Light Diffraction: Physics Basics Explained
  • Thread starter Thread starter primarygun
    Diffraction Light
Light diffraction involves the bending and spreading of light waves when they encounter an obstacle or slit, resulting in interference patterns. The brightness of colors in these patterns is indeed proportional to their amplitude, with the center typically appearing the brightest due to constructive interference. Even with a single slit, multiple light beams can create interference, leading to a series of bright and dark fringes on a screen. The behavior of light diffraction differs from that of water waves, primarily due to the distinct properties of electromagnetic waves compared to mechanical waves. Understanding these principles is crucial for grasping the fundamentals of wave behavior in physics.
primarygun
http://www.geocities.com/thescience...ffraction.html]
Refer to this web site, please.
The brightness of the colour is proportional to its amplitude?
I can understand why the middle of the screen is the brightest, but in my mind, I think there should be only one area which is bright for a single-slit.
Is that light has many beams and able to create interference for even only a single-slit?
The diffraction of a light beam is really different from that of a water wave, isn't it?
The page you requested was not found.
Yeah, fraction is spelled wrong, and there are too many "..."
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
