Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The Fukushima Daiichi nuclear plant is facing significant challenges following the earthquake, with reports indicating that reactor pressure has reached dangerous levels, potentially 2.1 times capacity. TEPCO has lost control of pressure at a second unit, raising concerns about safety and management accountability. The reactor is currently off but continues to produce decay heat, necessitating cooling to prevent a meltdown. There are conflicting reports about an explosion, with indications that it may have originated from a buildup of hydrogen around the containment vessel. The situation remains serious, and TEPCO plans to flood the containment vessel with seawater as a cooling measure.
  • #7,551
New video of Fukushima disaster site and reactors
Video taken 6 May 2011 - released 17 May 2011
https://www.youtube.com/watch?v=4k86qoCij_M
  • #7,552
SteveElbows said:
Lots of new images from site published today, I think as part of their roadmap update:
http://www.tepco.co.jp/en/news/110311/index-e.html
Most of the images I don't find very interesting, but there is also a 13 minute video showing a variety of scenes on site. They really have sprayed that anti-scattering agent all over the place.
The roadmap update isn't available in English yet but a quick look at the Japanese version suggests that this is as much about a desire to show all the 'progress' they have made, as it is a serious update of technical measures required.
Of interest, here is a picture of what they define as being the diesel generator building 6B for reactor N°6:
http://www.tepco.co.jp/en/news/110311/images/110517_22.jpg
it seems that these generators are finally at the top floor of this platform (see the exhaust pipes) on this newer generation of reactors... (or is it just the cooling system at the top?)
Why if the max tsunami was 5,7m by their calculations? Is it the admittance that they were wrong with earlier designs, even they didn't modify it (putting those generator on a platform was not an impossible modification for reactor 1 to 4 IMO).
EDIT: this platform is cooling equipment for the EDG building, it's much clearer in the video, i extracted this picture which shows it (the blue wall at the top was from the reactor behind). So EDG are not on a platform as i imagined above...
http://www.netimago.com/image_200947.html
  • #7,553
I think it is only the exhaust system and the cooling, IIRC they are in the basement in each turbine building. Keep in mind that the power of diesel generators in place range from rougly 3 up to 5 MW (3000~5000 kW each), the engine should be a V18. On the tepco website (japanese side only) it is possible to find some images and you can see their dimensions.
For the tsunami, it is true that the wall was made according to 5.7m estimate, but many are forgetting that the buildings has been placed at OP +10000 (u1 to u4) and OP +13000 (u5 and u6), for the latter it is thought this saved one of the D/G.
  • #7,554
No, this image is common SFP cooling system
btw they injecting 18m3/h to unit 3 now...
  • #7,555
Yep, I edited my post above after viewing the video...
On the other hand, if they placed N°5 and 6 at +13m, one could find this strange if +10m was already considered safe with some margin for a 5,7m tsunami... Wasn't it the admittance that they already had raised some doubts?
In the movie from Adam Curtis that i posted yesterday
http://www.bbc.co.uk/blogs/adamcurtis/2011/03/a_is_for_atom.html
(which talks about US, GB and USSR, not Japan),
it is shown that this period when these first reactors were built was a period of kind of exaltation of nuclear power, everybody had to go quickly to stay in the race and the guys interviewed in the video (who participated to this era as scientists and experts) admit that there was very little place for safety concerns at first... Then the doubts were raised about containment problems and so on. So this could apply to others risks. Still, Tepco was stating at the end of 2010 that 5,7m run up was the worst case scenario, so +10m was ok. +13m for 5 and 6 was even luxury with no real calculation basis in this case, don't you think? Waste of money even!
Well, to a certain extent, we have to consider that several factors are taking place in the designs standpoint, talking about elevation heights.
1) build on some solid "bedrock" or "mudstone" (for earthquake robustness) implies removing al lot of unstable surface sediments (25m for 1 to 4 it seems). This is a lot of work. From this standpoint, the less you remove, the lowest the construction cost is.
2) but if the plant is higher regarding to water intake (sea level), this means that the electrical consumption of pumps to send these continuous huge volumes of water to cool down the reactor (in fact to condense the steam in the condensers) will increase, which is not good for production costs!
So the altitude of the buildings is a trade off between safety and cost from this standpoint i think.
  • #7,556
~kujala~ said:
Everything else fine in #3 temperatures except those two RPV readings:
The other one is 258,6 degrees, 16th of May, 5:00 (second highest).
The highest has been 269,6 degrees, 15th of May, 14:00.
The other one is 267 degrees, 16th of May, 5:00.
The previous high was 262,7 degrees, 16th of May, 2:00.
http://www.tepco.co.jp/nu/fukushima-np/f1/images/032_1F3_05160600.pdf
TEPCO may see this a little different. Again the water flow from the two pathes was increased. Now at 18 m³/h.
  • #7,557
Edited with links
http://www.youtube.com/watch?v=4k86qoCij_M"
http://www.tepco.co.jp/en/news/110311/"
The TEPCO pictures on the source page are taken from the video. They give title and partial explanation to the scenes on the video.
  • #7,558
MadderDoc said:
It is also news to me from this document, that the RPV during the period of the 'black smoke event' on March 21st briefly peaked out at >12MPa, before it dropped back abruptly and went down to to atmospheric. My,my.
Are you talking about the graph page 41/66 of http://www.tepco.co.jp/nu/fukushima-np/plant-data/f1_8_Parameter_graph.pdf ?
3 data are between 8 and 12 MPa, but it is difficult for me to read the date more precisely than sometime between March 18th and March 23rd.
I am interested in any interpretation of what happened at any unit late on March 20th or early in the morning on March 21st, because I am curious about the radioactivity peak recorded in Mito at 6 AM on the morning of March 21st, as in most cities in Eastern Japan on that date, which I believe is also connected to the "don't give tap water to babies" crisis in Tokyo during the following days (http://www.guardian.co.uk/world/2011/mar/23/tokyo-water-unsafe-infants ).
My previous posts on that topic :
https://www.physicsforums.com/showthread.php?p=3258585#post3258585 (with Mito 6 AM March 21st peak attachment)
https://www.physicsforums.com/showthread.php?p=3258806#post3258806 (about the gap in Tepco data)
For what it's worth, I posted about Kenichi Ohmae's somewhat isolated view of black smoke being something serious at https://www.physicsforums.com/showthread.php?p=3229089&highlight=Ohmae#post3229089
  • #7,559
Nope, this is not, even if it looks like!
Look at the latest video from Tepco:
http://www.youtube.com/watch?v=4k86qoCij_M&feature=player_embedded
T=5'44 the building behind even if it is undamaged is NOT N°2 reactor. Plus in the video this area is clearly a different area from N°1 to 4 reactor, this is N°5 en N°6.
  • #7,560
MadderDoc said:
Find attached photos from two angles of a cylindrical oject lying leaned to the roof wall of turbine building 3. Seen from the THawk angle, one can well interpret the object as being connected to the piping there, i.e part of the original installation, albeit somewhat damaged. However, seen from the west in a zoom from one of the herostratic high resolution photos, it can be seen that it is not mounted, but has crashed on top of the original pipe. It has not been possible for me to find any satellite photo from before the unit3 explosion showing this object. So, I am led to believe that this object could be one of the ballistic objects. I have no idea what it could be, and where it sat in the building before the explosion. No high hopes that anybody can identify it, there are few clues except shape and a peculiar coat it appears to have been lined with.
You are right sir, this picture before/after confirms this: this kind of elongated tank was not there at first:
http://www.netimago.com/image_200952.html
  • #7,561
mamoru said:
Of interest, here is a picture of what they define as being the diesel generator building 6B for reactor N°6: http://www.tepco.co.jp/en/news/11031.../110517_22.jpg
The http://www.tepco.co.jp/en/news/11031.../110517_22.jpg link is broken because of "..." in the URL. I recommend using [PLAIN]https://www.physicsforums.com/Prime/buttons/quote.gif in order to provide the quoted person's name and manage url/links safely.
I would be glad if you could provide the links to these images.
  • #7,563
Notes concerning soil amplification:
1. Ground shaking is amplified in soft sediments and dampened in hard rock:
Flash animation:
"[URL amplification
[/URL]
(Source: U.S. Geological Survey)
2. In the U.S. they have already made soil amplification maps for some areas in the U.S. to predict the level of shaking depending on soil quality. Here we have the map for LA area:
http://earthquake.usgs.gov/learn/glossary/images/amplification.jpg"
Flash animation and LA region amplification map can be found in this page:
http://earthquake.usgs.gov/learn/glossary/?term=amplification"
And here they have made a research concerning earthquake ground motions in the central U.S.:
http://gsa.confex.com/gsa/2002NC/finalprogram/abstract_31500.htm"
Do they have these kind of maps in Japan?
