Minimum angle the ladder can make with the floor without slipping
In summary, the minimum angle that a ladder can make with the floor without slipping is determined by the coefficient of friction between the ladder and the ground. This coefficient is affected by the surface conditions and materials of both the ladder and the floor. A higher coefficient of friction means the ladder can make a smaller angle with the floor before slipping, making it more stable. It is important to choose a ladder with a suitable coefficient of friction for the surface it will be used on to ensure safety and prevent accidents.
sncobra
[/B]
A 3.0-m-long ladder, as shown in the following figure, leans against a frictionless wall. The coefficient of static friction between the ladder and the floor is 0.32.
What is the minimum angle the ladder can make with the floor without slipping?
With the axis of rotation at the bottom of the ladder:
ΣT = 0 <- torque
ΣF = 0
T = LF
T = LFsinφ
ƒ = μN
X to the right is positive, Y up is positive
Nw = Normal of wall
Nf = normal of floor
fs = static friction force
Fg = gravity
ΣFx = 0
Nw - fs=0
Nw = μNf
ΣFy = 0
Nf-Fg = 0
Nf = mg
So,
Nw=μmg
Now I'm still having trouble with torques so bear with me. Since these two forces go through the axis then they produce no torque correct?
TNf = 0
Tfs = 0
and
TFg = (Fg)(L/2) = mg(L/2)
TNw = (Nw)(L)
Am I on the right path? I think you sum the two torques but I don't have the mass so that wouldn't work.
Also, how do I know if the torque is negative or positive? and which way do I make torque positive? CW or CCW?
Appreciate any and all advice :)
link to the picture: http://session.masteringphysics.com/problemAsset/1385677/5/K-P12.60.jpg
Welcome to PF!
sncobra said:
[/B]
ΣT = 0 <- torque
ΣF = 0
T = LF
T = LFsinφ
ƒ = μN
Nw = Normal of wall
Fg = gravity
ΣFx = 0
Nw - fs=0
Nw = μNf
ΣFy = 0
Nf-Fg = 0
Nf = mg
So,
Nw=μmg
Correct so far.
TNf = 0
Tfs = 0
and
TNw = (Nw)(L)
It is right that the forces have zero torques if their line of action goes through the axis. But you calculate the torques incorrectly. Torque is force multiplied with the lever arm, the distance of the line of action from the axis. https://sites.google.com/site/torqu...xamples-of-torque-in-everyday-life/torque.gif
Remember, the torque makes the ladder rotate. Imagine that you exert force in the same direction as the force in question. In what direction will the ladder rotate? Do the normal force and the weight rotate in the same way?
Yep - the sum of the torques must be zero if the ladder is static.
Leave the mass of the ladder in as a variable "m".
Hello and welcome to PF!
TNf = 0
Tfs = 0
Yes.
and
TNw = (Nw)(L)
These aren't correct. For example, L/2 is not the "lever arm" for Fg because the direction from the axis to the center of mass is not perpendicular to the direction of the force.
Once you set the sum of the torques to zero, maybe some things will cancel out of the equation.
Usually, CCW is chosen as positive. But it won't make any difference here as long as you take CW and CCW torques to have opposite signs. A torque is CCW if it tends to rotate the ladder CCW around your chosen axis.
Oops, others answered while I was constructing my comments. Sorry.
Okay I wasn't sure I did the lever arm right thanks all.
So would the lever arm for Fg be d1 in the picture? and then d2 for Nw?
d1 = (L/2)cos60°
I'm still not sure where to go for the torque of Nw
And if I chose CCW to be positive, then Nw would be negative and Fg would be positive? Is that correct?
d1 = (L/2)cos60°
Yes. (Of course, in your problem the angle is not necessarily 60o.)
I'm not sure what you're having a problem with here. Is if finding the distance d2 in the diagram?
Yes, the torque from Nw would be negative and the torque from Fg would be positive.
What do you mean by this? I remember my professor saying something about the angle between the lever arm and force.
Yeah and I'm not sure what the angle you would use here would be either. I'm going to use a right triangle correct?
Thanks, you definitely cleared up the direction for me and are helping quite a bit :)
The lever arm is perpendicular to the force. You need the length of the level arm.
Use the angle θ the ladder makes with the horizontal . Your goal is to find the angle when the ladder starts to slip, by solving the equations you wrote up. See the link in my post #2.
Related to Minimum angle the ladder can make with the floor without slipping
What is the minimum angle that a ladder can make with the floor without slipping?
The minimum angle that a ladder can make with the floor without slipping is determined by the coefficient of friction between the ladder's feet and the floor surface. This angle is also influenced by the weight of the ladder and the weight of the person or object on the ladder.
How is the minimum angle calculated for a ladder?
The minimum angle is calculated using the formula:
Minimum Angle = arctan(coeff. of friction)
This formula takes into account the coefficient of friction and the weight of the ladder and load on it to determine the minimum angle required to prevent slipping.
What is the coefficient of friction and how does it affect the minimum angle for a ladder?
The coefficient of friction is a measure of the resistance between two surfaces in contact. In the case of a ladder, it refers to the resistance between the ladder's feet and the floor surface. A higher coefficient of friction means a greater resistance and therefore a lower minimum angle is required to prevent slipping.
What factors can affect the minimum angle for a ladder?
Aside from the coefficient of friction, the weight of the ladder and the load on it is a major factor in determining the minimum angle. The type of surface the ladder is placed on can also affect the minimum angle, as well as any external factors such as wind or movement of the ladder.
Why is it important to know the minimum angle for a ladder?
Knowing the minimum angle for a ladder is important for safety purposes. If the angle is too steep, there is a higher risk of the ladder slipping and causing injury or damage. It is also important for efficiency, as using the correct angle can make it easier to climb and work on the ladder without fear of it slipping.
