Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The Fukushima Daiichi nuclear plant is facing significant challenges following the earthquake, with reports indicating that reactor pressure has reached dangerous levels, potentially 2.1 times capacity. TEPCO has lost control of pressure at a second unit, raising concerns about safety and management accountability. The reactor is currently off but continues to produce decay heat, necessitating cooling to prevent a meltdown. There are conflicting reports about an explosion, with indications that it may have originated from a buildup of hydrogen around the containment vessel. The situation remains serious, and TEPCO plans to flood the containment vessel with seawater as a cooling measure.
  • #9,801
biffvernon said:
The trouble with general terms like 'sandstone' and 'mudstone' is that they tell you approximately nothing about the strength and probably nothing about the permeability of the rock.
As far as I understand the velocity of the S-waves are dependent on the strength of the rock ie the harder the rock the faster the S-waves. Faster is better.
So as we know that S-wave velocity in two different earthquakes has been around 520 m/s in Fukushima I think we can make some assumptions based on that. Or can we?
http://varasto.kerrostalo.huone.net/lietekivi_4.png
This would be quite normal S-wave velocity for mudstones/sandstones when compared to those in San Fransisco:
http://varasto.kerrostalo.huone.net/lietekivi_2.png
Actually it's a little on the slow side because the borders are 350 m/s - 750 m/s so in the middle it would be 550 m/s and it's 520 m/s. But I suppose this is something to be expected because we also know that sandstone/siltstone in Fukushima is young (Quaternary).
On the other hand the soil amplification for class C in the above chart is considered not to be as significant as for classes D/E. But it's not the same as for classes A/B where no significant soil amplification is considered.
Some other hints might be found from these drawings - according to Astronuc the numbers in the first one might be pressure gradients. What about the velocities in the second one? Could they be P-wave velocities (1,600 m/s - 1,700 m/s for mudstone):
http://varasto.kerrostalo.huone.net/lietekivi_5.png
http://varasto.kerrostalo.huone.net/lietekivi_6.png
  • #9,803
Bandit127 said:
All 4 videos are now hosted on my site
Are you sure they are properly described?
  • #9,804
StrangeBeauty said:
Could it be that the white spots are neutron reflectors and the black spots neutron absorbers creating a moderating field for recriticality?!
Yes! It must have been a borderline collie!
Apologies for the physics humor. ;)
Thanks so much for the humour...I needed the comic relief!
  • #9,805
Pu239 said:
Have a look at the following videos. I'll drop this topic very shortly, but I do want some kind of corroboration, given that this board's topic is: Physics Forums > Engineering > Nuclear Engineering > Japan Earthquake: nuclear plants.
This was not
- a false alarm
- one of the many false alarms
- one of the many frequent steam displays
It was a *massive* and significant steam/vapour display that started with a clearly visible vertical emission of vapour, then blotted out all the other reactors - starting around 2:15 in the first video below. Also look at the 10 second mark in the second video. They look very much like explosions to me:
Here's the video:
2011.06.14 00:00-01:00 / 福島原発ライブカメラ (Live Fukushima Nuclear Plant Cam)
http://www.youtube.com/fuku1live#p/u/9/k-EDceWFovc
2011.06.14 01:00-02:00 / 福島原発ライブカメラ (Live Fukushima Nuclear Plant Cam)
http://www.youtube.com/fuku1live#p/u/8/fg8yGBhoLxU
Not an expert, however, just because the dew-point may enable better visualization of the "steam" does that mean the ongoing release is not "important"?
  • #9,806
No, it doesn't necessarily mean the releases aren't important. It just means there probably isn't as drastic a change in the amount being released as some interpretations of the visible vapors have suggested (as seen in the videos being discussed above).
I'd also like to see some measurements taken from within the releases (as others have mentioned).
  • #9,807
Tepco plans to create the first nuclear powered Zeppelin:
http://www3.nhk.or.jp/daily/english/15_07.html
The operator of the Fukushima Daiichi nuclear plant will begin to cover the No.1 reactor building with polyester sheets this month to prevent the dispersal of radioactive substances.
The buildings of the No.1, 3, and 4 reactors were severely damaged by explosions and radioactive elements are still being released into the atmosphere. There are fears that heavy rain may hamper the workers' activities and that the rainwater may become contaminated with radioactive materials.
