How Many Dynes to Change Length of Spring by 20cm?
  • Thread starter Thread starter tuffshorty
    Length Spring
To change the length of a spring by 20 cm, it requires 400 dynes, calculated by multiplying the force needed for a 5 cm change by four. Springs operate linearly, allowing for direct proportionality in force and displacement. For a more formal approach, one can determine the spring constant (k) using the formula Fspring = k*x, where Fspring is the force and x is the displacement. The discussion confirms that the initial calculation is correct and no additional formulas are necessary. Understanding the linear nature of springs simplifies the calculation process.
tuffshorty
The question is... suppose it requires 100 dynes to change the length of a certain spring 5 cm. What force is required to change the length of the spring 20 cm?
Would you just multiply it... and say it would take 400 dynes?
Sounds good to me :smile: Springs are linear. If you wanted to be more formal about it, you could find the spring constant k from Fspring=k*x since you know Fspring and you know x.
Okay, thank you! Just wanted to make sure i wasn't missing a formula somewhere
