Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #6,241
|Fred said:
You may be putting word into the article "TEPCO suspects the blueprint is one of its internal documents, if proven to be genuine,the document is subject to the restrictions imposed under its regulations on nuclear materials protection."
Perhaps they don't have a literal list of enemies, but it's obvious they're not happy about it. If one drawing escaped their control there might be others. One would hope that they are more concerned about the source of the leak than websites that publish it. That they are concerned about the release of a 45 year old drawing at all is mystifying. There is no competitive advantage to be gained by keeping the drawings secret at this point.
  • #6,242
Curium said:
Gundersen
(3) If the contents of the fuel pool were lifted upward, this cannot have been only an external hydrogen explosion, something exploded in the pool itself...
The main problem with this idea is that now any worker can take a walk around the site without much hurry.
Any explosion IN the SFP would shatter fuel pieces around the unit. But only possible traces of particles were found, not pieces.
  • #6,243
Tepco knew a lot more than is openly or willingly given to public. I have come across below documents, these published ten minute logs of water level and pressure parameters at the most critical time after the tsunami and before explosions, and temperature after 20/3 and depicting were actual temperature sensors are placed.
There are some interesting data like unit 3 the fuel was uncovered 3/4 (-3metres) for more than two hours on the 19th March (does anyone remeber this event?)
[PLAIN]http://k.min.us/ilnQ3E.JPG
Here are all the files:
http://k.min.us/ilnOrs.pdf" Water levels and pressure
http://k.min.us/ilskVG.pdf" temperature
http://k.min.us/ilrLwi.pdf" Water levels and pressure
http://k.min.us/ilrN4q.pdf" temperature
http://k.min.us/ilnMjk.pdf" Water levels and pressure
032_1F3_04181300.pdf sorry cannot find this document can you find it?
unfortunately original documents cannot be found - they have been pulled from the Tepco site, these were google cached - the net does not forget (but it forgot one)
For May you can download these values
www.tepco.co.jp/nu/fukushima-np/f1/images/0[/URL]xy_1Fx_mmdd0600.pdf
were x is 1,2,or 3
y is 1 for water levels, pressure and CAMS, 2 temperatures
mm is month ie 05
dd is day ie 09
example http://www.tepco.co.jp/nu/fukushima-np/f1/images/032_1F3_05090600.pdf
Nice images of temperature graphs and temperature sensor locations
[PLAIN][PLAIN]http://k.min.us/in4JQ0.JPG
[PLAIN]http://k.min.us/in9ewE.JPG
  • #6,244
MadderDoc said:
Here is another stab of it (a higher resolution image is attached):
http://gyldengrisgaard.dk/fuku_docs/20110324_down_3thumb.jpg
3) Signature of heat on the winch, and possibly a burn through of the southern boom in this location
4) Missing rails on the top of this section of the southern boom.
5) Areas in which the booms have sunk into the concrete deck of the service floor, extending the NW broken region of the floor.
Excellent work.
3) IMO the crane is not 'burn through', here the crane directed the steam to the release path.
4) there everything covered with that gray dust.
5) On one of the T-Hawk videos it can be seen that the service floor is broken only under the north crane boom.
MadderDoc said:
Yes. We appear to have seen enough fuel racks to hold the recorded number of assemblies in the pool. Here is a rough lineout of the stacking in the pool, as much as can be gleaned from the two released videos.
http://gyldengrisgaard.dk/fuku_docs/P5080106thumb.JPG
That was fast :-)
IMO the 'cooling equipment' is partly the new fuel storage racks (with some black cover on the top, whick makes them look like damaged) and the fuel inspection machine - so there is one more rack. And that's all, we have seen everything.
  • #6,245
OMFG did you saw CAMS data 3/14 for unit 3 ? It is error or 100% of unit 1 core is damaged
  • #6,246
Jorge Stolfi said:
Your sketch shows 30*(7+7+12+12+10)+40 = 1480 slots for fuel assemblies; perhaps there are another 60 in the blind corner at right. On the other hand, some slots seem to be empty.