To prevent these situations, Tokyo Electric Power Company, or TEPCO, plans to enclose the reactor buildings with polyester sheets. The covering of the No.1 reactor building will begin later this month.
I hope that this plan makes more sense than it seems to. If the purpose is to contain the gasses and they do in fact make a leakproof covering, they will have created a Zeppelin. If hydrogen is still being produced, they will have made the Hindenberg.
Of course, if they vent the gasses to keep this from happening, then what was the point of exposing all of those workers?
All of this is aside from the fact that 1mm thick polyester is not going to survive a good gale, let alone a typhoon. I have some experience with this, having had a large expensive product shipped from China nicely wrapped in heavy-duty heat shrink poly. The captain of the container ship said that the covering barely made it out of the harbor before being ripped to shreds.
I think that the upshot of this exercise is that Tepco is now going to have to figure out how to dispose of hundreds of meters of shredded, highly contaminated polyester. This will not be easy, to say the least.
Edit: Oh by the way, that stuff floats...
  • #9,808
Might they possibly include hydrogen recombiners and filtered venting? I don't know but that might help!
  • #9,809
http://www3.nhk.or.jp/daily/english/15_07.html I hope that this plan makes more sense than it seems to. If the purpose is to contain the gasses and they do in fact make a leakproof covering, they will have created a Zeppelin. If hydrogen is still being produced, they will have made the Hindenberg.
Are there not several stadiums and even Denver Airport covered with some sort of fabric?
I assume this is not shrinkwrap that they plan on using.
In general, surely it is better to keep the dirt collected and try to deal with it immediately than to allow it to waft all over and then to try to clean some of it up as is the case presently.
  • #9,810
Edit:
Just read the NHK writeup with the 1 mm poly detail in the story.
That does seem quite inadequate, especially as this is a flat structure, the wind pressure on it will be material.
Apparently this is a temporary initial version which is supposed to be replaced in the longer term by a more robust enclosure to shelter the eventual dismantling of the reactor building.
  • #9,811
No, that really won't be a problem, because:
TEPCO aims to complete the covering operation in late September
...which is the usual time of the year the typhoon season ends in Japan.
But seriously, a lot of commercial greenhouses here in Japan use plastic sheets over a metal frame, instead of glass sheets. It does seem to work for the local climate. I wouldn't totally dismiss it as being unsuitable because of wind. It really depends on how it's done.
  • #9,812
Bodge said:
Now 15 days without update.
Since the figures seem to already have dropped by about 4 orders of a magnitude during the published interval, we should consider the possibility that figures since the end of updates have been below detection level:
[PLAIN]http://www.bfs.de/de/ion/imis/spurenmessstellen_caesium.jpg
The data published since May 10 has only been sampled weekly.
Bodge said:
I am expecting the pattern of I-131 spikes to continue into June.
It's been 95 days since the reactors were scrammed on March 11. That's almost 12 half lives for I-131. All but 1/4096 of it should have decayed by now. Cesium is another matter of course.
EDIT: Yes, it looks like worldwide samples (except in Japan) are falling below detection thresholds (shaded in gray at the bottom):
Iodine-131:
[PLAIN]http://www.bfs.de/de/ion/imis/ctbto_aktivitaetskonzentrationen_jod.gif
Cesium-137:
[PLAIN]http://www.bfs.de/de/ion/imis/ctbto_aktivitaetskonzentrationen_caesium.gif
The dashed orange lines are German maximum daily averages after the Chernobyl disaster.
  • #9,813
Initial test runs using low level contaminated water showed the Kurion cesium removal process did cut the cesium level in the treated water to 1/3000th of the initial value, in the middle of the predicted performance range.
The NHK report is here: http://www3.nhk.or.jp/daily/english/14_37.html
Note that the full train including the Areva coprecipitation and desalination treatment has not yet been run, nor is there any data on flow rates or test duration for this test.
These kind of columns can be somewhat sensitive to channeling, which would reduce efficiency.
So the performance needs to be monitored on an ongoing basis.
  • #9,814
There is a big difference between a greenhouse, usually a smooth wind cheating structure close to the ground
and this square sided tower. Ask any sailor what the stress on a sail maybe 100 feet high and equally wide will be.
  • #9,815
Sandstone is any sedimentary rock composed of sand grains; mudstone is a sedimentary rock made of much finer particles; siltstone is a sedimentary rock made of particles finer than sand but coarser than mud.
