Length/Time Period squared Relationship of a Simple Pendulum
The discussion revolves around the relationship between length and time period squared in the context of a simple pendulum. Participants explore the derivation of the formula and clarify concepts related to angular motion and differential equations.
  • Homework-related
  • One participant states that the L/T^2 relationship of a simple pendulum gives a constant of g/(2π)^2 and requests a derivation.
  • Another participant provides a derivation involving the force on the pendulum bob and the differential equation for small angles, leading to the solution involving angular frequency.
  • A participant expresses confusion about the notation used, specifically regarding angular acceleration and the parameters in the solution, asking for clarification on their meanings.
  • A later reply confirms the interpretation of angular acceleration and explains the parameters A0 and φ in the context of initial conditions and phase adjustment.
  • Participants discuss the relationship between the second derivative of the sine function and the characteristics of simple harmonic motion.
  • One participant thanks another for the clarification received, indicating a better understanding of the concepts discussed.
Participants generally agree on the mathematical framework and concepts involved, but there is a lack of consensus on the clarity of the explanation and notation used, particularly for those less familiar with calculus and differential equations.
The discussion includes varying levels of understanding among participants, with some expressing uncertainty about mathematical symbols and concepts. There is also a mention of the need for LaTeX for proper notation, indicating a limitation in communication of mathematical ideas.
This discussion may be useful for high school students learning about simple harmonic motion, those seeking clarification on the mathematical derivation of pendulum motion, and individuals interested in the application of differential equations in physics.
Thinker8921
I know the L/T^2 relationship of a simple pendulum gives a constant- g/(2pi)^2.
Could anyone please show me how it is derived?
Thanks in advance.
Thanks in advance.
The force on the pendulum bob is:
F = -mgsin\theta = ma = mL\ddot\theta
For small angles, sin\theta \approx \theta so you have the differential equation:
\ddot\theta = -\frac{g}{L}\theta the solution of which is:
\theta = A_0\sin(\omega t + \phi) where \omega^2 = g/L with \omega = 2\pi/T
AM
Thankyou for the reply. I think I should have been a little clearer. I am in high school and this depth is a little new so I don't understand the whole explanation.
-The theta sign with the 2 dots*, I am thinking it is angular acceleration? That way, mLa will be torque of the pendulum bob.
- I get the differential, however not the next step with the A zero sign and phi sign. What do they represent. Is it (Started calculus a week ago).
Please could you clear my doubts.
Thanks again.
*How do I insert the actual symbols in this?
Welcome to PF, by the way.
That's right.
These are parameters for the initial condition. The A0 (I could have said \theta_0) is the maximum value of \theta, which occurs when the sin term = 1. The \phi is simply to adjust for the phase - ie. when the amplitude maximum occurs in relation to t. For example if amplitude was maximum at t=0, you would set \phi = \pi/2 so that the sin term gave a value of 1 (which is the maximum value for sin).
The idea here is that if you take the second derivative of \theta_0\sin (\omega t + \phi) you get -\omega^2\theta_0\sin (\omega t + \phi), which is simply -\omega^2 x the original function. Generally if the second derivative is -\omega^2 multiplied by the original function, the function must be a some sort of sine wave with frequency \omega. You will learn how to solve this kind of equation when you study differential equations.
You have to use Latex. See https://www.physicsforums.com/showthread.php?t=8997" for help on Latex.
AM
Thanks, this has made it clearer to me.
  • · Replies 36 ·