Yet a previous post claims that there were (548 in-use + 1331 spent + 202 new) = 2081 assemblies in the pool. If that number is correct, then we are missing 500 to 600 assemblies. Seems a bit too much for roundoff error...
At 2010 Dec. there were 783 spent assemblies. Plus the core (548) gives the 1331 for 2011 March. Plus the 202 new -> 1533. According to the various sources the maximal capacity of that pool was 1590.
  • #6,247
NancyNancy said:
You see that the SFP is tied into the outside of the containment concrete. It hangs sort of like a window box off of the containment structure. There is a very thin piece of concrete that ties the bottom of the SFP to the outer frame of the building. There is nothing supporting the SFP from below.
From looking back at that GE cut-out drawing of a mark I containment, there seem to be at least a bunch of pillars unders the SFP. Well, but for my personal taste there could be a bit more structural support down there.
NancyNancy said:
I have a couple of new images on my website. One of the crane being moved and inserted into the side of the building at the work floor level. Not sure why. Move due to structural worries? Moved so work to shore up the SFP could begin? Needed to inject water directly in the pool?
Also some new images of the leaning reactor 4 along with vertical landmarks to try to figure out the leaning. I mentioned in another post that I received confirmation from the TBS tech crew that it is not an optical illusion of the camera and also from workers at the plant that 4 is leaning over.
That's fair enough, but like for the previous posters, that's not sufficient evidence for me that it really is leaning. But there is also no evidence that it definitely is not leaning. So, let's see how the situation develops.
They have poured in tons of water, the soil around the building could be becoming unstable adding to the sinking. There were previous concerns about the groundwater levels making the NPP buoyant. [...] So you have a reactor building that is floating to an extent, lots of water added to the situation, constant earthquakes and two confirmations that this isn't a camera trick.
Asahi Shimbun article about the floating buildings http://www.asahi.com/english/TKY201104010166.html
Manichi article about bedrock being 46 meters down http://mdn.mainichi.jp/mdnnews/news/20110427p2g00m0dm091000c.html
Study confirming the NPP is on floating mudstone base not bedrock http://www.iitk.ac.in/nicee/wcee/article/9_vol3_733.pdf
info and photos of r4 sinking and the moved crane http://www.houseoffoust.com/fukushima/r4sinking.html
images of yesterday's steam and smoke show http://www.houseoffoust.com/fukushima/May8smoking.html
  • First article: Only relevant part is this sentence: "The pumps are located around the reactor building and designed to prevent the building from moving due to the buoyancy of the groundwater."
  • Only relevant part in second article: "There is bedrock 46 meters underground."
  • Third one: The study itself is not about confirming that it floats on mudstone. The study is about testing if FEM simulations correctly predict the measured responses of unit 6 to some earlier earthquakes. They conclude it does. That unit 6 is founded on mudstone is stated only in a few sentences describing the input parameters to their model: "The reactor building is partially embedded and is founded on mudstone at an elevation 17m below ground surface."
  • Fourth: See above, not enough evidence to decide whether it is leaning or not for me.
  • Fifth: Might be interesting but it's a different topic.
Overall still some interesting bits and pieces in my view. I don't know enough about geology to draw any qualified conclusions, but probably mudstone should be considered more stone than mud. Does anyone know how much that weakens if it soaks up enough water? And how much would be enough water?
  • #6,248
I think one reason TEPCO is not so worried about the unit 3 is the CAMS readings.
On March 14th 7:00 they had quite high reading (167,0 Sv/h) but after that it has been going steadily down. On March 18th it was still 105,0 Sv/h but after a month it was only 15,8 Sv/h.
CAMS D/W(A)
March 14th 7:00 167,0 Sv/h
March 18th 11:50 105,0 Sv/h
April 18th 15,8 Sv/h
http://i.min.us/ilnMjk.pdf
On May the levels have also been going down. On May 1st it was 13,7 Sv/h and on May 9th it was 12,1 Sv/h.
