Proving Symmetry and Finding Conserved Quantities for Lagrangian Functions
To prove symmetry in the Lagrangian function L(q, dq/dt, t) under the translation q → q + e, it is essential to show that ∂L/∂q = 0. This indicates that L remains invariant under the transformation. The discussion highlights the need to utilize a Taylor expansion to analyze the changes in L due to the infinitesimal parameter e. Participants emphasize the importance of the Euler-Lagrange equation in identifying conserved quantities, which are defined by having a null time derivative. The conversation revolves around clarifying the application of Taylor series and the correct approach to finding the conserved quantity.
sunmaggot
Given L (q, dq/dt, t).
translation: q ---> q + e (e is infinitesimal constant)
show that if ∂L/∂q = 0, then L is symmetry under the above translation.
then find conserved quantity.
S = ∫ L dt
My attempt is nothing... because I don't know the proper procedure to prove a symmetry. Do I simply prove L' - L = 0? But then the next part askes me to find conserved quantity. I have no idea how to find it...
So, can anyone spare me some hints...?[/B]
Let ##L_1=L_1(q, \dot{q}, t)## and ##L_2## that with the replacement ##q\rightarrow q+ \epsilon##. Now consider the expansion of ##L_2## in the infinitesimal parameter ##\epsilon##.
do you mean taylor expansion??
A conserved quantity means null time derivative of that quantity. Look at the Euler-Lagrange equation.
Yup :)
CAF123 said:
Yup :)
cool, I will try it first!
CAF123 said:
Yup :)
the taylor series has a term (x-a), what should be the a?
What should be the x?
x is q?
That's not what CAF123 suggested you to do. L is a function of phase space: you are interested in a small perturbation of the position variable, which changes the whole function L. So this means taking a McLaurin expansion in the infinitesimal translation parameter.
