Kinetic Energy and Collision Question
The discussion centers on the maximum kinetic energy loss during collisions between two objects. The maximum energy that can be lost is equal to the initial kinetic energy of the system. Momentum conservation plays a crucial role, with maximum kinetic energy loss occurring when two objects coalesce. In glancing collisions, energy loss depends on the alignment of their velocity components along the line of contact. The complexity increases with irregular shapes and potential conversion of energy into rotational motion, highlighting that energy loss can vary based on the collision dynamics.
bebop1
Is there a threshold of maximum kinetic energy lost when kinetic energy is transferred between two objects through collision?
I just cannot find any information on this, any help would be VERY much appreciated.
Welcome to PF;
How much kinetic energy did the system start with?
That is the maximum that can be lost.
Momentum must be conserved. Their common mass centre therefore continues at the same velocity. Maximum KE loss occurs when they coalesce.
If it is a glancing blow, and the masses are not sticky, then their velocities parallel to the plane of contact will not change. Maximum KE loss when will be when their velocity components along the line of contact become the same.
If they are irregular shapes and the blow is glancing, it gets complicated since some of the energy may turn into rotational energy, so it depends whether you count that as conserved or lost.
There is also the case when a blob of wet clay collides with a fixed wall and sticks...
Are you saying I did not cover that?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