Surely they must have?
3. The differences between mudstone and bedrock:
The velocity of transmits shear waves (S-waves) is one contributor to the amplification rate. It's dependend on the area we are talking about. In the San Fransisco Bay area they have 5 level chart for soil types and shaking amplification. In that area mudstone and bedrock have different qualities:
Soil type B: 1500 m/sec > Vs > 750 m/sec
Includes volcanics, most Mesozoic bedrock, and some Franciscan bedrock. (Mesozoic rocks are between 245 and 64 million years old. The Franciscan Complex is a Mesozoic unit that is common in the Bay Area.)
Soil type C: 750 m/sec > Vs > 350 m/sec
Includes some Quaternary (less than 1.8 million years old) sands, sandstones and mudstones, some Upper Tertiary (1.8 to 24 million years old) sandstones, mudstones and limestone, some Lower Tertiary (24 to 64 million years old) mudstones and sandstones, and Franciscan melange and serpentinite.
http://earthquake.usgs.gov/regional/nca/soiltype/
Shaking is stronger where the shear wave velocity is lower. So it's stronger for mudstone than for bedrock.
4. Conclusion: To have nuclear plants built on bedrock and mudstone are two different things. Building on bedrock is safer.
If Fukushima plant's foundation is built on mudstone - not bedrock - and the local geological qualities for mudstone and bedrock differ in that area then it may have had some impact on the scale of the catastrophe.
But surely the Japanese must have made some calculations concerning the safety of building nuclear plants on mudstone if that happens to be the case?
  • #7,564
Tsutsuji my original post was this one, but i edited it in between so read the EDIT first!
https://www.physicsforums.com/showpost.php?p=3306526&postcount=7568
By the way The BLACK SMOKE at N°3 was first reported the 21 st of march at 3:55pm (japan time i guess) , so you were right, bt it seems that some was still reported the 23 st (not clear):
http://english.kyodonews.jp/news/2011/03/79925.html
For those interested in history of what happened then, the part of this PF thread for this date starts here (page 44):
https://www.physicsforums.com/showthread.php?t=480200&page=44
  • #7,565
Flash animation:
"[URL amplification
[/URL]
very interesting data which confirms that mudstone can hardly been described as bedrock from seismic standpoint...
So the Tepco site stating Bedrock is not lying by approximation, it's lying by using one word to describe something else.
THANKS!
Also of interest this recent article which summarizes the long history of battles and lawsuits of japanese residents against nuclear industries on the matter of earthquake resistance, very complete article:
http://www.staradvertiser.com/news/20110517_Japan_officials_ignored_or_hid_nuclear_risks.html
Today things are changing a bit:
In 2007, a district court ruled against the plaintiffs, finding no problems with the safety assessments and measures at Hamaoka. The court appeared to rely greatly on the testimony of Haruki Madarame, a University of Tokyo professor and promoter of nuclear energy, who since April 2010 has been the chairman of the Nuclear Safety Commission of Japan, one of the nation’s two main nuclear regulators.
Testifying for Chubu Electric, Madarame brushed away the possibility that two backup generators would fail simultaneously. He said that worrying about such possibilities would “make it impossible to ever build anything.” After the Fukushima Daiichi disaster, Madarame apologized for this earlier comment under questioning in Parliament. “As someone who promoted nuclear power, I am willing to apologize personally,” he said.
In the early days of nuclear power generation in Japan, the government and nuclear plant operators assured the public of the safety of plants by promising that they would not be located on top of active fault lines, Ishibashi, the seismologist, said in an interview.
But he said that advances in seismology have led to the gradual discovery of active fault lines under or near plants, creating an inherent problem for the operators and the government and leading to an inevitable conclusion for critics of nuclear power
Note also this part, where "solid bedrock" seems to have had some variations in the mouth of some people:
Her group filed the lawsuit in 1999, a year after the operator suddenly announced that it had detected a five-mile-long fault near the plant, reversing decades of claims that the plant’s vicinity was free of active faults.
