Limsupremum calculation horrible difficulty
betty2301
Calculate the radius of convergence of \sum_{n=0}^\infty a_{n}z^{2n}
let \sum_{n=0}^\infty a_{n}z^{n}with radius R
\limsup|a_n|^{\frac{1}{n}}=\limsup |\frac{a_{n+1}}{a_n}|
\limsup|a_n|^{\frac{1}{n}}=\lim_{k\to\infty}|a_{2k}|^{\frac{1}{2k}}
then how to write the "ratio"....
the latex is killin me please help....
You could use the limsup formula, but it's easier to think about what the radius of convergence means. Basically you're given that the original series converges for |z| < R and diverges for |z| > R, so what happens when you square z?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
