Kinetic energy, force, rotation
The discussion revolves around a physics problem involving a hollow cylinder and a rope, where a constant force is applied to the rope causing the cylinder to rotate. The key points include the need to calculate the change in kinetic energy of the cylinder and the force applied to the rope. The participant initially struggled with part A and attempted part B, calculating the force P as 29.59 N but received feedback indicating an incorrect moment of inertia was used. Clarifications were provided regarding the velocity of the center of mass and the appropriate moment of inertia for a hollow cylinder. The discussion emphasizes the importance of using the correct equations and understanding the physical concepts involved.
mybrohshi5
A light, flexible rope is wrapped several times around a hollow cylinder with a weight of 49.0 N and a radius of 0.27 m. The cylinder is attached by spokes of a negligible moment of inertia to a fixed horizontal axle coincident with the axis of the cylinder; the cylinder is free to rotate without friction about this axle. The cylinder is initially at rest. The free end of the rope is pulled with a constant force P for a distance of 4.95 m, at which point the end of the rope is moving at 6.25 m/s; the rope does not slip on the cylinder.
A)What is the change in kinetic energy of the hollow cylinder as a result of the rope having been pulled?
B) For the situation as described in the introduction, what is the value of P?
v=rw
k = 1/2mv2 + 1/2Iw2
w = omega
ki + ui + Work = kf + uf
i didnt know how to do part a so i just skipped to part B)
W = FD ----> W = P(4.95m)
W = kf
P(4.95m) = 1/2(5kg)(6.252) + 1/2(1/2(5kg)(.27m)2(6.25/.27)2)
P = 29.59 N
This is wrong though and i am not sure why. Also if i could get some help on part A that would be great.
Thank you :)
v=rw
k = 1/2mv2 + 1/2Iw2
w = omega
In the equation
K=\frac{1}{2}mv^2+\frac{1}{2}I\omega^2
what does v stand for? Don't just say velocity. The velocity of what?
W = kf
P = 29.59 N
Thank you :)
Also, you're using the wrong moment of inertia. The key word is hollow.
V should be the velocity of the center of mass v_cm
i am not sure what moment of inertia to use then? would it be
I = mr^2
should i just be using K = 1/2Iw^2 instead of what i have?
thanks for the help :)
Right. So what is the velocity of the cylinder's center of mass?
I = mr^2
Yes, all of the mass of the hollow cylinder is at a distance r away from the axis of rotation, so I=mr2.
