Lagrange Polynomial Interpolation
xkellyy
Find the polynomial p(x) of degree 20 satisfying:
p(-10) =p(-9) = p(-8) = ...=p(-1) = 0
p(0) = 1
p(1) = p(2) = p(3) = ...p(10) = 0
L(x) := \sum_{j=0}^{k} y_j \ell_j(x)
i tried using the formula above:
a = p(-10) / (-1)(-2)(-3)...(-20) = 0
and got zero for all the coefficients excluding the 20th coefficient, which i got 1/0
then i thought about it graphically - it looks like a cos graph so i tried using the maclaurin series expansion but realized that it only works from n to infinity.
any tips?
A few suggestions. Throw some itex and tex tags around your latex to make them render. Next, could you define some of things you're using? What are y_j, \ell_j,a? It is impossible for us to guess what these are supposed to be.
Now assuming I've guess your notation correctly, the Lagrange polynomial is given by
L(x) = \sum_{j=0}^{20} p(x_j) \ell_j(x)
where
\ell_j(x) = \prod_{i\neq j, i=0}^{20} \frac{ (x -x_j) }{(x_j-x_i)}
in which case you are correct, all terms except the j=0 term disappear. So what is \ell_0?
where
so to find the nth coefficient for the x^n-1 term
a(n) = p(n)/(x-x1)(x-x2)(x-x3)...
x1, x2 terms are the x values of the data points provided from ascending order excluding the x(n) point if that makes sense
but what I'm saying is, i get zero or 1/0 (for P(0) = 1) point for all the coefficients i calculate which is where I'm stuck :/
Okay, I understand the x(n) notation but you still haven't defined what y_j is, what \ell_j is, or how a(n) fits into the definition of the Lagrange polynomial. It's impossible to help you unless you make these things clear.
yj is the y co-ordinate of the data point...lj is the coefficient of x^n, where n is the varying degrees of the polynomial (in this example, 0-20 because there are 21 data points)
a(n) was just my way of explaining lj.
Ah, okay.
Well, the \ell_j are never zero. Take a look at how I defined \ell_j in one of my previous posts and you'll see that this is true. What is the formula you are using to calculate them?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
