Kinetic-Molecular Model of Ideal Gas: vrms/vav
The discussion focuses on calculating the average x-component of velocity, average speed, and root mean square (rms) velocity for gas molecules moving only in the x direction. The average x-component is simply the arithmetic mean of the velocities without absolute values. For average speed, absolute values of the velocities are averaged. The confusion arises around calculating rms velocity, with the participant questioning whether to square the average speed and take the square root, and if the formula for rms in mathematics applies here. Clarification is sought on the correct approach to these calculations, particularly for the rms value.
verd
Hey,
This should be a pretty simple problem to answer... I'm just a bit confused on this, and want to make sure I'm right. It's an easy problem:
Molecules in a gas can only move in the x direction (i.e., v_{y}=v_{z}=0). You set up an experiment in which you measure the velocity of a few molecules and the result that you obtain is the following (expressed in m/s):
2, -4, 6, 1, -3, -2, -5, 2, -1, 4, 3, -5
Calculate: a) the average x-component of the velocity (v_{x})_{av}, b) the average speed (v)_{av}, and c) the root mean square of the velocity v_{rms}For a), the x-component of velocity is literally just the average, right? No absolute values b/c we're not talking about speed here.
For b) because I'm being asked for the average speed, here is where I take the absolute values of all of these and average them together, right?
For c) This is where I'm most confused... Here, wouldn't I just square what I got for b) and then take the square root of it? That seems to make absolutley no sense. Would I then use the formula below?I noticed something in the book: (v_{x}^2)_{av}, (v_{y}^2)_{av}, (v_{z}^2)_{av} must all be equal. Hence: (v_{x}^2)_{av} = \displaystyle{\frac{1}{3}}(v^2)_{av}
This wouldn't apply for this situation, correct? As the y and the z components are 0, right?
Its been a while since I did some gas theory, but isn't the rms of the velocities, simply v_{rms} = \frac{A}{\sqrt{2}} (A = Ans to part b.)
Don't quote me on that, I'm not sure, but I think its right since rms voltage in electronics is defined in a similar way.
Thanks for responding, heh
I don't quite understand why you get that, could you explain it further?
(I'm not doubting you, I just don't understand)
Thanks again
Bump, please...?
Would this be the same as the root-mean-square in mathematics?
\sqrt{\displaystyle{\frac{\sum_{i=1}^{n}x^2}{n}}}
So my problem would look like this:
\sqrt{\displaystyle{\frac{2^2+(-4)^2+6^2+1^2+(-3)^2+(-2)^2+(-5)^2+2^2+(-1)^2+4^2+3^2+(-5)^2}{12}}}
Is this correct?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