Sandstone may be very weak, crumbling in your hand, if the matrix that holds the sand grains together is weak. At the other extreme a metaquartzite is a rock made of grains of quartz sand cemented together by quartz that has crystallised in conditions of relatively high temperatures and pressures. It's harder and stronger than granite.
In the Fukushima case we seem to be dealing with something not so extreme. It is probably safe to assume that the sandstones and siltstones at the site are quite adequate to build power plants upon (the area of alluvium to the north and to the south has been avoided) and that for most practical purposes the siltstones can be regarded as impermeable to the flow of water while the sandstones will allow the passage of water albeit it at very slow rates. There is likely to be a net flow of water through the rock towards the sea, pressured by rainwater descending from the higher ground inland. Over a period of years one might expect contaminated water to move down and out and released to the Pacific Ocean.
There may be other pathways, joints and bedding planes, even cracks caused by earthquakes, that allow faster flow in complex directions but one needs more site-specific data to judge that.
I just got another email from the geologist concerning groundwater flow:
"The ground water generally flow from elevated part of the aquifer to the structual low of the aquifer. In the plain, it is usually from the mountain (catchment area of the rain) to the sea, unless the flow makes a short-cut to a nearby river/stream or lake. As the cross-section of the aquifer in the paper you showed me showed that they are inclined to the sea, it is likely that the overall flow is from the land to sea, even though it might locally flow to different directions (i.e., landwards), notably from the source of the contamination for a few km. But in a general rule, aquifers located far landward of the nuke plant is safer.
It is ironic that scientists/engineers use radioactive source called Tracer to check the underground movement of water within aquifer - after a few months, the movement of the Tracer is checked in nearby wells, rivers, seas, surface reservoir (ponds/lakes). This is the most powerful and reliable way to determine the flow pattern of an aquifer in a given region (other way is to measure pressure gradient within the area, but it is less reliable). Tracer usually exhibits a negligible amount of radioacitvity and is harmless to health, but, this time, gigantic amount of "tracer" has been injected within the hydrologic system in both surface and underground waters. So the best way to check the movement of the ground water is simply to measure radioactivity of waters from the wells/streams/ponds, etc. around the nuke plant."
  • #9,816
Correct me if I'm wrong, but I think the Quarternary deposits are to the north and to the south of the plant. The sandstones and siltstone below the plant are much older (and stronger).
How a rock behaves in an earthquake is very complicated and how a building sitting on top behaves is even more so. A hard rock will transmit the earthquakes energy quickly with high frequency small amplitude movements. You get high acceleration but small linear movement. A soft rock will move more slowly but further and that is often more damaging to a building, particularly when it sways in resonance.
Here's an analogy. Take three coins placed on a smooth table. Hold one down firmly with a finger, place the second touching the first. Flick the third into the held down coin hitting it on the side opposite the second coin. The held down coin will not move but the second coin will shoot off across the table.
The held down coin is like the hard rock, transmitting the shockwave without visibly moving. The second coin is like the soft rock, it experiences a large magnitude acceleration. Don't build your nuclear power plant on the second coin.
  • #9,817
I don't know. I tried to find geological maps for Daiichi area and I found maps quite near the plant but that's not enough. If I remember correctly in some earlier discussions some maps were also presented. You never find anything when you really want to... :smile:
Could you show your source for the above claim so we could all see it?
  • #9,818
The plan makes perfect sense if we regard it as simply TEPCO attempting to hide what is going on. I won't be surprised if TEPCO "discover" that hydrogen is lighter than air and "unfortunately" they will have to allow venting from their "greenhouse", but still not allow us to peek in there.
  • #9,819
LOL There was a map posted here several pages ago! The anonymous professor gave the name of the Sandstone/siltstone formation. This is the 'bedrock' that the power plants are built on. The Quarternary deposits cover this bedrock just north and south of the site. The builders were not completely daft!
See post 9753:
" it has been long known that around the Fukushima Daiichi Plant is sedimentary rock Taga Group; around the plant this rock is called the Tomioka Formation, whch is made of coarse sandstone (or Grit) and tuffaceous siltstone."
  • #9,820
MiceAndMen said:
The number of posts here regarding the non-events observed while glued to the Fukushima Webcam Entertainment Network is getting annoying.
