore small too. However, as k aproaches 1 the number of fissions T created by one spontaneous neutron gets arbitrarily large. For k = 0.9, each initial neutron generates 9 fission events, on the average; for k = 0.99, it is 99 fissions. The chain reaction for one initial neutron indeed will die off, but a steady supply of N spontaneous neutrons per second will produce N*T fissions per second.
Of course this ignores the effects of energy, direction, and location within the mass. But the point is that fission can generate an arbitrarily large amount of heat power even if k < 1. Indeed, in a woking reactor the goal is to keep the net k below but very close to 1. Isn't that so?
(Wikipedia says that in a reactor one has "delayed criticality", i.e. k > 1 but secondary fissions are "delayed" so that the process becomes stable. This does not seem right: if the net k is greater than 1, delaying the children fissions will still yield an exponential growth with a smaller but still positive rate, growing ever faster without limit. Isn't that so?)
Astronuc said:
The famous bare critical sphere demonstration, e.g., the one in which Louis Slotin died, was a supercritical assembly with nearly pure fissile material. Such material is not used in power reactors.
Did Stotin's configuration really get supercritical? As I understand, it would be hard to tell the difference between (k slighty below 1) and (k slightly above 1) for a very short time. In both cases the rate of fission would be very high. The difference is that in the second case the radiation would have increased exponentially if the assembly had not been undone; whereas in the first case the reaction would remain at a high but constant level indefinitely.
Astronuc said:
Only if a system went supercritical and achieve a certain power density very rapidly, would there be a possibility of a steam explosion, and likely the system would have to be prompt critical with a significant amount of positive reactivity (i.e., k >> 1.006), which is not the case at Fukushima.
What I was thinking is the fllowing. I am assuming a dense rack design like that in the Czech re-acking paper, with walls of boral (boron carbide powder clad in aluminum) sandwiched in steel around each assembly.
0. Pool cooling pumps stop.
1. Pool water boils off, and the assemblies become partly dry.
2. The dry parts of the assemblies slowly get hotter by decay heat (k still <<1).
3 When the temperature reaches 660C, the aluminum in the boral melts.
4. The boron carbide powder shifts inside the steel walls, creating "neutron holes".
5. As neutron absorption decreases, the k factor starts to increase.
6. Larger k means increased heat production that means more boral melting and larger k.
8. As k approaches 1 the temperature of the fuel slugs shoots up to >>1800C.
9. A few seconds later, fuel tubes and steel jackets melt.
10. The molten mass falls onto the remaining water causing a steam explosion.
11. The explosion blows away the overheated fuel and stops the chain reaction.
Note that this scenario does not require k>1, but only k large enough for fission to cause fast heating of (some part of) the fuel, from ~700C to over 1800C.
Does it make sense?
  • #3,742
I think it can get to well over 1800 celsius with good ol chemistry alone - zirconium in steam exothermic reaction, then zirconium-uranium dioxide reaction, and of course the simple zirconium-air reaction. The fission would be bad though. Also, it probably wouldn't fission without water, unless aluminium works as moderator. However, when the fuel falls down between the rods - who knows. They'd better have proof it couldn't happen.
  • #3,743
densha_otoko said:
BTW, according to some Japanese documents I read a few days ago (cannot find now) the 4/08 R1 Drywell radiation reading was actually 187 Sv/h, not EXACTLY 100 as reported in some places. A Japanese source said 100 was the max limit reportable for some reason, but a conversion of the raw readings data released by Tepco translated to 187 Sv/h.
The "most pristine" source I have is the faxes that are included in the twice-daily NISA press releases. Those faxes have been reporting the CAMS readings in Sv/h in exponential format; the only conversion I did was to fixed format, x100. Do you recall the source of those "raw readings"?
  • #3,744
OK, understand, but - - -
The thermal image originally posted was this one. I have recombined the window/level scale and annotated what I see as Bldg 4, Bldg 3, Tower, and Pipe (darker = colder = water in pipe?). The pipe just to the east of the tower is near ambient temp (empty). The only hot spot between Bldg 3 and Bldg 4 (circled) is relatively small, east of the pipe next to the tower, and only somewhere near 25ºC. If the thermal image pre-dates the "cleaned up" image, then the hot spot is about where a large square of metal plate or plywood has been laid. I see nothing on the thermal image even vaguely resembling a truck, blocking activity or otherwise.
I have rotated your before/after clean up image to match the orientation of the thermal image, though the angle is different, and I have indicated the approximate location of the small hot spot between Bldg 3 and 4.
  • #3,745
They have been using remote controlled excavators to clear away debris . There burying some of the hotter stuff and putting a lot of debris in small containers taking it to a temporary storage point just to the west side of the reactor buildings near a storage shed . (approx. 2.5mSv/h around containers) that have been filled .
  • #3,746
I once was in a test building open in the back to the outside when a large shock wave passed the building and promptly sucked out the windows as it passed.
I'm not sure if that's the same effect you're describing.
  • #3,747
Air movement away from one location will create a low pressure at that spot.
Picture a fire 'drafting' in air to the flame as heated air moves up.
That's what an explosion is basically. Although it typically seeks relief in all directions or the easiest path of resistance.
The question here is what pressure gradients were created by what explosions and resistance.
There could have been a variety of powerful air movements inside Reactor Building 3.
  • #3,748
Reporting from Futaba, Japan—
The radiation gauge beeped, signaling that isotopes were in the atmosphere.
As our SUV followed a line of electricity towers marching across deserted farmland, we made an agreement: If the dosimeter hit 15, we'd turn around. The device inched up to 12, its faint beep seeming more like a scream. Each time, edgily, we called out the number.
Thirteen.
The ventilation was off and the windows were sealed tight, even though the afternoon was warm. With our heads covered and our mouths sheathed in breathing masks, the SUV became a sauna as we bumped along roads with cracks as wide as a man's head.
The minutes ticked by.
Fourteen.
Miles past a police checkpoint, we finally saw it. In Japanese and English, a large blue sign. Fukushima, the place where no one else in the world wanted to be.http://www.latimes.com/news/nationworld/world/la-fg-japan-fukushima-20110415,0,271475.story
  • #3,749
Hello to everyone
Hello, all. This is my first post but I have been following the discussions closely ever since finding out about this Physics Forums thread from reading over on The Oil Drum. That was a little less than 2 weeks ago, and I've been catching up on this thread (and eschewing TOD threads on Fukushima) ever since.
I knew this thread would be a barn burner when I saw post #44 in this thread from way back on 13 March (page 3) :smile:
Angry Citizen said:
A shame, because this is shaping up to be a textbook example of nuclear safety. Most of the backups and emergency procedures failed, yet it looks like little radiation has been or will be released. Considering this is a forty year plant that happened to be very near one of the largest earthquakes ever recorded, I'd say nuclear power is vindicating itself. Of course, I don't expect the ignorant masses to understand what's really going on. I swear, some people hate nuclear power just because it's got ATOMS.
In the last 10 days or so I have read every single post in this thread. The commentary and contributions of so many people are wonderful and, in all seriousness, if there was some kind of an award for internet journalism for excellence in coverage of a current news topic, this thread deserves it.
I have a few things to contribute but will let this post stand as-is for now by way of introducing myself. My background is in engineering, albeit computer systems and not mechanical, nuclear, electrical or chemical (did I miss any?). Anyway, more to come and I hope I'm not too late to the party, so to speak. I realize the Japanese people don't have too much to celebrate these last 7 weeks.
  • #3,750
Looks a bit like steam coming out of #4 this afternoon. Probably temps still increasing. It is a low-res image updated hourly but easier to see 3 and 4 than 1 and 2. http://www.tepco.co.jp/nu/f1-np/camera/index-j.html.
On most normal weather days you only see the steam in early morning hours when the wind is dead at sunrise between onshore and offshore flow change. Over the past couple hourly frames I have seen some steam coming from #4 (near the closest tower). This despite today's stronger north winds of 5 to 7 meters per sec this mid-day in around the plant http://www.mapion.co.jp/weather/admi/07/07541.html.
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
471K
21K
  • · Replies 763 ·
284K
  • · Replies 38 ·
17K
12K