CAMS D/W(A)
May 1st 5:00 13,7 Sv/h
May 9th 5:00 12,1 Sv/h
http://www.tepco.co.jp/nu/fukushima-np/f1/images/031_1F3_05090600.pdf
I think what they are more interested in each reactor is the radiation readings and only if they see both temperatures rising and radiation rising will there be a "strong" reaction but if there is only temperature rising the reaction is subtler.
  • #6,249
You mean unit 1? Did you see D/W value for 4/8 ?
added: Does anyone have an idea at what level those sensors saturate or get damaged?
  • #6,250
I agree with Fred, and fear this is, again, a matter of overparsing a translated statement.
If you read the original Japanese version of the article, that is exactly the impression given:
http://www.asahi.com/national/update/0425/TKY201104250626.html
"東電側は24日夜の記者会見で、「基本的には内部資料として持たせていただいているもののはずなんですが、それがどういった経緯で、というのは確認していない」と説明した。"
I can't translate the tone exactly, but my reading is that this is a somewhat whiny (or offended) way of saying, "Those are our internal documents, and we don't know how they leaked out."
"また、問題の図面が東電のものだとすれば「核物質防護上の規制がかかっている」対象と認めた。"
TEPCO "admitted" (認めた) that if these diagrams are theirs, they would be subject to regulations on the protection of nuclear materials.
"これまでも設計図について、東電は「メーカーのノウハウがある」などの理由で公表を拒否している。 "
They have also previously refused to release blueprints, because they include "the maker's [GE's] knowhow."My reading is that TEPCO is concerned about getting into trouble for leaking documents that they had a responsibility to safeguard -- both for public safety legal reasons (protection from terrorists, for example), and for reasons of contractual obligation to GE. I don't see an implied threat to foreign bloggers, and indeed, don't see jurisdictionally how they could even make a credible one if they wanted to.
As far as the rules themselves, don't know exactly what TEPCO is referring to, but searching turns up stuff like this:
http://law.e-gov.go.jp/htmldata/S32/S32HO166.html
which, at admittedly just a glance, seems to apply to nuclear materials materials handlers -- like TEPCO.
I stress the above is all my reading only, and I am not an expert at Japanese law, or Japanese language, for that matter. Opinions and corrections would be welcome from ernal_student, Susudake, and whoever else may be able weigh in.
  • #6,251
Shall we conclude that the fuel in SFP #4 is fine and dandy, no H2 was generated, and the building did not explode? :smile:
*IF* there is damaged fuel in the #4 SFP, my guess would be the last row of 3x10 racks in the back, beyond the fallen staircase. There, the outline of the racks is fuzzy; maybe damage, maybe just bad imaging...
I fancy I see another area of damage on the right side of the main group of racks, two racks above the fallen rectangular plate, to the right of the staircase and slightly closer than it.
Bubbles seem to be rising from the bottom of the tank, in the free spaces adjacent to those two areas.
Just my imagination?
I suppose that the sort of damage we are looking for would leave the ends of the assemblies reasonably intact while the rest corrodes/melts. Is that correct?
  • #6,252
pdObq, it's better to look the overall trend, not some big values every here and now.
For the unit 1 it mostly makes sense until April 7th 18:00 (31,1 Sv/h), then you suddenly get these mega values after which CAMS D/W(A) stops working.
I wouldn't trust the values between April 8th 0:00 - April 8th 13:00 for the unit 1.
  • #6,253
Curium said:
Gundersen made an update to his previous hypothesis about SFP #3.
(4) Some other people (not Gundersen himself) suggested that since plutonium melts at a higher temperature than uranium, plutonium could have accumulated in a mass at the bottom of the pool
(5) This could cause a prompt, but "moderated" criticality
Contentions 1, 2, and 3 seem correct on the basis of the evidence. New question is: do hypotheses (4) and (5) make any sense?
Previously it was hard to imagine how an explosion could compress damaged fuel rods into a configuration resulting in criticality. Is the above any more plausible? In any case, something complex must have happened inside Unit 3 to account for what is seen in the videos.