Chugoku Electric said the fault was too small to produce an earthquake strong enough to threaten the plant, but Ashihara’s suit cited new research showing the fault line could in fact be much longer, and produce a much stronger earthquake. It got a boost in 2006, when a seismologist announced that a test trench that he had dug showed the fault line to be at least 12 miles long, capable of causing an earthquake of magnitude 7.1.
After initially resisting, the company reversed its position three years ago to accept the finding. But a spokesman for the Chugoku Electric said the plant was strong enough to withstand an earthquake of this size without retrofitting.
“This plant sits on solid bedrock,” said Hiroyuki Fukada, assistant director of the visitor center for the Shimane plant, adding that it had a 20-foot, ferro-concrete foundation. “It is safe enough for at least a 7.1 earthquake.”
However, researchers now say the fault line may extend undersea at least 18 miles, long enough to produce a magnitude 7.4 earthquake. This prompted Ashihara’s group to appeal last year’s ruling.
So I'm happy to extract again this last sentence here in a PF forum where science means something:
"However, researchers now say the fault line may extend undersea at least 18 miles, long enough to produce a magnitude 7.4 earthquake. This prompted Ashihara’s group to appeal last year’s ruling"
then the question is: what do we do with this new knowledge?
How many nuclear plants in the world are still on places where it was considered safe at the time of their design and construction (for whatever reason) and where it can no more be considered that way with new scientific findings?
As life of old plants everywhere seem to be extended, and as retrofitting seems impossible in some cases like theses, what do we do? Do we wait for the next big one?
  • #7,566
Tepco is providing daily updates in English
The image cited by mamoru and jlduh is described as:
Building for diesel generator 6B of Unit 6
Before posting make sure links are not parsed (...)
Heavy oil tank swept up by Tsunami (I believe this is one of the tanks of diesel fuel that was moved from the shoreline to is present location.)
http://www.tepco.co.jp/en/news/110311/images/110517_17.jpg
  • #7,567
Can anyone locate the camera location on Google maps?
By the same token, I mentioned yesterday a report that a transmission tower tower had been collapsed by the quake : https://www.physicsforums.com/showthread.php?p=3305099#post3305099 : I would be glad for any picture showing the collapsed transmission tower, or for the location of that transmission tower on google maps.
  • #7,568
http://www.tepco.co.jp/fukushima1-np/bi3916-j.html" (sort of vintage :smile:)
http://www.tepco.co.jp/fukushima1-np/b42403-j.html"
http://www.tepco.co.jp/fukushima1-np/b42615-j.html"
I think I gathered few others, but I'm not at home now.
I made some posts about F-1 with some image I took from Tepco material and some original work by myself (all in italian language).
The first post gives you the exact position of D/G in R3: click on the image to open the bigger one and look on the North side of the basement plan.
http://giappopazzie.blogspot.com/2011/05/post-tecnico-4-approfondimento-sulla.html"
http://giappopazzie.blogspot.com/2011/04/post-tecnico-no2-quanta-acqua-ci-sta.html"
  • #7,569
The camera appears to be north of Unit 6.
  • #7,570
To sum up, we have
a) "grayish smoke" at 3:55 PM on March 21st and
b) "black smoke" on March 23rd afternoon :
JAIF also said work at units 1, 2, 3 and 4 was suspended after black smoke rose from unit 3 yesterday afternoon. Work resumed at around 05:30 Japan time (21:30 on 23 March central European time)
http://www.worldnuclear.org/_news_database/rss_detail_features.cfm?objID=4A9D7859-1491-40DE-8802DB48852FA882
  • #7,571
sp2 said:
Yeah, that advice looks pretty good (and makes them look a lot more responsible than their Japanese counterparts), but this statement now (basically that 'we're packing up and heading home because everything's fine now') looks shockingly stupid and irresponsible, don't you think?
(And *unbelievably* badly timed.)
Off-topic responses to slightly off-topic comments: (1) This NHK article says the NRC is not continuing 24-hr monitoring of the situation, but is not removing its team from Japan. (2) The NRC is a separate federal agency from the Dept of Energy -- they are different organizations. Dr. Lyons is a DOE official rather than NRC, although I think he was previously an NRC commissioner. When the old AEC was split in the US, the NRC was set up to regulate and inspect (the safety watchdog, FWIW) while the DOE was given responsibility for R&D and promotion of nuclear power.
