Law Of Universal Gravition (am I Right?)
  • Thread starter Thread starter heelp
    Law Universal
The discussion centers on estimating the surface gravity of a neutron star with five times the mass of the sun and a radius of about 10 km. The correct formula for calculating gravity involves using the gravitational constant and the mass of the star, which can be derived from the sun's mass. Participants clarify that the mass of the neutron star is indirectly provided in the problem statement and emphasize the importance of correctly applying the formula. Additionally, there is a query about calculating the acceleration of gravity 250 km above Earth's surface, highlighting the dependence on distance and mass. The conversation reinforces the need to accurately interpret given values in gravitational calculations.
heelp
A certain neutron star has five times the mass of our sun packed into a sphere about 10km in radius. estimate the surface gravity on this monster.
= (5)(1.99 *10^30 =m
10km =r
g = G mass of earth/r^2 = 6.67* 10^ -11 9.95* 10^30/10^2 = 6.64m/s
Is that the right answer?
Calculate the acceleration of gravity 250km above the Earth's surface in terms of g
ar = v^2/r I'm really stuck I would I go about solving this problem? your help will be appreciated.
The acceleration of gravity is dependent upon the mass of the Earth and the distance (d) that an object is from the center of the earth. Think a little about the inverse square law.
The value of g on any other planet can be calculated from the mass of the planet and the radius of the planet. The g on the surface would be inversely proportional to the square of the radius and proportional to the Mass of the planet times the gravitational constant.
There was no need to use the mass of the earth. The question is asking you for the g of a star that's 5X the mass of our sun. The equation that you are using is right. You just inserted the wrong values.
I should enter the mass off the star? it wan't given
Of course it was. The question says "A certain neutron star has five times the mass of our sun". The mass is indirectly stated. Just loook up the mass of the sun then times it by 5 that's all. Common you can do it :wink:
