Limit of Functions proof; help
Unassuming
Let E \subset \mathbb{R} and E \neq \emptyset. Fix p as a limit point of E. Suppose that f is bounded and realvalued on E and that \lim_{x \to p}f(x) does not exist. Prove the fact that there exist sequences p_n and q_n in E with \lim_{n}p_n=\lim_{n}q_n=p such that \lim_{n}f(p_n) and \lim_{n}f(q_n) exist, but are different.
Since p is a limit point of E, we are guaranteed a sequence (p_n) in E where p_n \neq p and \lim_{n}p_n=p. Using the same logic I can find another sequence, call it (q_n), that converges to p.
Now I am unsure how \lim_{n}f(p_n)and \lim_{n}f(q_n) exist?
f is bounded, so given a sequence of values (f(pn), you can find a convergent subsequence. Use the subsequence instead of the full sequences you originally find.
I'd be wary about the 'using the same logic' part though... let's say E is the set of all numbers of the form 1/n... if my first sequence is an = 1/n, I've screwed myself out of finding any more sequences. You need to work your way around this problem
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
