Why Do Light Bulbs Blow When You Turn Them On?
Light bulbs often blow when turned on due to a surge in current through the filament, which is influenced by the filament's resistance. When cold, the filament has lower resistance, allowing a higher current to flow, which heats the wire rapidly. This sudden increase in temperature causes mechanical strain on the thin metal wire, leading to failure. The greatest temperature difference occurs at the moment of activation, contributing significantly to the bulb's failure. Understanding the relationship between resistance, temperature, and current is crucial in explaining why light bulbs blow.
_Muddy_
We did an experiment in class abvout resistance and temperature. The teacher told us to find out why light bulbs usually blow when you turn on the light. It must be related to the experiment we did which was seeing how resistance changed with temperature
I'm not sure if there are any, If there are please tell me
I have no idea why, and i wouldn't know where to look on the internet
thanks
_Muddy_
The light bulb fails because the current through the filament is too large.
The current depends on the resistance
How does the resistance of metal change with temperature ?
The higher the temperature the higher the resistance.
So then, the light bulb fails because the current through the filament is too large. The resistance is too low. So the temperature is too high. Is that correct? What actually happens to the filament, does it break? Why would a high temperature/ high current make the light bulb fail?
The filament is a thin metal wire - rather like a fuse.
When the filament is cold the resistance is lower and so the currentis higher.
The current heats the wire which expands which puts a mechanical strain on it.
Also when the light is first turned on is the greatest temperature difference and so the greatest strain - this is probablyy more important than the resistance in reality
thanks a lot for that, I'm pleased and my teacher should be pleased aswell
