Lagrange Multipliers: A theoretical question and an example
This discussion centers on the application of Lagrange multipliers to solve optimization problems involving constraints. The first problem involves maximizing the function f(x,y,z) = x + z subject to the constraint x² + y² + z² = 51, yielding a maximum value of √102. The second problem examines the function f(x,y) = 5/x + 1/y under the constraint x + y = 1, leading to a maximum value of approximately 10.47. Participants provide detailed calculations and seek validation of their results, demonstrating a solid understanding of gradient methods and constraint handling.
  • Understanding of Lagrange multipliers
  • Knowledge of gradient vectors and their properties
  • Familiarity with optimization problems in multivariable calculus
  • Ability to solve systems of equations
  • Study advanced applications of Lagrange multipliers in constrained optimization
  • Learn about the method of Lagrange multipliers in higher dimensions
  • Explore numerical methods for solving optimization problems
  • Investigate the implications of constraints on optimization solutions
Students and professionals in mathematics, physics, and engineering who are interested in optimization techniques and their applications in real-world problems.
diewolke
Hello physicsforums community.
I have recently learned about Lagrange multipliers and have been given three problems to solve. Could you guys please go over my work and see if I have the gist of it? One question, a theoretical one, I have no idea how to begin. Any advice regarding this would be welcomed.
Thanks
PS: Please excuse any formatting errors; this is my first post on this forum.
Question 1a
f:R^2-->R^2, (x,y)-->x^2-y^2, and let S be the circle of radius 1 around the origin.
In two dimensions, the condition that
[tex]\nabla[/tex]f(x,y,z)=[tex]\lambda[/tex][tex]\nabla[/tex]g(x,y,z) at [tex]x_{o}[/tex], that is, [tex]\nabla[/tex]f(x,y,z) and [tex]\nabla[/tex]g(x,y,z) are parallel at [tex]x_{o}[/tex][/tex] is the same as the level curves being tangent at x[tex]_{.}[/tex]. Give the reason why you may conclude that the level curves are tangent at [tex]x_{o}[/tex].
2. f:R^2-->R^2, (x,y)-->x^2-y^2 and
g:R^2-->R^1, (x,y)--> x^2+y^2 (obtained from the statement about S)
3. I simply do not have a clue how to go about this. I know that the gradient of a function is given by the coordinates which are the function's partial derivatives. I also know that the gradient points to the direction of highest increase for a function at a particular point. Regarding level sets, I know that level sets are given by all (x,..x[tex]_{n}[/tex]) such that f(x,..,x[tex]_{n}[/tex])=c, where c is a constant. I am not sure how to utilize this information to produce an answer. Any advice?
Question 1b
1. Using the Lagrange multiplier method, maximize the function f(x,y,z)=x+z subject to the constraint x^2+y^2+z^2=51
2. [tex]\nabla[/tex]f(x,y,z)=[tex]\lambda[/tex][tex]\nabla[/tex]g(x,y,z)
3.
Having computed the gradients for g and f, listed the partials separately, and using the above equation, I obtained the following system of equations:
1=2x[tex]\lambda[/tex]
0=2y[tex]\lambda[/tex]
1=2z[tex]\lambda[/tex]
Solving for x, y, and z, I obtained
x=1/(2lambda)
y=0 and
z=x=1/(2lambda)
and here is the constraint once more: x^2+y^2+z^2=51
substituting the values of x, y, and z into the above expression,
I get [tex]\lambda[/tex]=+ or - [tex]\frac{1}{\sqrt{102}}[/tex]
using this value to solve for x, y, and z, I get that
x=+ or -[tex]\frac{\sqrt{102}}{2}[/tex]
y=0 and
z=+ or -[tex]\frac{\sqrt{102}}{2}[/tex]
plugging in these values into f(x,y,z)=x+z,
I find that the max must be [tex]\sqrt{102}[/tex]. Is this correct?
I will post the third question shortly.
Thank you again
Question 2
1. Consider the function f(x,y)=5/x+1/y subject to the constraint
x+y=1, x>0, and y>0. Does this function with a constraint have a minimum or maximum? If so, what are these values?
2. [tex]\nabla[/tex]f(x,y)=[tex]\lambda[/tex][tex]\nabla[/tex]g(x,y)3. Finding the gradients for f and g and using the above formula, I obtained the following system of equations:
-5/x^2=[tex]\lambda[/tex]
-1/y^2=[tex]\lambda[/tex]
Solving for x and y,
x=[tex]\sqrt{-5/lambda[/tex] and
y=[tex]\sqrt{-1/lambda[/tex]
I discarded the negative valued solutions for x and y because of the given constraints that x and y are both greater than 0.
the constraint restated:
x+y=1
substituting x and y into this expression to solve for [tex]\lambda[/tex],
I get [tex]\lambda[/tex]=-2(3+sqrt{5})
solving for the numerical values of x and y using this [tex]\lambda[/tex],
I get that
x=sqrt(-5/(2(3+sqrt5))) and
y=sqrt(-1/(2(3+sqrt5)))
Plugging these values into f(x,y)=5/x+1/y I get a value of about 10.47.
I assume this to be a max since the other solutions for x and y (the negative values of what I found for x and y) had to be discarded due to the constraints that x and y > 0. These discarded x and y values would have produced a value less than 10.47, so I conclude that 10.47 is the max. Any input? Corrections? I expect more of the latter, haha.
  • · Replies 16 ·