The plutonium hypothesis is just because one needs something that might sustain a chain reaction. It is hard to imagine that in old fuel. But it is even more difficult to imagine how plutonium could have purified itself under water...
A prompt criticality would more likely involve the fresh fuel that was also stored in the pond. If the boral plates desintegrated in the alkaline water of a boiling SFP, one might expect big trouble.
  • #6,254
CAMS D/W(A)
CAMS D/W(A)
Or is the contaminated water just being flushed out into the basement and groundwater and the radioactive water being replaced by fresh water in the unit thus diluting radioactivity which could explain the gradual and continues fall in D/W radioactivity
  • #6,255
Hmmm, the sudden high readings at 4/8 coincide with the sudden temperature rise of that N4B sensor (sorry, too lazy to put the japanese label into google translate). The other temp. sensors seem not to see that.
  • #6,256
Average of 9 frames from the TEPCO video of SFP #4, manually aligned and with very low frequencies removed::
  • #6,257
The maximum from the unit 3 turbine building has been 750 mSv/h so far from the surface of the stagnant water.
Also IAES states: "In addition the water in the turbine building floor does not show high contaminations level."
http://www.slideshare.net/iaea/technical-briefing-11-0505
(I think they think 750 mSv/h is not "high". :smile:)
If water would leak wouldn't the contamination level in the turbine building be much higher?
(Of course there is a possibility of the water leaking into the basement on the reactor building and only a small part of it leaking into the basement of the turbine building. The radiation in the basement of the reactor building is still unknown.)
  • #6,258
were x is 1,2,or 3
mm is month ie 05
dd is day ie 09
][/QUOTE]
I have found this document for a couple days later and is attached
[ATTACH=full]142709[/ATTACH]
  • #6,259
I found the missing file..
http://doc-0o-94-docsviewer.googleusercontent.com/viewer/securedownload/dsn1aovipa7l846lsfcf94nedj8q2p4u/8c5thse5v9cd2meshc5cl2qr6f934scr/1304931600000/Ymw=/AGZ5hq8BgbJY1gwaOYx83cPOdNw6/QURHRUVTZ0ZFcXF2dWt0OGRCUm9ueUdCMkk3MzdTR3l5bHBxLXRCVEJXdURxYk9XeTdQcElpTldzcTdGdXdQTjAteXBxekN2TFRCWGZ1MHRVbGNWQUEzV1pvSzRRT1Fyb1I2cTNwTnZlUTkzTlh5bVVBX0NXUy03Wkc3N0NQcTZjd0RFOTBvZGFyZVc=?a=gp&filename=032_1F3.pdf&chan=EgAAAD6vI5/VRlCU5i4pgUzPU9Km4tn1JD8a0Jzc20%2BGFwbX&docid=6345a1e68d72ae09aae9bdedb1337358&sec=AHSqidaieXcDccdYhypxj0jsUp_XglLAWR4WCIYyJHrL0-F4fzZsO-yLoIuXoaM4FfNGF4VdNGO8&nonce=11ec8voqipgke&user=AGZ5hq8BgbJY1gwaOYx83cPOdNw6&hash=9bnuup18t2abh38mqss9o0iu6u9rkmq2"
  • #6,260
Why not? It's even ready for a hot bath :-P
What I'm telling is that there was no explosion or fire in SFP#4. That's all I'm saying :smile:
http://www.ic.unicamp.br/~stolfi/EXPORT/projects/fukushima/videos/110508_2/frames-b/avg-001--009.png
May I ask that what kind of software did you used for that? I have some more candidates for such trickery.
  • #6,261
Well I guess it could be that. I don't read Japanese.
Yes, the connection to GE was discussed here previously and that could have a bearing on it, although one could make a pretty solid argument that the damage caused by the release of the drawing is immeasurably small. A desire to avoid shame could be a key factor as well.
As it turns out they had nothing to fear from terrorists that they couldn't accomplish all by themselves.
