Testing the Magnetism of a Solenoid & Galvanometer
When two magnets, one S-N and the other N-S, move towards a solenoid with a hollow core, they induce opposing currents in the solenoid. As they approach each other at the same speed, the currents generated by each magnet cancel each other out. Consequently, the galvanometer connected to the solenoid shows no current. This phenomenon occurs because the magnetic fields from the two magnets are equal and opposite. Therefore, the prediction of no current in the galvanometer is correct.
handsomecat
suppose you have a solenoid with hollow core connected to a galvanometer.
On one side you have a S-N magnet (ie. the N pole is nearer to the solenoid). On the other side you have a N-S magnet( ie. S pole is nearer to solenoid). ie.
[S - N] [Solenoid] [N - S]
Both magnets are equidistant from the solenoid, and at a distance sufficient for the solenoid to "detect" the magnetic field.
They start moving towards each other at the same speed into the solenoid core and stop at the same time.
My prediction is that there will be absolutely no current shown in the galvanometer. This is because it is impossible to have N poles on both sides of the solenoid to oppose the motion.
As this topic is new to me, is my prediction correct?
You have a contradition between your text and your graph that you might want to clear-up.
Apologies. It should read:
On one side you have a S-N magnet (ie. the N pole is nearer to the solenoid). On the other side you have a N-S magnet( ie. N pole is nearer to solenoid). ie.
It is true that you will register no current. The reason is that the two magnets induce exactly opposing currents, which cancel.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
