Kicking a Ball Upwards with force x and mass y
  • Thread starter Thread starter Gui
    Ball Force Mass
A 2kg ball is kicked upwards with a force of 50N, prompting a discussion on how to calculate its maximum height and time in the air while considering gravity. Initial calculations suggest an acceleration of 25 m/s², but confusion arises regarding the application of equations and the need for the duration of the force application. The missing variable is the time the force acts on the ball, which is crucial for determining the initial velocity. Energy conservation principles are introduced, stating that the initial kinetic energy converts to potential energy at the peak height, allowing for further calculations of height and time. The discussion emphasizes the importance of understanding both momentum and energy conservation in solving the problem effectively.
Gui
Problem (this is an extra credit challenge kinda thing): You kick a 2kg ball with 50N of force, directly upwards. The ball is not moving when you kick it. How far does it go and how long is it in the air (take gravity into consideration)?
I don't know, but I've been discussing this on #physics at freenode and 2 equation have been proposed although we haven't managed to figure it out yet: a = a0 - g*t AND v = v0 + at
I'm not sure whether each of them is right or not, but it's been tossed around and discussed. I've also been told I don't have enough information, but my teacher told me I did.
First, I tried this:
force = 50N
mass = 2kg
acceleration = ? = 25 m/s/s
gravity = 9.8 m/s/s
a = a0 - g*t (the second derivative of position equation x = x0 + vt+at^2/2)
a = 0m/s/s (the acceleration at the top when it stops)
a0 = 25m/s/s (the initial acceleration i got from f=m*a)
g = 9.8m/s/s
t = ?
0m/s/s = 25m/s/s - 9.8m/s/s*t
t = 2.551
Then I was told: "Wait a sec... what are you dealing with change in acceleration for" ... " your equation is incorrect ... your equation has acceleration confused with velocity"
So I tried this:
force = 50N
mass = 2kg
gravity = 9.8 m/s/s
v = v0 + at (derivative of vf - vi = at)
v = 0 (final velocity, at the top when it stops)
v0 =
I'm not sure what to do from now on though. Any help is appreciated - thanks! :D
I think you don't have enough information.
The crucial piece of the puzzle that's missing is how long the 50N force was applied? 0.01 seconds? 0.1 seconds? It makes a difference.
Without that, you can't determine the change in momentum, from which you may deduce the starting velocity v0. Determining the change in momentum:
F*t = m2*v2 - m1*v1
t being the time of contact and in this case m1=m2, v1=0.
From there on there are several methods to solve this, a simple one is using energies.
1/2 m v^2 = mgh
starting position's kinetic E = potential E of pause at the top
once you got the hight, you can calculate time from 1/2 a t^2.Best wishes
Yeah, I got told that too... so if I just assume the amoutn of time the foot is in contact with the ball to be 0.1s, then I can do it. Thanks for your input, I really appreciate it :)
I'll try and solve it now and I'll post back results
mihajovics said:
F*t = m2*v2 - m1*v1
I got 2.5m/s.
mihajovics said:
F*t = m2*v2 - m1*v1
1/2 m v^2 = mgh
I don't quite understand this part though, can you elaborate a little? What do the variables stand for in that equation? Is the equation just a derivative of ke = 1/2mv^2? Also, what do you mean with last line?
Thanks.
If you don't know what potential energy or kinetic energy is, just solve it with your original idea. Also read http://en.wikipedia.org/wiki/Kinetic_energy and http://en.wikipedia.org/wiki/Potential_energy :smile:
Otherwise...
kinetic energy + potential energy = constant
because energy is reserved within a closed system. (Sorry if that's not the proper expression, my English isn't the best.)
At the starting position (after the kick) for a moment at the very beginning the ball only has kinetic energy.
At the top the ball stops to move for a moment, thus it has 0 kinetic energy. But energy can't just be lost (assuming no air resistance, etc), so what happened to it? It changed into another form of mechanical energy, potential energy: m*g*h m=mass g=gravity h=height.
The two positions:
bottom: 0 + kinetic
top: potential + 0
state 1) = state 2) because energy is reserved within the system.
Once you have the height, you may calculate the amount of time the ball is in the air. Think of how long it would take to drop the item from that height (h). And don't forget to multiply that by two (going up takes the same time as going down).
I understand it, thanks mate! :D