  • #7,572
  • #7,573
Thanks for looking up all that information and clearing that up!
My naive first thought was that the softer soil might even act to damp the accelerations via dissipation like a piece of rubber, but apparently that's not how this works.
They certainly had done calculations, see that paper originally referred to by NancyNancy (see links in EDIT below), in which they compared simulation results with measured acceleration from unit 6 sensors during a smaller earthquake. Maybe someone also recognized the risks, but since the plant had already been built, they would probably try to hide that away from the public and from themselves.
Well, as ernal_student said before, maybe one should consult the original Japanese version before saying they were outright lying. Could be a translation issue. [sarcasm] And in some sense it's not totally untrue, "built on solid bedrock" could be interpreted as "there's bedrock somewhere below if you go deep enough".[/sarcasm]
EDIT: In this post I summarized the relevant content of the links NancyNancy provided (follow back the quotes): https://www.physicsforums.com/showthread.php?p=3291249#post3291249 . Here the direct link to the study again for convenience: http://www.iitk.ac.in/nicee/wcee/article/9_vol3_733.pdf .
PS: Regarding that discussion about "partially embedded". Looking back at that study again, from the context you can tell what they mean, and that is that from the ground level to the bottom of the building/concrete structure it's 17m. That's also how I had read it originally.
  • #7,574
I've put the EDG building right in the middle of the screen, follow this link:
http://maps.google.com/maps?ftr=mis...37.430616,141.032771&spn=0.0023,0.006539&z=18
The camera was above this on the map (North), looking towards south/west direction, on the ground close to very end of the limit of the plant.
That's where they seem to have installed the big number of tanks that we see in the video. I imagine that these tanks are for storing the tons of "weakly contaminated water" that they are pumping out of the basements from N°5 and 6?
  • #7,575
What site is that? Do you have link to the original Japanese?
  • #7,576
All this talk of mudstone and bedrock is quite meaningless until the material is better defined. I've no idea what the Japanese words were that got translated into English but mudstone is any rock that was once a fine grained sediment. It can be very hard and very strong. Bedrock is just what's below, under any recent superficial deposits. It can be very soft and very weak.
Using terms that aren't defined does not tell us much.
Different rocks alter both the frequency and the amplitude of earthquake waves. It's not simple.
  • #7,577
rowmag, see this post for an earlier discussion of that and follow back the quotes (by clicking on the blue box with the white arrow, I am sure you know) to get to a link to the English website that states that.
https://www.physicsforums.com/showthread.php?p=3305982#post3305982
  • #7,578
This is the english version:
http://www.tepco.co.jp/en/challenge/energy/nuclear/plants-e.html
I don't read japanese so it's difficult to find the japanese page for me, but the tree index for the english page is from main page "Challenges of Tepco" -> Nuclear -> Tepco power plants
Maybe this will help to find the page in japanese if the japanese site structure is the same (not sure!)
BUT: THERE IS A SECOND PLACE WHERE THEY MENTION THIS...
In the SAFETY SECTION of the site (you could try to find the japanese version):
http://www.tepco.co.jp/en/challenge/energy/nuclear/safety-e.html
Designed for the Largest Conceivable Earthquake
Before constructing a nuclear power plant, the site is carefully studied for previous earthquake records and geological features. This study establishes that there is no active fault under the site. Then, the building, the equipment, the piping, and other equipment are all designed to withstand the strongest possible earthquake in the area.
Hard-to-Shake Structure
Reactor buildings are built directly on solid bedrock after all soil has been removed. Furthermore, the reinforced concrete walls are far thicker than those used in other buildings. The building itself is a strong dice-like structure. Therefore, in the event of an earthquake, reactor buildings shake far less than an ordinary building.
They even add some illustrations, and to me these illustrations are self explanatory of what they mean, or would like to mean (and then translation is out of subject):
http://www.netimago.com/image_200971.html
  • #7,579
Thanks. I am happy to be able to locate this separate EDG building now on Google maps here on the north of reactor No 6.