Maybe someone would be so kind as to translate this:
http://www.soumu.go.jp/menu_news/s-news/01kiban08_01000023.html
Google does an OK job, but I'd like to hear what others think.
It wouldn't take much to move "unauthorized release of nuclear blueprints" into the "illegal" category IMO, and receiving cooperation from other nations in an effort to eradicate said illegal information is probably a good bet. See the current CEO of General Electric, for example http://en.wikipedia.org/wiki/Jeffrey_R._Immelt
  • #6,262
TEPCO discovers NEW PHYSICS
http://www3.nhk.or.jp/daily/english/08_18.html
T
TEPCO releases footage of No.4 reactor pool
The operator of the Fukushima Daiichi nuclear power plant has released footage of the spent fuel pool in the Number 4 reactor.
The video was taken on Saturday by a camera on the tip of a mechanical arm used to pour water to cool the reactor.
The footage shows 1,535 spent fuel rods stored in racks and covered by water. It also shows debris and ladders damaged by an explosion that occurred after the March 11th earthquake and tsunami. The shelves on the side wall have been destroyed.
Bubbles are occasionally visible, as the water is boiling at a temperature of 84 degrees Celsius.
After analyzing the amount of radioactive materials in the water, Tokyo Electric Power Company has concluded that the spent fuel rods are not seriously damaged.
The Number 4 reactor was not operating at the time of the quake. The reactor building was severely damaged by a hydrogen explosion on March 15th.
Sunday, May 08, 2011 23:00 +0900 (JST)
boiling at 84oC : :smile:
  • #6,263
http://www3.nhk.or.jp/daily/english/society.html - ,,Tokyo Electric Power Company released 2 photos taken inside the No.1 reactor building early on Monday."
TEPCO says that pictures posted http://www.tepco.co.jp/en/news/110311/ are pictured on May 9th, 2011.
http://www.tepco.co.jp/en/news/110311/images/110506_Northwest_1.jpg
http://www.tepco.co.jp/en/news/110311/images/110506_North_2.jpgThe pictures name are 110506_Northwest_1.jpg and 110506_North_2.jpg. I think that pictures are made on May 6th, 2011.
  • #6,264
The water is murky and the focus is fuzzy at that distance. Averaging 9 fuzzy frames results in another fuzzy frame, and I don't think 2D Fourier transforms help all that much unless you know the point spread function of the lens, and even then no amount of convolution filtering will extract information that isn't there to begin with. Image enhancement processing is a valid tool under the right circumstances, but this is trying to extract information from data that just isn't there IMO. For instance, we know the back rail of the stairs is there from the video after the 13 second mark, yet your processing fails to bring it into focus. I just don't see how anyone can draw any valid conclusions about the condition of fuel bundles back there.
  • #6,265
From The Physics arXiv Blog at MIT's Technology Review website -
(05/09/2011) Chain Reactions Reignited At Fukushima After Tsunami, Says New Study
Radioactive byproducts indicate that nuclear chain reactions must have been burning at the damaged nuclear reactors long after the disaster unfolded
http://www.technologyreview.com/blog/arxiv/26738/
The source paper is -
Matsui, T. Deciphering the measured ratios of Iodine-131 to Cesium-137 at the Fukushima reactors. arXiv:1105.0242v1.
abstract: http://arxiv.org/abs/1105.0242
full text (pdf): http://arxiv.org/PS_cache/arxiv/pdf/1105/1105.0242v1.pdf
  • #6,266
MiceAndMen said:
A Japanese news story from 27 April says TEPCO doesn't like what Nancy has on her website.
http://www.asahi.com/english/TKY201104260122.html
Oh I expected something more sinister.:smile:
As regards the secrets of TEPCO. In my humble opinion a court should have ordered them to publish all plant layout and infrastructure plans of the affected facilities in order to allow the rest of the world to help assess the damage and work toward countermeasures.
