zapperzero
- 1,045
- 2
Sounds like bits of roofing.
Sotan said:http://www.tepco.co.jp/nu/fukushima-np/handouts/2014/images/handouts_140214_04-j.pdf
(in Japanese)
It's a report on the results of checks performed in the building of Reactor 3, after removing the debris.
Many interesting photos.
One important finding is that the massive concrete shield plug that covers the PCV (made of 3 slabs of concrete stacked one atop the other, each 600 mm thick) appears to have a big "dent", the surface is pushed in, about 300 mm. Most likely caused by the fall of the ceiling crane (it had a big heavy trolley right in that area). They don't seem much alarmed by this, though, as it probably didn't cause important damage to the PCV and the situation seems to be stable now.
Sean Thornock said:Meltdown: What Really Happened at Fukushima?
http://www.thewire.com/global/2011/07/meltdown-what-really-happened-fukushima/39541/
Sean Thornock said:I'm wondering also how they can clear the 50 tons of steel, refueling mast and cement out of the #3 fuel pool. Could these fuel racks still be intact ? I wonder how this can be done.
Sean Thornock said:I heard that can't even get robots near this area.
Rive said:I'm afraid it's simply not true. They've sent robots even much worse areas and doing their jobs as scheduled by remotes, robots and: personally too.
The top of the U3 was cleaned up with remote controlled machinery. That cleanup was performed unexpectedly well. The pool of U3 will be emptied by the same machinery.
Sean Thornock said:And what about Cobalt-60 ? Or last weeks Cesium-137 54,000 Bq / Liter / Or the new revised Strontium-90 5 million Bq / Liter per recent well reading.
After 3 years the readings are quickening not slowing.
Sean Thornock said:I thought those fuel rods were delicate & the radiation levels at unit three are off the charts. Much different then taking wreckage from the roof. The #3 sfp is in very bad shape.
BWR/6 Fuel Assemblies & Control Rod Module ( these can't handle 50 tons without sever damage )
http://www.nucleartourist.com/images/bwrfuel1.jpg
What do you think about the fault / sandstone below the corium kinda makes it hard to stop the 600 tons of water flowing toward the ocean every day, no ?
The authors have spoken to several workers at the plant who recite the same story: Serious damage to piping and at least one of the reactors before the tsunami hit. All have requested anonymity because they are still working at the plant or are connected with TEPCO. One worker, a maintenance engineer in his late twenties who was at the Fukushima complex on March 11, recalls hissing and leaking pipes. “I personally saw pipes that came apart and I assume that there were many more that had been broken throughout the plant. There’s no doubt that the earthquake did a lot of damage inside the plant," he said. "There were definitely leaking pipes, but we don’t know which pipes – that has to be investigated. I also saw that part of the wall of the turbine building for Unit 1 had come away. That crack might have affected the reactor.”
A second worker, a technician in his late 30s, who was also on site at the time of the earthquake, narrated what happened. “It felt like the earthquake hit in two waves, the first impact was so intense you could see the building shaking, the pipes buckling, and within minutes, I saw pipes bursting. Some fell off the wall. Others snapped. I was pretty sure that some of the oxygen tanks stored on site had exploded but I didn’t see for myself. Someone yelled that we all needed to evacuate and I was good with that. But I was severely alarmed because as I was leaving I was told and I could see that several pipes had cracked open, including what I believe were cold water supply pipes. That would mean that coolant couldn’t get to the reactor core. If you can’t sufficiently get the coolant to the core, it melts down. You don’t have to have to be a nuclear scientist to figure that out.”
Before the dawn on March 12, the water levels at the reactor began to plummet and the radiation began rising. Meltdown was taking place. The TEPCO Press release issued on March 12 just past 4am stated, “the pressure within the containment vessel is high but stable.” There was a note buried in the release that many people missed. “The emergency water circulation system was cooling the steam within the core; it has ceased to function.”
Oddly enough, while TEPCO later insisted that the cause of the meltdown was the tsunami knocking out emergency power systems, at the 7:47 p.m. TEPCO press conference the same day, the spokesman in response to questions from the press about the cooling systems stated that the emergency water circulation equipment and reactor core isolation time cooling systems would work even without electricity.
Decay heat projections SFP all levels, funny thing is the worst spot / water height low-mid level point on rods, it stops water / air circulation.
Sean Thornock said:I heard that can't even get robots near this area. TEPCO announced record cesium & today cobalt-60 readings in the test wells.
nikkkom said:What is "off the charts"? Engineering is done with numbers, otherwise it's handwaving.
jim hardy said:well duu-uhh, - that's why you keep the pool filled.
and why the bottom of door is above top of fuel.
Sean Thornock said:I'll let the article stand on its merit. It has more information regarding TEPCO issues in the past regarding those pipes in question. Workers said they seen busted pipes in an article a few months after the disaster. Many of the assertions regarding safety issues are searchable.
What about the rubber seals on the SFP doors that inflate with air. Those will not hold air without power. ( fuel pool gate between pool & reactor. Powered by electricity off grid not diesel backups or batteries. ( Hatch/Georgia 1986 lost 141,000 gallons in a few hours time because of this same issue. )
I'd like to talk about the Cobalt-60, Manganese-54 ( neutron activation radionuclide / product ) & the large Cesium levels ( wells 1-6 ) pointing toward sfp criticality.
Hiddencamper said:As for spent fuel pool gates, do you honestly believe they just left the pools without gates and did nothing for the past 3 years? Seriously? Apparently you don't realize the Mark I BWR design for spent fuel pools is such that even with a total gate failure, water will not uncover the fuel (the bottom of the gate is above the top of fuel). Additionally, there is no evidence a total gate failure happened.