Influenced by http://www.asahi.com/english/TKY201104060126.html I had on mind only two possibilities : EDG in turbine building basement in Daiichi or EDG in reactor building as in Daini, and the following sentence :
TEPCO documents show that the emergency diesel generators located in the turbine buildings at the Fukushima No. 1 plant were flooded by the tsunami and rendered inoperable, except for the one at the No. 6 reactor.
had wrongly made me imagine that the Emergency Diesel Generators were also in the basement of unit 6's turbine building.
the following paragraph :
“Most are located in generator rooms in basement 1 of the turbine buildings,” Arai said, pointing to a diagram in a Tepco brochure of the Dai-Ichi plant. The turbine buildings holding eight of the generators are about 140 meters from the seafront, another two generators were on the ground floor behind reactor 4, which was offline for maintenance. Three others were in and around reactor 6, which was also offline.
http://www.bloomberg.com/news/2011-04-25/japan-s-terrifying-day-saw-unprecedented-exposed-fuel-rods.html
was containing better information, but I read it very quickly only a few days ago after someone posted the link here, and I had failed to memorise the details.
I am happy to be able to locate the "around reactor 6" one(s). Comparing the shapes, I think it is also quite easy to recognise the "behind reactor 4" one on the Google maps aerial view.
jlduh said:
Thanks.
bytepirate said:
That's great. Thanks.
Edit: I also found http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110516e19.pdf showing pictures of earthquake damages to various Tepco power lines. It includes elements of that same "Yonomori line".
  • #7,580
SteveElbows said:
I am a little wary of the rises that are shown far away from the plant on that date, simply because they may have been caused by changing weather conditions which sent stuff in direction of Tokyo.
So I tend to go by radiation dose measurements from the site itself, which also rise over the same period. Shame there are some gaps in such data during this time, although I suspect that was inevitable given site evacuations that these smoke events & higher readings caused.
The changes caused by weather are an order of magnitude smaller Steve. The rise on the 20th is an abrupt spike and then falls with a rate reminicient of isotope decay. Its a real shame that the perimeter monitoring network was not immediately re-established. The 'drive around with a counter out the window' technique doesn't provide a reliable picture of the releases.
  • #7,581
If you are talking about Tokyo readings, then no, I am not completely convinced that what we see at that time is caused by something other than wind taking stuff in the direction of Tokyo for perhaps the first time since the disaster, and it may also have been raining for the first time. I will have to go back and see if I have any weather data left from that period.
But in any case, the readings from the site itself spike on that date too, and I am not trying to attribute these higher site readings to the weather. So it does not matter too much whether I am right or wrong about the cause of readings from further away, we still know that something was going on in the period around 20th/21st->23rd March that caused higher radiation.
  • #7,582
razzz said:
Then there is the tsunami where the sea reportedly receded leaving 300 feet of the sea floor exposed before the tsunami arrived. No intake for the water cooling system during that period.
Siting plants at higher levels would not help for that aspect of a tsunami. Are power plants designed to handle the lows?
The cooling inlets may fall dry for 15 minutes, due to distant earthquakes that would not scram the reactor. Can a reactor at full power survive that?
  • #7,583
Thanks jlduh, and pdObq. Unfortunately, as I think ernal_student noted once before, the Japanese TEPCO pages are all disaster-related now, and I didn't find the equivalent of the English page. Perhaps such PR material was taken down as being likely to incite anger under the circumstances.
  • #7,584
ROWMAG, read my updated post as I provide a second english link in the "safety" section:
https://www.physicsforums.com/showpost.php?p=3306751&postcount=7594
  • #7,585
As we talk about bedrock, i post this:
http://criticality.org/2011/04/japan-sinking-pacific/
see the very impressive animation showing all the aftershocks earthquakes lately:
http://www.youtube.com/watch?v=SjfWBnSeDik&feature=player_embedded#at=76
I post also this very interesting (and complex) study about seismic assessment of nuclear plants (unfortunately no Daichi data):
http://www.iter-consult.it/Meetings...P and experience feedback in Japan (JNES).pdf
See page 28: the graph shows that in automatic shutdown, the control rods have to be inserted while the building is shaked by the Earth quake of course (see the timing), and of course one risk could be that while shaking, the cross rods could not slide properly in between the fuel elements...
Of course they state it is not possible, but...
Page 18: about the fault N°2 (NCO) "At establishment permission, fault ②was estimated to be 7~8km (M<6.5) and non active fault". But it's now estimated 27~36km (36km for conservative evaluation)
  • #7,586
Very interesting question.
