LHC first beam (end of world) time announced
  • Thread starter Thread starter neu
    Beam Lhc Time
CERN announced that the first attempt to circulate a beam in the Large Hadron Collider (LHC) is scheduled for September 10, 2008. This event marks the initial circulation of protons, not the first collision. The process will involve circulating protons counterclockwise initially, followed by switching directions to test the system's functionality. During this initial test, only a small fraction of protons will be used to avoid damage to the equipment, as adjustments to the magnet settings are anticipated. The lighthearted commentary about the "end of the world" reflects a mix of humor and misunderstanding surrounding the LHC's operations, emphasizing that significant events will occur later in the testing phase.
neu
"Geneva, 7 August 2008. CERN1 has today announced that the first attempt to circulate a beam in the Large Hadron Collider (LHC) will be made on 10 September."
http://press.web.cern.ch/press/PressReleases/Releases2008/PR06.08E.html
That's cool. About time too.
So by putting "(end of world)" are you feeding into some people's idiotic belief's or stating your own?
I'm pretty sure he was joking.
Good.
Er.. that isn't really the end of the world. That Sept. 10 date is first proton beam circulating in the LHC, not the first collision. I was told it will be counterclockwise (looking from the top). They then will switch and get the proton beam to go the other way (cw), and then they'll switch it back to see if that will work again like the first time. During this test, they will use a very small fraction of the protons that will eventually be used, because they know they'll get the magnet setting not quite right and the protons will hit the walls of the vacuum beam line. You don't want to incur proton damage right away by flooding it with the full proton density per bunch.
In other words, the end of the world will come later, probably in early October, thank you. :)
Zz.
Man, I was hoping the end of the world was going to happen before school starts again. :(
Similar to the 2024 thread, here I start the 2025 thread. As always it is getting increasingly difficult to predict, so I will make a list based on other article predictions. You can also leave your prediction here. Here are the predictions of 2024 that did not make it: Peter Shor, David Deutsch and all the rest of the quantum computing community (various sources) Pablo Jarrillo Herrero, Allan McDonald and Rafi Bistritzer for magic angle in twisted graphene (various sources) Christoph...
Thread 'My experience as a hostage'
I believe it was the summer of 2001 that I made a trip to Peru for my work. I was a private contractor doing automation engineering and programming for various companies, including Frito Lay. Frito had purchased a snack food plant near Lima, Peru, and sent me down to oversee the upgrades to the systems and the startup. Peru was still suffering the ills of a recent civil war and I knew it was dicey, but the money was too good to pass up. It was a long trip to Lima; about 14 hours of airtime...
