Lift and Drag from Pressure Distribution over an Air Foil
Calculating lift and drag from pressure distribution over an airfoil is complex, as it involves understanding both static and dynamic pressure. While lift and induced drag can be determined, skin friction or parasitic drag presents challenges due to its dependence on the boundary layer characteristics. The shear boundary layer can thicken and transition from laminar to turbulent flow, affecting the effective shape of the airfoil. Accurate pressure distribution measurement may require instrumentation that could impact airflow. Simplified models often rely on the Navier-Stokes equations to analyze these forces effectively.
Triggers12
Pretty simple question:
Is it possible to completely calculate Lift and Drag from the pressure distribution over an airfoil?
Atm, I have Lift worked out as well as the Induced drag ( correct me if I'm wrong. ) but am having trouble working out how it would be possible to get the skin friction / parasitic drag.
Thanks for your help!
Trigs
How would you determine the pressure distribution over an airfoil? Perhaps some form of intrumentation, but that would have some effect on the flow. A simplified model could use static pressure distribuition and the normals (line perpendicular) to the sections of surface of a wing, but there are other factors. Static pressure isn't directional, but dynamic pressure and any related changes in momentum of the air are directional. Skin friction is nearly parallel to a wing surface. The shear boundary layer thickens over time, may detach and reattach as it transitions from laminar to turbulent, so that changes the effective air foil shape.
The best mathematical models for lift and drag are usually based on some simplified form of Navier Stokes equations:
http://en.wikipedia.org/wiki/Navier–Stokes_equations
rcgldr said:
How would you determine the pressure distributaion over an airfoil? Perhaps some form of intrumentation, but that would have some effect on the flow. A simplified model could use static pressure distribuition and the normals (line perpendicular) to the sections of surface of a wing, but there are other factors. Static pressure isn't directional, but dynamic pressure and any related changes in momentum of the air are directional. Skin friction is nearly parallel to a wing surface. The shear boundary layer thickens over time, may detach and reattach as it transitions from laminar to turbulent, so that changes the effective air foil shape.
Hey thanks for the response,
Trigs
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
