Just Tell Me If Its Doable (Vectors)
  • Thread starter Thread starter sugarntwiligh
    Vectors
The discussion focuses on solving a vector problem involving vector A and vector C, specifically calculating the vector A - C. The user correctly calculates the components of vector A but initially misunderstands the relevance of vector B, which is not needed for this calculation. After clarification, they realize that to find A - C, they need to invert the components of vector C. Ultimately, they compute the magnitude of the resultant vector as 91.8 and the direction as 54.8 degrees from the positive x-axis. The problem is deemed solvable with the correct approach to vector subtraction.
sugarntwiligh
Just Tell Me If Its "Doable" (Vectors)
Here's the problem:
Give magnitude and direction from the positive x axis, given A=60. Use the following picture:
http://www.webassign.net/giancoli5/3_35alt.gif
I know how to do vectors...
Ax: 60cos(28)=52.98
Ay: 60sin(28)=28.17
Cx: 0
Cy: 46.8
B: ?
B: ?
Now correct me if I am wrong, but don't I need the angle of B in order to solve?
What's the exact statement of the problem?
Determine the vector A - C, given the vectors A and C in Fig. 3-35 (A = 60.0).
Magnitude:_____
Direction:____ ° (from the positive x axis)
This has nothing to do with B, so B's angle is not needed.
Ax: 60cos(28)=52.98
Ay: 60sin(28)=28.17
Cx: 0
Cy: 46.8
Good, except for the sign of Cy.
Oh ok I got it now. Since its A-C, I just take my C values and times them by -1. So now I have,
C=-46.8(-1)=46.8 (y)
C=0 (x)
And then I take the values Rx and Ry:
Rx: 52.98
Ry: 74.97
And plug in the formula:
squareroot(52.98^2+74.97^2)=91.8
And I get my angle:
tan-1(74.97/52.98)=54.8
Yay!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
