Lifting a car of 1500 Kg through air compressor
To lift a 1500 kg car using an air compressor with 50 nozzles, the size of the nozzles and the required pressure depend on the force generated by each nozzle. The discussion highlights skepticism about the feasibility of such a method, comparing it to an air hockey table rather than a practical lifting solution. Questions arise regarding the force output of each nozzle and the overall design concept. The idea is deemed impractical, suggesting that consulting experts like Randall Munroe could provide better insights. Ultimately, the concept lacks a solid engineering foundation for effective implementation.
Vikramaditya
If I want to lift a car of 1500 kg with a air compressor and with 50 nozzles, what should be the size of nozzles and what should be the pressure of air compressor and at what pressure will the air come out through nose so that it could be easily be lifted.
Nozzles? Is this an air mattress or a bunch of mini jet engines?
How much force out of each nozzle?
Let me get this straight. Are you imagining something like an air hockey table, but with cars? It's a ludicrous idea. Maybe you should ask Randall Munroe, author of What If.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
