Lab Report: Centripetal Force - Should I Round or Extend?
  • Thread starter Thread starter melchisio
    Lab
In the discussion about a lab report on centripetal force, the main concern is whether to round numbers for significant figures or extend them for accuracy in graphing. Rounding leads to a misleading graph with an apparent outlier, while extending the figures aligns the data points correctly. It is suggested to maintain precision in the report and address the rounding issue in the conclusion as a source of error. The importance of accurately representing data for clarity and correctness is emphasized. Ultimately, using precise figures while explaining the implications of rounding is recommended for a more accurate representation of results.
melchisio
lab report--quickie!
im drawing up the graphs for my "centripetal force" lab report by hand, and we are instructed to use sig figs.
problem is, if i use sig figs and round my numbers, the graph's points are in a straight line with one other point that looks like an outlier. It isn't an outlier, and i know what the graph is supposed to look like... my points would follow that exact correlation if i extended the numbers one more digit.
Should i keep my figures rounded, however messed up my graph looks, or should i just leave it and explain the "lack of" trend in my conclusion??
HELP SOON!
How about mentioning as a source of error.I meam,u know how it looks like with accurate no-s and how it doesn't with the no-s rounded.How about you do it as it should come out (namely precision) and the end of the paper mention the reason for doing it:if u had used less sign.dig-s,your graph would have looked differently,possibly incorrect.
Daniel.
yea thanks, i wouldn't have thought of that. I think it'll work into my report really well!