I would second a motion to create a photo interpretation thread, or the renaming of the Unit 3 explosion thread to become general photo interpretaion.
It has it's place but it takes up lots of forum inches. If this is anything like the Macondo deal then the discussions will go on long after the cameras have stopped rolling.
  • #9,821
Oh dear, I've just found a paper about the geology written in English:https://ir.kochi-u.ac.jp/dspace/bitstream/10126/2261/1/N022-04.pdf
The Taga Group and its Tomioka Formation are indeed Quarternary - Late Miocene/Early Pliocene. Much younger than I had assumed and so likely to be much softer and more wobbly in an earthquake. Deary me.
  • #9,822
Great find! I've passed it on for comment. It's from 1973 it seems, not long in geologic time for sure but maybe the region is better understood now.
  • #9,823
OK so we now have some results from air sampling above reactor 3, like we previously got for 1 & 4.
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110614_03-e.pdf
As withthe previous tests, I am not sure whether their methods are very good for doing a decent estimate. And I've no idea how to convert the numbers shown into something a bit more useful, such as estimated release rate.
  • #9,824
Thank you for exactly reading between the lines. A separate thread is called for IMO. I have all but stopped following this thread; I see 3, 4, 5 posts in a row regarding the webcam and I just "page down, page down, page down ... next page". Very bad for the signal to noise ratio. Can anyone point out ONE post mentioning any of the webcams post-unit-3-explosion that was newsworthy? Explosion here, vapors there, steam and smoke over there, but hyperventilating viewers everywhere.
TV viewers like to think they are seeing things that are worthwhile. Entertainment, news, current events, paparazzi, bread and circuses... it's all the same. Worthless speculation ensues. News at 11.
  • #9,825
Feel free to start a new thread, you don't need Admin privileges to do so :wink:
  • #9,826
biffvernon said:
See post 9753:
Yes, but the professor is also saying:
I have talked with some of my colleagues (geology professors) today, and some of them knew for many years/decades that the bed rock of the Fukushima Daiichi Nuke Power Plant is soft sedimentary rock.
Why would he (they) be worried about geological issues if it would only concern some areas outside the plant area? It makes no sense.
I think it is this very mixture of siltstone/sandstone that they think is "soft". And I think it is also this "soft" siltstone/sandstone that they believe is below the Daiichi plant.
I also noticed that in the first sentence he is using the word "around" which might be some kind of translation issue. Or perhaps he means that the geological structure outside the plant area is known for sure and inside the plant area only TEPCO knows it absolutely sure?
BTW, I am referring to discussions about 1 - 2 months ago. I remember that some documents were presented that contained detailed geological information. But I don't remember what the conclusion was back then.
  • #9,827
:oops: That should have read Tertiary rather than Quaternary (but it doesn't change the argument very much).
The basement rock of granite type material starts about 800 meters below the power plant and is overlain by the Tomioka Formation of Late Miocene/Early Pliocene sedimentary rocks upon which the the plant is built.
This paper: Granitoids with 300 Ma in the Joban coastal region, east of Abukuma Plateau, northeast Japan. Journal of Mineralogical and Petrological Sciences Vol. 105 (2010) , No. 6 December 320-327 Yukiyasu TSUTSUMI et al.
http://www.jstage.jst.go.jp/article/jmps/105/6/105_320/_article
describes a deep borehole into the basement from a site pretty close to Fukushima Daiichi. It also has a map that shows a couple of big lines marked Futaba Shear Zone and Hatakawa Shear Zone.
Now will somebody please tell me that these do not represent any kind of earthquake hazard.
  • #9,828
Yes, I also found this paper (and couple of others) but...
If you look carefully the map (figure 3) on page 106, the area of the study only goes as far as Yamadahama in the north.
Both Fukushima I and II NPP:s are both further away to north. So the proof is still not absolute.
Also in the figure 1 on page 104 it is said that Taga group goes as far as Tomioka but Fukushima I is still not covered.
But if the professor says Taga group also covers Fukushima I perhaps we should believe him?
http://www.boston.com/news/world/asia/fukushima_nuclear_plant/
The pin A is near Tomioka. It's Daini.
The pin B is located further away to north. It's Daiichi. It's located near Futaba.
