Calculating Changes in Water Speed with Kinetic Energy Equations
The discussion focuses on calculating the change in water speed based on an increase in kinetic energy. When the kinetic energy of flowing water increases by a factor of 2.25, the speed change factor can be determined using the kinetic energy equation, KE = 0.5mv^2. By isolating v^2, the relationship between the new and old kinetic energies is established, leading to the conclusion that the speed changes by the square root of 4.5. This mathematical approach effectively demonstrates how kinetic energy correlates with velocity changes in flowing water. The solution emphasizes the importance of understanding the relationship between kinetic energy and speed in physics problems.
McKeavey
It was on a test, not sure if I remember it to the exact word but it went something like..
If the Kinetic Energy of flowing water increases by a factor of 2.25, what is the factor that the speed changes by.
Something like that :S
I said something like..
The square root of 4.5/m
Try it like this:
Ek(new)/Ek(old) = 2.25
Ek(new)=0.5mvnew2
Ek(old) = ?
Now just sub it into the equation.
Say KE=1 originally. It would become 2.25 if increased by a factor of 2.25. With the Equation KE=.5mv^2, you can isolate the v^2 to get v^2= KE/(.5m). Just replace the values and you would get that answer. 2.25/.5= 4.5 which becomes the square root of 4.5 after you square root velocity