The heat of vaporization is about 2000 joules/gram. So a 1 gigawatt plant at full cry would need to vaporize 3 gigajoules worth of water every second, or about 1.5 million grams of water, about 1.5 tons worth. The 15 minute dry spell would vaporize 1350 tons of water. That seems a manageable amount, about equal to the water quantity in SFP 4. No idea if the reactors are designed to have that much reserve capacity though.
  • #7,587
Yes. Assuming loss of offsite power. Diesels will be tripped if they try to satrt without cooling water which will protect them during the drawdown period. The high pressure DC systems can inject cooling water for long enough for the drawdown period. At Fukushima that is the isolation condenser at unit 1 and the RCIC and HPCI systems at the other plants. If the water returns and the diesels are undamaged from the tsunami they can be started and then the low pressure AC systems will also be available. The Fukushima event made this scenario impossible due to failure to protect safety systems from the tsunami or from flooding.
  • #7,588
Wow, you have some very nice stuff on your site. Are you planning on an English version?
Regarding the EDGs, those things must weigh A LOT. It makes a lot of sense to put them as close to the ground as possible both from the engineering and the building cost point of view.
In general, I think they should try to distribute them as much as possible around the site (also elevation-wise if the terrain is appropriate - what if they had had at least one backup EDG located on the higher grounds behind?), and it should be possible to easily route power from any EDG to any unit in case of emergency.
Another option would be to put a small gas power plant into the vicinity (not only as backup but also regularly operating), but not too close.
But as those recent reports suggest, it wasn't necessarily the tsunami's fault...
Which makes me wonder if there is serious damage in other plants not affected by the tsunami that were reported in cold shut down early on?
  • #7,589
thanks.
Sorry, I am lost. "click on the image" : which one ? Can you provide a direct link to this image ?
  • #7,590
We know that Daini N°1 got problems just after events and that Tepco declared that they were "preparing for venting" (it finally did not happen). So here is one where we don't know clearly what happened.
And of course now there is the Hamaoka N°5 reactor with saltwater entering reactor during shutdown due to a leak. Is this leak related to earthquake, we don't know...
  • #7,591
  • #7,592
See IAEA/JNES/NIED Seminar on Nuclear Disaster & General Disaster Management against Tsunami and Earthquake, Tokyo, December 2007, “Safety Assessment and Disaster Management for Tsunami Hazards at Onagawa Nuclear Power Plant”, Y. Matsumoto, (Tohoku Epco, Japan) : http://www.jnes.go.jp/content/000015486.pdf page 10/14 showing a sort of underground tank / sump from which water is taken during a tsunami's low ebb.
See also:
tsutsuji said:
attachment : section view of the turbine building and sea water circuits on page 10 of http://www.pref.fukushima.jp/nuclear/pdf_files/onhaisui-h19houkokusyo.pdf available from http://www.pref.fukushima.jp/nuclear/anzen/onhaisui.html
showing the same sort of design exists at Fukushima Daiichi.
mamoru said:
thanks
  • #7,593
razzz said:
Interesting read about the great quake and land movement both horizontal and vertical at the http://ex-skf.blogspot.com/2011/05/fukushima-i-nuke-plant-ground-may-have.html"
I haven't read anything that said otherwise esp. parts of the island moving 8 feet to the east.
Interesting, thanks for sharing. That seems like very solid data, I mean it comes from the official "Japanse Geospatial Information Authority of Japan (GSI)" site after all (link from ex-skf's blog entry: http://www.gsi.go.jp/chibankansi/chikakukansi40005.html ).
And it comfirms what some people have mentioned on this forum based on the TEPCO webcam pictures.
Thinking of those pictures of that road and the pictures from the New Zealand quake, it's good that at least there was no crack and horizontal offset in the ground right through the site of the power plant.
  • #7,594
Concerning Tepco reassessment of seismic safety data which was required after the Kariwa plant event, read this Tepco communication for shareholders:
http://www.docstoc.com/docs/41609714/Creating-Disaster-resistant-Nuclear-Power-Stations
They say they did new geological surveys at Fukushima, they were due to June 2009 i think. But i can't find these studies.
They should be called something like "Fukushima Daiichi Units Geological Survey Seismic Safety Assessment"...
Maybe a japanese member could try to find this by googling some of these key words in japanese?