  • #9,829
Right, to summarise, I think what we now know is that we have some soft, Quaternary, deposits, maybe fluvial or marine alluvium, to the north and south of the site. That would not be sensible to build anything very heavy upon.
The plant itself is built on the Tertiary Sandstone/siltston/mudstone complex known as the Tomioka Formation. It's perhaps not ideal but was judged strong enough to support heavy buildings.
800 metres below is the granitic basement. This outcrops at the surface a few kilometres inland.
That granitic basement has a couple of major shear zones trending NNW-SSE a few km west of the plant.
And to speculate, rather than what we know, if those shear zones are potentially active (and the fact that there has not been a major earthquake on them for 400 years does not mean they aren't potentially active) then building a nuke on Tertiary sediments a few km away might be judged, generously, as hoping for the best.
  • #9,830
I guess it was these fault lines that the professor described:
So people thought the region is relatively safer in terms of bed rocks and fault systems. But after the 3-11 earthquake, many "inactive" fault systems moved, causing some problems such as landslides or forming sink holes. Some of these faults CUT through these hard rocks, which people, including many geologists, thought quite unusual (if not impossible) utill they saw the consequence of the 3-11 Earthquake in Tohoku.
... and there are a few active faults around*the plant*(they have been recently*found to be active after the 3-11 Earthquake)
I don't know how much harm they could cause for Daiichi, though.
  • #9,831
Yes, you're right.
  • #9,832
MiceAndMen said:
<..>Can anyone point out ONE post mentioning any of the webcams post-unit-3-explosion that was newsworthy? <..>
To be newsworthy in the common sense of that word, I reckon such webcams would have to show something like explosions, fires, or at the very least some dramatic evolution of smoke or steam. I think I have mentioned in some of my posts the 7am webcam from March 15th (explosion in unit 4), and the webcams from March 21st and March 24th (dramatic smoke events at unit 3). They were all, I think, newsworthy.
However, 'newsworthy' is hardly a criterium for what can be mentioned in this thread. In fact preciously little of what is being mentioned here would have the interest of the general public.
  • #9,833
Indeed. Otherwise, why would they be saying on one hand that they need to open the doors to lower the internal radiation levels for workers, while on the other hand they are saying they need to build a tent to contain the contamination within the work area.
In Japan, blue vinyl sheets are often used by the police to hide crime scenes from cameras.
  • #9,834
I guess I have to say it again. If you contain the buildings, it allows you to filter the venting instead of letting it drift down wind. That is justification enough. As to hiding what is going on iside a containment "tent," don't you think by now that we already know something bad happened there? If offsite dose rates decline or increase isn't that good enough to tell whether their efforts are working?
Other than speculation about steam and fog and light flashes what has anybody seen while there is no tent? One big gain of installing a tent might be to let all of the looky loos sitting staring at the live webcam to get back to their lives.
  • #9,835
Interesting video filmed on June 9 (during sampling and radiation measurement) in Unit 3 (53MB zip, unzips with no problems):
http://www.tepco.co.jp/en/news/110311/images/110615_01.zip
  • #9,836
NUCENG said:
snip >
No, it just means the tent will be on fire twice a week.
  • #9,837
1mm poly is a lot thicker than standard greenhouse poly, too (6mil).
  • #9,838
It will probably do. Unless it doesn't. What are they going to do with the radioactive steam, though? It's not like it's going to magically stop just because they implement closed-loop cooling and somehow I don't see anyone going in there to find and plug cracks in the RPVs anytime soon.
  • #9,839
Inside Reactor Unit 3
Video Taken 9 June 2011
Released 15 June 2011
https://www.youtube.com/watch?v=nYQS0n-EihM
  • #9,840
Interesting. I get the feeling when they are sticking the long poles down into the stairway, they don't want to go down those stairs to get measurements or samples.
  • #9,841
I think they used sensors on these poles to check out for radiation before entering the area.
  • #9,842
DR13 said:
Is there any real chance at a meltdown or is that just the typical media hype?
It's funny, because I saw the media as playing down the entire thing. They never even tried to get independent measurements, which would have made for a huge story. Instead they pretty much bought the official nonsense, and never lifted a finger to find out anything firsthand.
Not even when the US military diverted ships from the area.
  • #9,843
I think the media lost its interest when the land side measurements of Greenpeace and a few others were in accordance with those from the government (even though the interpretation of those measurements differed quite a bit).
