Sotan
- 330
- 254
A new NRA meeting was held on Jan 13, 2023 to discuss the materials listed here (in Japanese).
I opened this document, which is a general review of what is known about the nuclear accident until now. I will post below the translation of a portion of this document, starting with the page numbered 26 in the PDF file. It's google translation with just a few small edits by me where the result seemed odd. The fragment presents the findings on debris at the bottom of the PCV of Unit 1, based on the investigations made up to date, and suggests/discusses 3 scenarios that are taken into consideration. The text on the 3 scenarios is presented in the post following this one, in case there is a limit in size (apologies for the length of these posts.)
Chapter 2
Behavior of the Falling Core and its Impact on the Primary Containment Vessel
Section 1 Inside the Unit 1 Primary Containment Vessel, Examination Status
2-1-1 TEPCO Report and Features
Since February, we have been taking pictures of the inside of the Unit 1 reactor containment vessel. The specific equipment, details of implementation, and photographing results are described in Attachment 4-1. Prior to this, TEPCO and IRID have taken pictures of the inside of the reactor containment vessels of Units 2 and 3. Although it is not yet sufficient due to the severity of the environment, the information obtained in the process is summarized in Attachment 4-2. The results of the photography inside the PCV of Unit 1 differed greatly from the results of photography inside the PCV of Units 2 and 3, which had already been carried out, and this attracted attention. In addition, photography of the inside of the reactor containment vessels of each unit has not progressed sufficiently, and the above understanding may change in the future.
The photographing results that attracted attention are as follows (see FIGS. 8 to 10). (See Attachment 4-3)
(1) TEPCO determined that there was a mound-like object with a height of about 1.0m, which was likely derived from the fallen molten core, near the Unit 1 pedestal opening.
(2) Concrete near the Unit 1 pedestal opening has been lost over a considerable area. On the other hand, the reinforcing bars and inner skirt that were inside the concrete have remained almost unchanged. Such a phenomenon has not been confirmed in Units 2 and 3 so far.
(3) A terraced structure was observed around the pedestal, with a height of 1.0 to 1.1m from the bottom of the primary containment vessel near the opening, and a height of 0.2 to 0.4m on the opposite side of the opening. Moreover, it seems that the concrete failure occurs only in the part below the terrace structure.
(4) Although it is a small part, a cross-sectional image of a terrace-like structure has been obtained, and a structure with bubbles can be seen, but nothing more is known about these. The thickness of the section is estimated to be approximately 3 cm. Note that the lower surface of the terraced structure appears smooth.
(5) Deposits thought to have arrived from the pedestal can be seen on the back side of the jet deflector located at the outermost periphery of the reactor containment vessel, but no major damage is seen on the jet deflector itself. As far as it can be seen, there is no major damage to the inner surface of the reactor containment vessel.
(6) It has been confirmed that the lower part of the terrace structure is hollow near the pedestal opening, but it is unknown at this stage what happens in places away from the opening. In addition, in places where there are few structures in front of the pedestal opening, the terraced structure has fallen onto the floor of the containment vessel.
(7) Metal structures such as pipes located at the bottom of the terrace structure appear to be mostly maintained. However, the RCW (Reactor Cooling System) piping near the opening is not in its original position, and its whereabouts have not been confirmed.
(8) The lead shield mats (lead wool mats) appears to have melted and fallen at the position of the terrace structure. At the top of the terrace structure, the covering material (glass fiber) of the lead shield mat (lead wool mat) seems to be maintained, and the effect of the significant high temperature seems to be limited to the vicinity of the terrace structure. In addition, TEPCO confirmed that the lead shielding was lost below the same height as the opening of the pedestal even on the opposite side of the pedestal opening.
(9) A bubble-shaped object can be seen at the pedestal opening at a height of 1.4m, but it is clear that there is a space below it. However, no information has been obtained as to what the back surface of the bubble-shaped portion looks like.
(10) Debris deposits on the floor surface of the reactor containment vessel around the pedestal are unclear, but some hemispherical objects have been photographed. (It is not clear at this stage what exactly it is.)
Chapter 2