  • #7,595
I think i downloaded some pdf document related to geological studies in F-1 weeks ago, they are in japanese and also shows the location where they bored some 300m below ground level around the npp, there are a lot of pages but i don't understand the subject and the my proficiency in the language is not that good.
  • #7,596
Maybe we could try an automatic translation, if you can attach or upload the doc?
I found on tepco site these docs explaining the kind of survey they did:
http://www.tepco.co.jp/en/press/corp-com/release/betu07_e/images/071105e1.pdf
http://www.tepco.co.jp/en/press/corp-com/release/betu07_e/images/071127a.pdf
http://www.tepco.co.jp/en/press/corp-com/release/betu07_e/images/070817e2.pdf
The results would be VERY interesting...
  • #7,597
Here are some various Fukushima Daichi earthquake safety related reports
http://www.nisa.meti.go.jp/shingikai/107/4/1/001/a1-2-4.pdf (13 May 2008)
http://www.nisa.meti.go.jp/shingikai/107/4/1/005/a5-2-1-1.pdf (31 July 2008)
http://www.nisa.meti.go.jp/shingikai/107/4/1/019/a19-2-1.pdf (15 May 2009)
http://www.nsc.go.jp/senmon/shidai/taishin_godo_WG1/taishin_godo_WG1_09/siryo-9-1-1.pdf (22 May 2009)
http://www.pref.fukushima.jp/nuclear/info/pdf_files/100714-13.pdf (22 February 2010)
http://www.tepco.co.jp/nu/material/files/ka10070602.pdf (6 July 2010)
http://www.pref.fukushima.jp/nuclear/info/pdf_files/100805-1.pdf (August 2010)
Speaking about post-2007-quake retrofits, does anyone know the location of the newly built (summer 2010) "Seismic isolated building" within the Fukushima Daichi plant ?
  • #7,598
[URL]http://www.tepco.co.jp/en/nu/fukushima-np/f1/images/f1_lmap-e.gif[/URL]
[URL]http://www.tepco.co.jp/nu/f1-np/pavilion/images/mensin_2.jpg[/URL]
  • #7,599
"www.tepco.co.jp/nu/material/files/fg09062401.pdf"[/URL]
  • #7,600
~kujala~ said:
Ground shaking is amplified in soft sediments and dampened in hard rock...
Not to defend TEPCO, but we must keep in mind that the safe design criteria for buildings of this type are diferent from those of ordinary apartment/office buildings. I recall reding the words 'floating foundation' somewhere, perhaps in a TEPCO document. Instead of anchoring the building to the underlying rock, or driving deep piles into the ground, the idea is to build the basement as a big stiff box that 'floats' on the soil/rock below. That way, if the ground cracks, deforms, liquefies, or shakes too much, the building may move or sink a bit but is less likely to crack or collapse.
In any case, building on bedrock (granite or other volcanic rock) will not help if the rock cracks and shears during a big earthquake. (Recall that the cause of the earthquake was a 500 km long crack that caused two pieces of that 'solid bedrock' to slide tens of meters past each other.) Anchoring the building to the bedrock seems a rather bad idea in that case.
According to the blueprints, the thickness of the reactor building walls increases from top to bottom. The service room wall panels are perhaps 30--50 cm thick and thinly reinforced; but 2nd floor walls seem to be 1.2 meters thick, basement walls are at least 1.5 meters thick, and the basement floor slab is 4 meters thick. (That by itself would explain why the explosions did very little visible damage below the 3rd floor.)
Thus I am willing to believe that the buildings of the reactors are pretty safe against earthquakes, and suffered no damage on 11/mar. (That does not apply to the reactors proper and other equipment, of course) I have yet to see a picture of any crack or other damage to those buildings that was caused by the earthquaque itself.
In particular, I do not see any possibility of their lower levels sinking, tilting or collapsing to any significant extent, even if they were resting on top of soil rather than rock. Thus the tilting of #4 that is supposedly visible in the webcam --- and only there --- can only be an optical illusion or artifact.
The type of the underlying rock could matter for the safety of the equipment inside (mudstone results in stronger shaking than granite, it seems) and for the water leakage problem (mudstone probably has more cracks and pores).
Of course, some parts of the upper floors that were damaged by the explosions are now visibly unsafe, even against minor quakes or storms. (Could a tornado blow away the loosely-hanging wall panels of #3 and #4?)
49K
449K
273K
16K
11K