  • #9,844
It seemed to me that they were very cautiously trying to determine the flooding level in the lower regions of the building- and once they found the upper extent of the water, they probably beat one hell of a hasty retreat. Seeing that greenish coloration begin one tread down at the lowest stairwell area they got down to (at 1:38) looked like the water level to me, and I'd have to believe that said water would be more than a little radioactive.
Those folks are very, very brave.
  • #9,845
They are using 40mil poly pond liner (40mil = 1mm). If 40mil poly held up to the sorts of winds that are common around an ocean, then yacht sails would be a heck of a lot cheaper! One uses poly on greenhouses because it is cheap and easy to fix when it blows out -- in fact one of the advantages is that it does blow out, which means that your greenhouse frame stays intact. Poly is not a recommended building material for windows or walls or even really trans-pacific shipping purposes. (Steel containers are used for that when possible.)
I want this problem to be solved; if Gunderson is to be believed then I'm breathing the same hot particles that those of you who live in Tokyo do (albeit not quite as many.) But this approach looks to me like an upper-management obession rather than an engineering fix. I'm willing to be wrong on this, but the snippet in the video of the exec showing an autocad presentation with little square walls magically hopping on top of each other didn't give me much confidence about the engineering thought that went into this idea.
If the structure could be constructed and did in fact hold up and was airtight (which I consider doubtful), then I question the wisdom of adding sails to damaged buildings of unknown structural integrity in a location that is prone to typhoons. If that isn't enough, then realize that they are vaporizing 1300 gallons/hr in reactor #1 plus an unspecified amount of water in the SFP. That is over 8000 cubic meters of vapor per hour that needs to be dealt with to keep the bag from turning into a blimp.
Add to the mix the fact that we are still arguing why reactor #4 exploded and you can see why I am doubtful about the wisdom of putting all of the reactor's work product into a plastic bag and blowing it out with electric fans.
If they get the plan to work, then I also question how they plan to approach the reactor now that they have a 1300 gph rainstorm of radioactive water flowing down the inside of the bag -- assuming that the steam doesn't just melt the poly straight away. It is not only water that would be contained, but some percentage of the heat; and the temps in that reactor building are significant.
I think that this is a plan that looks good to an engineer who hasn't worked much with poly sheets...
  • #9,846
They were improperly described - it was past my bedtime and I just cut and paste the descriptions from TEPCO's website.
I have now tried to correct the descriptions as well as I can.
The 4th video is corrupt for me too - only 16 s long.
I will leave them up there and use the page if further zipped videos appear on Tepco's site. Please let me know if you want any videos unzipping and reposting.
P.S. If it was Solidworks that was used to generate the CG animations then good skills from the engineer(s) involved. A lot of work went into that - possibly hundreds of man-hours, certainly tens.
  • #9,847
The geology discussion could use it's own thread.
  • #9,848
I would appreciate it if you could please recommend the soulution that you would use or at a minimun a solution to what you precive as the problems with the design. I agree that there are many "what ifs" here, you seem to have spent sometime on this problem so what direction, and time frame to do it would you take?
  • #9,849
Or walked into a greenhouse in the middle of Summer to water the plants.
For reference, the yield strength of polyethylene is about 4,000 psi or about 25 MPa. About 1/3 that of copper (at 70 MPa).
So, a 1 mm square string could support ~2.5 kg. Or a 25 mm x 1 mm strip could support ~62.5 kg.
We will wait and see, but I am optimistic that it isn't in tatters by this time next year.
  • #9,850
Afaik, all larger fabric covered structures are either largely self supported, by increased internal air pressure, or they use a very robust reenforced membrane, with tensioner webbing incorporated into the fabric.
None use flat panels of fabric, which have no strength against perpendicular loads, nor do they use a right angle based framework, because that is just an invitation for eddies and turbulence creating stresses at odd angles, which the poly skin is not well suited for.
The flat frame structure is surely the easiest to put up, especially as there is not enough room to accommodate individual bubbles because the reactors are so close together. Also, a light framework that is easy to erect and is without big foundations probably cannot support much more than a film wall. TEPCO does say the building is temporary, which it is perhaps even more so than might be wished.
Imho, it will at least give TEPCO a dry run to see what the problems posed by a closed containment will be,
but otherwise it seems impractical.
49K
449K
274K
16K
11K
