Analyzing the Effects of Lifting on a Wagon and Train Model in Ansys Workbench
The discussion focuses on conducting a lifting analysis of a wagon with a train model in Ansys Workbench. The user seeks guidance on how to analyze the effects of lifting the wagon, specifically regarding the potential for permanent deformation. There is a suggestion to apply acceleration to simulate the lifting velocity. Concerns are raised about the complexity and safety of the analysis, prompting a recommendation to consult an experienced professional. Additional context and images are requested to better understand the analysis requirements.
lavecchiasignora
Hello!
I wish to do a lifting analysis in Ansys workbench.
Basically it is a wagon with a train on it. I wish to analyse what happens to the model when lifting the wagon which has the weigth of the wagon+train.
What is the easiest way to analyse what will happen to the wagon when lifting it with slings attached to the side of the wagon? Should I apply a acceleration to the wagon which will represent the velocity of the lifting? I must decide if the lifting will result in any permanent deformation to the wagon when lifting it... any idea on how to proceed?
Thanks!
This sounds like a complicated and potentially dangerous analysis, have you considered that it might be better to have this analysis done by an experienced professional?
Why dangerous? Just static analysis...
Is this static analysis being done to certify a lifting or rigging fixture for a real-life application? Please provide more context (including images if possible) regarding the analysis you want to perform...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
