Largest mass for Ultimate Tensile Strength
The discussion focuses on determining the maximum radius and mass of a steel ball that a steel wire can support, given the wire's dimensions and the ultimate tensile strength of steel. Participants emphasize the importance of understanding the relationship between stress, strain, and material properties, particularly the ultimate strength as a measure of failure. There is a realization that the ultimate strength represents the stress at which failure occurs, clarifying previous misconceptions about the relationship between stress and strain. Suggestions include using free body diagrams for visualization and working backward from known material properties to find the required mass. The conversation concludes with a consensus on the correct interpretation of ultimate strength in solving the problem.
AJKing
Vibrations and Waves, A.P. French, questions 3-9
Please /do not/ provide full solutions. Just suggestions.
A solid steel ball is hung at the bottom of a steel wire of length 2m and radius 1mm, the ultimate strength of steel is 1.1E9 N/m2. What are the radius and mass of the biggest ball the wire can bear?
Y = \frac{\sigma}{\epsilon} (line)
U = \frac{\sigma_u}{\epsilon_u} (point below line)
m = \frac{4}{3}\pi*r^3 \rho
\rho \approx 7850 Kg/m^3 (Internet)
For the sake of sanity, I arrange eq.2 by knowns and unknowns.
\frac{U*A}{g*l_0} = \frac{m}{\Delta l}
I must find Δ l
I consider two points on the Y line:
Y = \frac{\sigma_u}{\epsilon_1}
Y = \frac{\sigma_2}{\epsilon_u}
both can be written as
Y = C\frac{\sigma_u}{\epsilon_u} = C U
C = Y/U
Then I stop and think about how this will lead me in circles.
I have a suspicion that the solution to my problem requires differential equations. Anyone second that notion?
DEs not required. Do you know what Y represents?
You know the ultimate stress the wire is capable of sustaining. You also know the size of the wire. Can you use this information to work back and figure out the amount of mass required to produce this stress? Draw a free body diagram if it helps you to visualize the situation.
Y is available in the text.
[strike]The ultimate stress σu. Do I really know this without knowing the ultimate strain εu?[/strike]
Have I been wrong this entire time? Is ultimate strength just the stress associated with failure?
Suggesting the following is incorrect:
Holy hell.
Yes. I was incorrect about ultimate strength!
Break through in understanding here folks.
Ultimate strength is the stress of failure.
Question solved correctly.
Our discussion in the other forum makes more sense now SteamKing - cheers :).
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
