Solving Circuits with Kirchhoff's Rules
  • Thread starter Thread starter physicssux
    Circuits Rules
The discussion focuses on applying Kirchhoff's rules to solve a circuit problem, with participants expressing confusion about deriving the necessary equations. Key points include the application of voltage drops across resistors and the identification of current directions, which can be arbitrary. One participant emphasizes the importance of understanding the signs of voltage and current, explaining that a negative sign indicates a voltage drop. The conversation also highlights the challenge of grasping these concepts initially but encourages persistence in learning physics. Overall, the thread serves as a support platform for students struggling with circuit analysis using Kirchhoff's rules.
physicssux
Apply kirchhoffs rules to find the currents in the circuit shown
http://img297.imageshack.us/img297/5048/kirchvm8.jpg
here's what the book says
i3(25 ohms) = 12 V
i2(15 ohms) = 6.0V + 12 V
i1 = i2 + i3
i have tried over and over again on hoow they got the equations from but i don't understand.
where did i3 come from there are only 2 resistors. so only 2 current.
i just don't understand kirchhoff loop rule, is there any place where i can a ismple explanation because the book DOES NOT HELP
You might review the lecture notes found here.
https://www.physicsforums.com/showthread.php?t=95448
For this problem, a couple of observations:
the voltage change down the middle path must be 12V. It is in parallel with a a 12 Volt limb, so IR=12 where R=25.
Now along the outside loop, we have two batteries and a single resistance.
The drop must be zero so i2*15 must equal the sum of the two voltages. (Take everything else away except an 18 volt battery and the resistance.)
hey thanks for the notes
but i still can't get understand it.
i think it's already built in in my head that i won't understand.
i just don't know how to get the equations.
how do you know if the current is positive or not, or if the voltage is positive or not, i just don't get t hose.
well your attitude re physics probably isn't helping.
But don't give up. I certainly didn't get those rules at first, and for many of us here at PF, physics generally is a hard fought battle for small chunks of understandings that over time can grow into an actual appreciation and love of the subject. Yea, sure you say. I just want to get thru this friggin class and have nothing to do with it again. Hey that's OK as well.
The signs aren't that hard but can be at first and maybe why you are getting confused.
lets try the small loop from lowerleft corner of circuit, since the wide line is on top as we move upwards, this is positive voltage
so 12V-i3*25=0
When current flows across a resistor we call these voltage drops, hence the negative sign. The direction of i3 is chosen as clockwise but this is arbitrary. We could just as easily gone the other way round the loop,
then -i3*25-12V=0. Now since we are going the other way across the battery, its -12. So the answer is different but that only tells us that its going in the opposite direction we assumed, so no penalty for guessing.
The other big loop is treated the same, again starting from lower left
12V-i2*15+6V=0 Had the voltage signs of the 6V battery been different, would have had to count that as -6V.
For the current let's consider the area in common between the loops. The currrent in that last stretch before we get to the lower left hand corner consists of contributions from the inside and outside loop. Technically we consider nodes, but intuitively one can see the total current there consists of contributions from both loops which were both treated as clockwise positive. So i1=i2+i3.
Look here for some more examples
:http://www.ualr.edu/dcwold/phys2122/p24man/p24man.html
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