Companies running nuclear power plants, unlike car makers, are not in a race with the competition and don't need to keep secrets. On the other hand, their special responsibility to us, the public, should be a reason for compelling them to openness. Why has the International Atomic Energy Agency not intervened?
I hope this is not altogether off topic in this forum.
  • #6,267
Jorge Stolfi said:
The "round thing" may be an enclosure within the SFP that holds a fuel transportation cask while loading and unloading. That would be another version of the square concrete enclosure visible in the far left corner of the SFP in the photo of an unidentified japanese reactor (Unit #5?) attached.
Some blueprints/drawings (said to fit Unit #1) show a separate "cask-loading pool" between the equipment pool and the elevator shaft. Presumably in Units #2--#4 that separate pool was replaced by a smaller enclosure within the SFP.
Nope. The accessory pool inside a corner of the main pool is a feature at Dianni, but not at Daiichi. The Daiichi 2, 3, 4 plans have a "cask lay down pool" between the vertical lift shaft and the main SFP, pretty sure.
As for debris in the pools, differential pressure of the blast was outward and upward, so most of the debris was vectored away from the pools. Unit 4's roof was intact when debris from 1 and 3 were salted over the NPP site. At Unit 3, SFP3 does seem to have at least part of the FHM or some similar large green piece of equipment in the pool. I am as yet not totally convinced that all of the FHM is in the pool, but clearly the vector of the force of the explosion was upward, out of the SFP3.
At Unit 4, clearly a large, intact portion of the roof slab has done much of the damage at the north end of the building. It follows, by analogy, that part of the roof slab may have done damage at Unit 3, but, first, the explosion was probably much more powerfue (at least the vertical (steam?) explosion over SFP3) and, second, large pieces of debris can be seen lofted skyward then falling on the building, perhaps even part of the FHM. Put that in the "unresolved" column along with a bunch of other stuff.
Unit 4 is and has been the enigma as far as explosions. In my lay opinion, Anton's suggestion of low water, but not exposed fuel, and radiolysis occurring in vigorously boiling water would help explain some of the discrepancies. Vigorous boiling at SFP4 versus superheating water in lower thermoclines of the SFP3 prior to an explosion out of the primary containment of Unit 3 might also explain the qualitative difference in the "hydrogen" explosions at these units. Alas, "unresolved".
As it now seems to be "official" that the primary containment of Unit 3 has an enlarging crack, my logic tells me the most obvious site would be at or around the fuel transfer chute. That is yet another "unresolved" awaiting confirmation.
  • #6,268
No, nothing so dramatic. Still, hers is the only website I have seen mentioned by name in any of the Japanese media coverage.
As for intervention by outsiders, I think everyone around the world wants the whole mess to just go away. As long as TEPCO seems to be making progress they will be allowed to run the show barring any more dramatic unplanned events. Nobody else seems to have any better ideas at the moment.
  • #6,269
Ooohh ! I like it how they translated 'flange' mucho - mas ! ! :)
  • #6,270
High levels of Strontium 89 and 90 found in soil around Daichi reactors:
http://www3.nhk.or.jp/daily/english/09_01.html
Up to 570 becquerels of strontium 90 per kilogram of dry soil were detected in samples from 3 locations. They were taken on April 18, about 500 meters from the Number 1 and 2 reactors at soil depths of up to 5 centimeters. The amount detected is about 130 times higher than a previous high, level that was measured in Fukushima Prefecture before the accident at the nuclear plant.
TEPCO also said it found 4,400 becquerels of radioactive strontium 89 per kilogram of dry soil taken from the same location.
Earlier in March, strontium was detected in soil and plants outside the 30-kilometer zone around the Fukushima plant.
Note this also:
Strontium can cause cancer and like calcium it tends to collect in bones once humans inhale it.
To the isotopes specialists: does these levels of strontium tells something about the cores destructions or possible criticalities? What are the most possible ways this strontium went there? By dust and particulates during the explosions? By steam?
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
471K
21K
  • · Replies 763 ·
284K
  • · Replies 38 ·
17K
12K
